Samsung ue49mu6120
This topic is closed.
  • Marty-Club
    • Aug 2019
    • 23
    • United Kingdom
    Samsung ue49mu6120
    Hi i have Samsung ue49mu6120
    the tv will not turn on, no standby light, power supply BN44-00807F
    Main board BN41-02568B
    BN94-12644a
    i have repaired tv's in the past, i know the basics.....
    when i remove the psu cable to main board i get back lights......
    if any one has repaired this tv or had similar problem..
  • lotas
    • Jan 2016
    • 4789
    • Russia
    Re: Samsung ue49mu6120
    This chassis is famous for its standby firmware rally in SPI Flash W25Q40CL (IC1604).
    If you have a programmer, then copy the contents of W25Q40CL (IC1604) and post it here, I'll fix the dump for you.
    • Marty-Club
      • Aug 2019
      • 23
      • United Kingdom
      hi how do i copy contents of w25q40l ic1604... eprom chip?
      • lotas
        • Jan 2016
        • 4789
        • Russia
        Using the programmer, you unsolder the spi flash, insert it into the programmer and read the data, save it in BIN format and put it here.
        • Marty-Club
          • Aug 2019
          • 23
          • United Kingdom
          I don't have programmer, where would I get one from,
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4506
            • Italy - Milan
            eBay: search CH431A
            Lotas: can i know why the dump must be "fixed" instead of rewritten? thanks
            • lotas
              • Jan 2016
              • 4789
              • Russia
              Well, I don't know whether to buy the simplest "CH341A" or take it from friends who are engaged in electronics repair, without a programmer you will not repair your Samsung, only replace the mainboard.
              • lotas
                • Jan 2016
                • 4789
                • Russia
                Originally posted by Davi.p
                eBay: search CH431A
                I will fix its damaged dump and post the finished fixed here and it will remain to write it back to flash and solder it back.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4506
                  • Italy - Milan
                  No i've asked why not to provide him a standard dump, and you want his dump, what goes wrong with them?
                  • lotas
                    • Jan 2016
                    • 4789
                    • Russia
                    They are not all standard, they may have different software versions.
                    • Marty-Club
                      • Aug 2019
                      • 23
                      • United Kingdom
                      Hi have a programmer CH341A now, please can you post software and drivers.... to use programmer
                      i have removed the main board i can only see ic1603 Winbond 25Q80DVSIG 1737... is this the right chip to copy?
                      rgs Martin
                      • lotas
                        • Jan 2016
                        • 4789
                        • Russia
                        Hi, the chip spi flash is under the IC1604 (25Q40CL) heatsink.
                        Driver and program for CH341A "AsProgrammer" posted here
                        https://www.badcaps.net/forum/showth...t=99752&page=2
                        • Storyteller12
                          • Jun 2020
                          • 625
                          I just bought the same programmer and tried but had no luck. Please let me know if you get it to work. Maybe I’m doing something wrong.
                          • Marty-Club
                            • Aug 2019
                            • 23
                            • United Kingdom
                            chip
                            • lotas
                              • Jan 2016
                              • 4789
                              • Russia
                              chip
                              chip read.OK
                              • Marty-Club
                                • Aug 2019
                                • 23
                                • United Kingdom
                                I think so, what do I do now? saved old chip
                                Fixed now.. to download on the chip...
                                Rgs Martin
                                • lotas
                                  • Jan 2016
                                  • 4789
                                  • Russia
                                  Yes, write this corrected dump to the same chip, use this instruction when writing.
                                  https://www.badcaps.net/forum/showpo...3&postcount=29
                                  • Marty-Club
                                    • Aug 2019
                                    • 23
                                    • United Kingdom
                                    Hi i have got to the stage Seger edition check mark s7 s3 s14 s9 not on the register
                                    • lotas
                                      • Jan 2016
                                      • 4789
                                      • Russia
                                      Hello, why do you have an empty dump (FF FF FF ...), you should have this.
                                      • Marty-Club
                                        • Aug 2019
                                        • 23
                                        • United Kingdom
                                        Hi I'm still getting the same on the status register no s7 etc
                                        The program you added fixed chip 7zip or winrar
                                        Rgs Martin
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
