Samsung ue49mu6120
This topic is closed.
  • lotas
    • Jan 2016
    • 4602
    • Russia
    Re: Samsung ue49mu6120
    Hello, do this. You should have it, then click Write.
    • Marty-Club
      • Aug 2019
      • 23
      • United Kingdom
      hi QE will not let me tick it, even when iv unlocked it...
      • Marty-Club
        • Aug 2019
        • 23
        • United Kingdom
        Hi lotas the Qe will not let me tick, everything else in the description is working...
        • lotas
          • Jan 2016
          • 4602
          • Russia
          Try hitting "read" first.
          • Marty-Club
            • Aug 2019
            • 23
            • United Kingdom
            Hi lotas this is my chip reader,
            Just looked on eBay I can get ue55ue6120 main board, I'm not sure if it's compatible...
            Thanks for your advice,
            • lotas
              • Jan 2016
              • 4602
              • Russia
              #26
              Try "NeoProgrammer V2.2.0.10"
              • Marty-Club
                • Aug 2019
                • 23
                • United Kingdom
                #27
                Hi That did'nt work
                im guessing QE has to be ticked
                • lotas
                  • Jan 2016
                  • 4602
                  • Russia
                  #28
                  Yes, it is compatible, but you will need to rearrange the eeprom SPI_ic1603 W25Q80, it is responsible for the t-con there are settings for your matrix, its diagonal.
                  • Marty-Club
                    • Aug 2019
                    • 23
                    • United Kingdom
                    #29
                    Hi that program let me select qe, pressed write yes,
                    Nothing come up in the log,
                    Is that normal, usaly tell you if it's confirm write on the log...
                    Rgs Martin
                    • Marty-Club
                      • Aug 2019
                      • 23
                      • United Kingdom
                      #30
                      How do I rearrange the eprom settings, on the tv, easy to do
                      • lotas
                        • Jan 2016
                        • 4602
                        • Russia
                        #31
                        ry everything from the beginning in stages with a new program, as I described the instructions.
                        • lotas
                          • Jan 2016
                          • 4602
                          • Russia
                          #32
                          Do you program with a clothespin?
                          Programming must be removed from the 25q40 board and programmed through the adapter and then soldered back.
                          • lotas
                            • Jan 2016
                            • 4602
                            • Russia
                            #33
                            Yes, easy, you need to unsolder 25q80 from one board and rearrange it to another.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4330
                              • Italy - Milan
                              #34
                              If you uncheck SRP0 can you check QE?
                              • lotas
                                • Jan 2016
                                • 4602
                                • Russia
                                #35
                                QE is not active for some reason in the program, I already wrote that the CH341A programmer itself needs to be modified.
                                • lotas
                                  • Jan 2016
                                  • 4602
                                  • Russia
                                  #36
                                  f you do not activate the QE protection, then when installing and turning on the TV, the "header" at the beginning of the dump will be deleted again.
                                  • Marty-Club
                                    • Aug 2019
                                    • 23
                                    • United Kingdom
                                    #37
                                    yes i was using the clip, i need to unsolder the chip use in the programer
                                    • lotas
                                      • Jan 2016
                                      • 4602
                                      • Russia
                                      #38
                                      Yes, that's better!
                                      • Marty-Club
                                        • Aug 2019
                                        • 23
                                        • United Kingdom
                                        #39
                                        Hi ok i will unsolder the chip use the programmer see how it goes, fingers crossed
                                        can you buy the chips Winbond 25Q40CL.. ..
                                        rgs Marty......
                                        thanks for the help
                                        • lotas
                                          • Jan 2016
                                          • 4602
                                          • Russia
                                          #40
                                          Hopefully, the main thing is not to damage the nearby components when dismantling.
                                            09-07-2024, 05:50 AM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
                                            Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                            This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 06:20 PM
