JVC LT-55CF890 backlight on but no image
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: JVC LT-55CF890 backlight on but no image
    re ball is probably the only option but may require hand re ball if no stencils availabe hence in situations like this if you have two boards i guess maybe worth a reflow on a bga station ( i would try it if i was my own set i was keeping) but i dont own a bga reflow machine
    • notallbad
      • Oct 2012
      • 1183
      Originally posted by notallbad
      These are the voltage comparisons from the connected panel boards and the spare disconnected from panel board at the LVDS connector.
      For info/ref.
      These readings are the same when TV is working.
      • menlinks
        • Dec 2021
        • france
        #43
        Thank you, I watch this when I get home
        • notallbad
          • Oct 2012
          • 1183
          If you need any further readings let me know.
          • danpianji88
            • Sep 2022
            • fadsfdsa
            #45
            Hello @dskall @notallbad,
            I seems the sm4190 like a dc-dc boost chip,because the pin 37 of sm4190 is a VONE,and when I take down the attached cap,the pin37 of the chip burnning an demaged
            • Salem Aboshala
              820-00138-A got image but no backlight
              by Salem Aboshala
              Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
              I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
              History: my laptop backlight stopped working without any reason.
              Symptoms:
              I have image on screen using my flashlight.
              I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
              Keyboard backlight still working and can be adjusted normally.
              Since two days I tried to follow all similar...
              06-11-2024, 03:02 PM
            • zaurus81
              Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
              by zaurus81
              This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
              The board is equipped...
              01-16-2025, 03:54 AM
            • Constantinos
              Macbook Pro A2442 820-02098 No image but has backlight
              by Constantinos
              Hi all
              I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
              He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
              Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
              Obviously, he decided against this and gave it to me so that I could have a crack at it.
              From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
              08-24-2024, 09:48 AM
            • ajgae
              HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
              by ajgae
              Hi everyone!
              First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
              03-06-2025, 09:53 AM
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
