Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4451
    • Russia
    Re: Samsung ue49mu6120
    Hello, do this. You should have it, then click Write.
    • Marty-Club
      • Aug 2019
      • 23
      • United Kingdom
      hi QE will not let me tick it, even when iv unlocked it...
      • Marty-Club
        • Aug 2019
        • 23
        • United Kingdom
        Hi lotas the Qe will not let me tick, everything else in the description is working...
        • lotas
          • Jan 2016
          • 4451
          • Russia
          Try hitting "read" first.
          • Marty-Club
            • Aug 2019
            • 23
            • United Kingdom
            Hi lotas this is my chip reader,
            Just looked on eBay I can get ue55ue6120 main board, I'm not sure if it's compatible...
            Thanks for your advice,
            • lotas
              • Jan 2016
              • 4451
              • Russia
              #26
              Try "NeoProgrammer V2.2.0.10"
              • Marty-Club
                • Aug 2019
                • 23
                • United Kingdom
                #27
                Hi That did'nt work
                im guessing QE has to be ticked
                • lotas
                  • Jan 2016
                  • 4451
                  • Russia
                  #28
                  Yes, it is compatible, but you will need to rearrange the eeprom SPI_ic1603 W25Q80, it is responsible for the t-con there are settings for your matrix, its diagonal.
                  • Marty-Club
                    • Aug 2019
                    • 23
                    • United Kingdom
                    #29
                    Hi that program let me select qe, pressed write yes,
                    Nothing come up in the log,
                    Is that normal, usaly tell you if it's confirm write on the log...
                    Rgs Martin
                    • Marty-Club
                      • Aug 2019
                      • 23
                      • United Kingdom
                      #30
                      How do I rearrange the eprom settings, on the tv, easy to do
                      • lotas
                        • Jan 2016
                        • 4451
                        • Russia
                        #31
                        ry everything from the beginning in stages with a new program, as I described the instructions.
                        • lotas
                          • Jan 2016
                          • 4451
                          • Russia
                          #32
                          Do you program with a clothespin?
                          Programming must be removed from the 25q40 board and programmed through the adapter and then soldered back.
                          • lotas
                            • Jan 2016
                            • 4451
                            • Russia
                            #33
                            Yes, easy, you need to unsolder 25q80 from one board and rearrange it to another.
                            • Davi.p
                              Hobbist
                              • Sep 2009
                              • 4258
                              • Italy - Milan
                              #34
                              If you uncheck SRP0 can you check QE?
                              • lotas
                                • Jan 2016
                                • 4451
                                • Russia
                                #35
                                QE is not active for some reason in the program, I already wrote that the CH341A programmer itself needs to be modified.
                                • lotas
                                  • Jan 2016
                                  • 4451
                                  • Russia
                                  #36
                                  f you do not activate the QE protection, then when installing and turning on the TV, the "header" at the beginning of the dump will be deleted again.
                                  • Marty-Club
                                    • Aug 2019
                                    • 23
                                    • United Kingdom
                                    #37
                                    yes i was using the clip, i need to unsolder the chip use in the programer
                                    • lotas
                                      • Jan 2016
                                      • 4451
                                      • Russia
                                      #38
                                      Yes, that's better!
                                      • Marty-Club
                                        • Aug 2019
                                        • 23
                                        • United Kingdom
                                        #39
                                        Hi ok i will unsolder the chip use the programmer see how it goes, fingers crossed
                                        can you buy the chips Winbond 25Q40CL.. ..
                                        rgs Marty......
                                        thanks for the help
                                        • lotas
                                          • Jan 2016
                                          • 4451
                                          • Russia
                                          #40
                                          Hopefully, the main thing is not to damage the nearby components when dismantling.
