Hitachi 55" TV dead after 18 months (Vestel 17MB100)
  • Ruptor
    • Sep 2021
    • 35
    • GB
    #41
    Re: Hitachi 55" TV dead after 18 months (Vestel 17MB100)
    Originally posted by Davi.p
    Can't you solder copper filaments onto miniscart internally?
    I could and short all the other pins together. TP167 & TP169 are on the UART lines but the board isn't labelled. However there are two test points that connect to the correct pins on the cable SCART socket so it is a reasonable assumption that the UART lines come out as described in the manual. The boards over MB100 seem to only have two methods of software update FTP & USB but both methods require a working TV screen where I only have a flashing LED. Maybe the code doesn't get far enough to log anything although I would guess if it is flashing the LED it is in the search for code mode or in to the software update mode.
    Given that I have put an Hitachi 17MB120 from a 48" TV in place of 17MB100 for a 55" TV and it works isn't it more likely any 17MB100 board would take the Hitachi USB code and work or does it have to be Hitachi because the boot loader software from a different manufacturer might be different?
    • Ruptor
      • Sep 2021
      • 35
      • GB
      #42
      I found a main board identical to the Hitachi 17MB100 very cheap for £5. On EBay here they advertise my remote RC5118 as Digi home & Hitachi.
      https://www.ebay.co.uk/itm/163395716...Cclp%3A2334524
      The board was advertised as Digi home, comes up as Toshiba, but Hitachi remote doesn't work it why?
      The TV works with the Digi home board and I found my 20 year old Toshiba remote works on it so I could change the language from Polish to English.
      What is the safest & best solution?
      1) Put Hitachi USB in and update the Toshiba to Hitachi so it is all back to normal.
      2) Get a different remote control & leave it as Toshiba.
      3) Cut the TV Box to fit the Hitachi 17MB120 board that uses the original. remote
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        #43
        the best way is to search the presence on board of settings eprom, buy a cheap eprom programmer, copy the one on original board to new one, there was a picture of the board i think, i can try to watch at it.
        • Ruptor
          • Sep 2021
          • 35
          • GB
          #44
          Code is in ball grid array Flash chip that is why I want to know if point '1' above would work or brick the board.
          Without any advice I shall go route '2' above and have a Toshiba in an Hitachi box without cutting up the back panel and use a universal remote control.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            #45
            are you sure? how are marked U33 & U27?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #46
              ignore sorry wrong thread
              • Ruptor
                • Sep 2021
                • 35
                • GB
                #47
                I know nothing about these TV boards. U27= 25L1606 U33= RK743
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #48
                  The first is an eprom but not the usual type of the settings, maybe it's it or not..
                  • Ruptor
                    • Sep 2021
                    • 35
                    • GB
                    #49
                    [Solved Twice] Re: Hitachi 55" TV dead after 18 months (Vestel 17MB100)
                    I am not gong to waste time trying to fix the original Hitachi 17MB100 board for the TV because I have two working solutions that are good enough.
                    Solutions
                    1) 17MB120 23345028 FOR HITACHI 48HK6T74U TV SCREEN: VES480QNDS-2D-N11 with the flip screen software back on post #32 works with the original remote control but the board connectors require the plastic back to be cut for the different connectors.
                    2) MB 17MB100 23330575 FOR DIGIHOME 48300UHDLEDCNTD TV SCR: VES480QNES-2D-U01 (1) Works the screen perfectly as a Toshiba and fits the box without modifications but not with the Hitachi remote control. An old Toshiba Regza Remote control works it perfectly.
                    I have chosen to the Toshiba route because I think their software updates will be more reliable not wanting to stuff the TV to maintain their product quality image.
                    Comparing the original TV and how it tunes in now I think the original board was not as good and maybe that is the reason the software update screwed up.
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • massimomax
                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                      by massimomax
                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                      Post in English !!!
                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                      02-28-2025, 07:27 AM
                    • Bazilwrc164
                      Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
                      by Bazilwrc164
                      I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
                      The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
                      I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
                      If anyone can provide:
                      • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
                      • Or a compatible EEPROM dump
                      07-23-2025, 12:15 PM
                    • EnricoS92
                      Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
                      by EnricoS92
                      I have a problem with this tv Hitachi with vestel 17MB171 board.
                      I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
                      The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
                      I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
                      I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
                      12-08-2021, 05:59 AM
                    • double_DD
                      How can I be sure that my EC chip is dead?
                      by double_DD
                      As the title suggests, how can I be sure that my EC chip is really dead?
                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                      03-12-2025, 07:47 AM
