JVC LT-55CF890 backlight on but no image
  • notallbad
    • Oct 2012
    • 1190
    This is a Fire TV Edition
    The tv powers on, sound and can hear the remote response (clicks on the tv) but no images, no logo, menu or picture.
    This set only has power and main boards.
    Help appreciated!
  • notallbad
    • Oct 2012
    • 1190
    Re: JVC LT-55CF890 backlight on but no image
    photos
    • diif
      • Feb 2014
      • 6978
      • England
      Voltage on the fuse both sides ?
      • notallbad
        • Oct 2012
        • 1190
        12.5v on both sides of the fuse on the (t-con) panel board fuse
        • diif
          • Feb 2014
          • 6978
          • England
          Check for any test voltages, check the diodes and caps for shorts.
          • notallbad
            • Oct 2012
            • 1190
            the 3 diodes on the (tcon) panel board seem ok, caps dont appear to have shorts.
            Not exactly sure which are the test points in all cases for the voltages labeled but there are 1.8, 3.3, 1.05 and 12v present around the board.
            • notallbad
              • Oct 2012
              • 1190
              When initial mains power applied the red led standby light comes on solid, when powered up from standby the red led flashes 18 times and then when powered off goes solid, next time its powered from stby it goes out with no flashes. Until next time its completely powered down then its back to 18 flashes.
              I guess this is normal being a smart tv?
              • notallbad
                • Oct 2012
                • 1190
                power board voltages
                12v stby (stby- 12.55v, on - 12.55v)
                power pin 9 5v_stby (stby - 0v, on - 0v)
                dimming (stby - 2.75v, on - 3.4v)
                BL_on_off (stby - 0v, on - 5v)
                stby_on/off_not (stby - 0v, on - 0v)
                power pin 1 24v_vcc (stby - 24v, on - 24v)
                After a short period of time (5 mins) the stby volts change
                12v stby (stby- 8v, on)
                power pin 9 5v_stby (stby - 0v)
                dimming (stby - 0v)
                BL_on_off (stby - 0v)
                stby_on/off_not (stby - 1.4v)
                power pin 1 24v_vcc (stby - 5v)
                • notallbad
                  • Oct 2012
                  • 1190
                  The power pin 9 5v stby is not connected to anything on the pcb side of the board so can be ignored.
                  So looking at the power board voltages I would say they look ok.
                  Anyone care to confirm please?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I was suggesting you check the voltages on the slim boards that connect to the panel, the rest are working if you have everything but picture.
                    • notallbad
                      • Oct 2012
                      • 1190
                      Yh sorry, I was partly supplying more detail as well as checking all basics were covered and correct.
                      I believe at the moment that the power board and backlights are ok. Suspect the firmware is ok.
                      But not yet convinced the main board cpu chip is 100%, which if it is ok it then only remains for the panel board(s) to be faulty. Bummer!
                      • comptek
                        • Aug 2013
                        • 606
                        Check screen slim boards for anything getting hot caps or dc-dc converter etc
                        • notallbad
                          • Oct 2012
                          • 1190
                          Shall confirm with photos later but although there is hvin_12v and hvin_24v at the connector theres also a hvin_12v on one of the slim panel boards that does not appear to be there and noticed a chip labelled 8100vb (3 pin - 2 top, 1 bottom) quite hot, think its a diode. Theres a small i.c, 6 pin i think in close proximity that could be a dc-dc converter.
                          I have a temp gun so shall check around the boards on those small smd caps.
                          But again will confirm later.
                          Thanks for the help!
                          • notallbad
                            • Oct 2012
                            • 1190
                            It would seem the slim panel board is hotter in the upper portion as per zoomed in photo below, around 41 degrees whereas its around 24 to 30 degrees elsewhere.
                            • notallbad
                              • Oct 2012
                              • 1190
                              Theres an smd G64 6 pin ic, mosfet.
                              12.5v on pin 4 Source
                              12.4v on pin 3 Gate
                              0v on pins 1, 2, 5 & 6.
                              Drain is connected to the hvin_12v test point that reads 0v.
                              How can I bypass or otherwise check its the mosfet at fault?
                              thanks
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Is it hot ? You can check mosfets in diode mode but it's not in the photo of the hotter area, have you checked the components there ?
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Theres an ic SM4190 which I'm assuming is a DC-DC converter, but cant find any datasheet for it.
                                  But seems its not generating any of the required voltages. i.e -14v, -7.4v, -3.3v, -4.15v, 9v or 32v.
                                  I have panel slim boards from a 49" tv which are very similar but no longer connected to the panel but when powered up gives me voltages for comparison.
                                  The other day I did get a perfect picture, I did not do anything to cause it that I know of, but had to power it off and now cant get it back since.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    SM4190 appears to be a processing chip. What voltages are you getting at your ldvs input on the paired lines going into main processor? You should read about 1.2v if data is coming from mainboard.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      These are the voltage comparisons from the connected panel boards and the spare disconnected from panel board.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        Still looks like a processing chip, not voltage chip.
                                        • Salem Aboshala
                                          820-00138-A got image but no backlight
                                          by Salem Aboshala
                                          Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                          I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                          History: my laptop backlight stopped working without any reason.
                                          Symptoms:
                                          I have image on screen using my flashlight.
                                          I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                          Keyboard backlight still working and can be adjusted normally.
                                          Since two days I tried to follow all similar...
                                          06-11-2024, 03:02 PM
                                        • zaurus81
                                          Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                          by zaurus81
                                          This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                          The board is equipped...
                                          01-16-2025, 03:54 AM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • ajgae
                                          HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                          by ajgae
                                          Hi everyone!
                                          First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                          03-06-2025, 09:53 AM
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
