Hitachi 55" TV dead after 18 months (Vestel 17MB100)
  • Ruptor
    • Sep 2021
    • 35
    • GB
    Re: Hitachi 55" TV dead after 18 months (Vestel 17MB100)
    Originally posted by ducky29
    They look the same but the screen is different. The image might be ok or it might be flipped, solarized. Probably even the remote might be different. You might need to flash the firmware from Hitachi again but you need a toshiba remote control to flash it.
    Are you saying the hardware could be different or it is software that can be changed? I bought mum a 65" Toshiba replacement because TV is her life at 96 years old so have a remote type CT8533.
    There are few listings for your board on ebay...
    I can't see any boards like mine only ones that appear to have the same components with a different reference.
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Software needs to be changed if you use the board from toshiba.
      Check here https://www.ebay.co.uk/sch/i.html?&_nkw=23348885
      • Ruptor
        • Sep 2021
        • 35
        • GB
        Could I get an Hitachi 17MB100 main board for 48" or 43" and use my USB stick to upgrade it to 55"? The only difference in the screen type is the VES480QNDS-2D-N11 to VES550QNDS-2D-N11. Another query is I read the USB stick needs to be ext3 format not fat32 or others.
        I tried to check out the power supplies and found there was no 5V STBY on the main board but following it back to the PSU board there are no components fitted. Should there be 5V on the main board perhaps derived from another rail or is it an option that isn't required on this model TV?
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          Hi, try this, freeze with a butane gas or compressed air upside down can the following chips on the mainboard for 2-3sec.: U18,U23,U27 (appearently one microcontroller, two spi flash), U31(emmc) and eventually U1, wait 5sec. then turn on tv... Bye...
          • ducky29
            • Dec 2015
            • 369
            • Europe
            Its better to change the mainboard only with the correct part number. A mainboard from a 43 or 48 might work or it might not work. I cannot give you an answer for this. You have to find out yourself if you wanna go along that way.
            • Ruptor
              • Sep 2021
              • 35
              • GB
              #26
              Not so easy to do I don't have a freezer spray. Would it work putting the board in the freezer & dropping it to zero C?
              I am still hoping to fix the original board. I think the PSU is working & saw a cheap board for £13 that will verify the PSU state & give me a whole TV board that can drive an older TV via SCART or HDMI that can't tune the latest incarnation of digital channels with the addition of a PC supply. The final solution might be a £40 board if the problem is hardware but I want to investigate and learn more.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                #27
                In freezer is ok.
                • Ruptor
                  • Sep 2021
                  • 35
                  • GB
                  #28
                  In freezer is ok.
                  I nearly had frost bite when fitting the frozen board but it didn't make any difference.
                  There is 5V on the main on the LED connector so it must be an option to derive it from either 3.3V or 12V.
                  I am setting up a terminal to read the Tx output on the mini SCART today when I figure out which pin it is in the normal SCART socket on the end of the adapter lead.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4539
                    • Italy - Milan
                    #29
                    I'm sorry, some moments i have maybe a loss of concentration, reading again the first post, indeed the freeze technique is not the thing to do. Let's start to say that i don't trust the fate fault, this behaviours happens very often and are the manufacturers that intentionally bricks your device!
                    In this optic you can follow two main paths, one to complaint agaist Hitachi that you are sure the fault is by guilt of the upgrade software, until you are to the point of scream in their face, this is the best approach because morally right. The other is to study how the tv is bricked and this only by the serial log and trying to enter in the console..
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      Under the Consumer Rights Act 2018 it is the vendor not the manufacturer that is responsible and as it's a TV the expectation is still covered after 18 months.
                      The OP needs to remind the vendor about the UK laws under which they operate. They do at times seem to "forget". Loudly and on a Saturday when the shop is busiest is the best time to get the fastest resolution.
                      • Ruptor
                        • Sep 2021
                        • 35
                        • GB
                        #31
                        I didn't know that & when the supplied USB didn't work, after my prompting, Argos did give me the option of writing to customer services that would have been a long process but I was dealing with the incompetent doctors trying to get mum out of hospital where they were doing nothing for her so didn't follow it up.
                        Making money and morality are at odds these days.
                        This board works the TV full screen but the picture is upside down.
                        17MB120 23345028 FOR HITACHI 48HK6T74U TV SCREEN: VES480QNDS-2D-N11
                        Easily fixed by turning the TV 180 degrees and it proves beyond doubt that my main board is faulty.
                        After hours of messing around trying to get Putty working on Linux I ended up just setting up two terminal windows for receive and send that ended up stuck in a loop when I tested the comms by linking the RX & TX wires on the USB to serial adapter but it proved it could receive.
                        I have the PSU & main board on the table but there is no comms out of the SCART. I put the receive in both Data1 & Data2 but nothing. Does the board require other things plugged in to get to the point of talking to the serial output?
                        • arizanotlari
                          • Nov 2014
                          • 158
                          • Turkiye
                          #32
                          Hi.
                          17MB120 VES480QNDS-2D-N11 Flipped Panel File :
                          https://www.badcaps.net
                          • Ruptor
                            • Sep 2021
                            • 35
                            • GB
                            #33
                            Thanks for the file but what do I do with it? Put it on a USB stick & hold button at power on? Will a future update flip screen back?
                            • yokoono
                              • Apr 2010
                              • 515
                              #34
                              Unzipp.Create a folder called PQ on the stick (fat32). Put the file in it. Stick to tv. Type MENU 4725. Go to USB Operations and press OK. Exit the menu and turn off the TV. Unplug the TV and wait 1 minute. Take out the stick and turn on the TV.
                              • Ruptor
                                • Sep 2021
                                • 35
                                • GB
                                #35
                                Is there a way to back up the existing code just in case of a problem.
                                • ducky29
                                  • Dec 2015
                                  • 369
                                  • Europe
                                  #36
                                  That file only changes the screen. Your screen is already faulty so no need to backup that.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    #37
                                    usually serial line is not in scart port but in VGA or hdmi or internal port..
                                    • Ruptor
                                      • Sep 2021
                                      • 35
                                      • GB
                                      #38
                                      Quote from Hitachi 55HK6T64U
                                      55293DLB MB100 SERVICE MANUAL
                                      "Try to update TV with latest SW. Additionally it is good to check SW printouts via Teraterm. These printouts may give a clue about the problem. You can use mini scart for terraterm connection. "
                                      Mini SCART Pins 9 & 12 on the schematic are labelled UART_RX_SC & UART_TX_SC but there is no description of what happens in the adapter cable to convert the mini to standard SCART socket
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4539
                                        • Italy - Milan
                                        #39
                                        Can't you solder copper filaments onto miniscart internally? you have to connect ground , tx, rx, obviously tx,rx must be crossed respect to rx,tx of adapter..
                                        • Ruptor
                                          • Sep 2021
                                          • 35
                                          • GB
                                          #40
                                          I tried putting the screen flip file on root but it wasn't used by the TV so I put it in a directory called PQ like you said and it worked. Thanks a lot for the help and information from everybody I now have a working TV with the screen up the right way but the case needs hacking to clear the onboard SCART, the shifted aerial, Ethernet and SPDIF.
                                          Now I query the USB stick I was sent by Hitachi for the original board and whether it was created correctly for the job? All the files are in root as per the picture of previous post #6 but does the stick need to be bootable which it isn't?
                                          • Jaime Morillo
                                            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                            by Jaime Morillo
                                            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                            The TV was stuck on the logo and I couldn't access the update menu.
                                            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                            The image result was good, but the image is inverted.
                                            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                            08-18-2025, 11:38 AM
                                          • massimomax
                                            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                            by massimomax
                                            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                            spero che qualcuno può averlo per riprogrammare eprom. grazie
                                            Post in English !!!
                                            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                            02-28-2025, 07:27 AM
                                          • Bazilwrc164
                                            Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                                            by Bazilwrc164
                                            I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                                            The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                                            I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                                            If anyone can provide:
                                            • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                                            • Or a compatible EEPROM dump
                                            07-23-2025, 12:15 PM
                                          • EnricoS92
                                            Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
                                            by EnricoS92
                                            I have a problem with this tv Hitachi with vestel 17MB171 board.
                                            I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
                                            The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
                                            I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
                                            I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
                                            12-08-2021, 05:59 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
