Hitachi 55" TV dead after 18 months (Vestel 17MB100)
  • Ruptor
    replied
    [Solved Twice] Re: Hitachi 55" TV dead after 18 months (Vestel 17MB100)
    I am not gong to waste time trying to fix the original Hitachi 17MB100 board for the TV because I have two working solutions that are good enough.
    Solutions
    1) 17MB120 23345028 FOR HITACHI 48HK6T74U TV SCREEN: VES480QNDS-2D-N11 with the flip screen software back on post #32 works with the original remote control but the board connectors require the plastic back to be cut for the different connectors.
    2) MB 17MB100 23330575 FOR DIGIHOME 48300UHDLEDCNTD TV SCR: VES480QNES-2D-U01 (1) Works the screen perfectly as a Toshiba and fits the box without modifications but not with the Hitachi remote control. An old Toshiba Regza Remote control works it perfectly.
    I have chosen to the Toshiba route because I think their software updates will be more reliable not wanting to stuff the TV to maintain their product quality image.
    Comparing the original TV and how it tunes in now I think the original board was not as good and maybe that is the reason the software update screwed up.
  • Davi.p
    replied
    The first is an eprom but not the usual type of the settings, maybe it's it or not..
  • Ruptor
    replied
    Originally posted by Davi.p
    are you sure? how are marked U33 & U27?
    I know nothing about these TV boards. U27= 25L1606 U33= RK743
  • vinceroger69
    replied
    ignore sorry wrong thread
  • Davi.p
    replied
    Code is in ball grid array Flash
  • Ruptor
    replied
    the best way is to search the presence on board of settings eprom, buy a cheap eprom programmer, copy the one on original board to new one, there was a picture of the board i think, i can try to watch at it.
    Code is in ball grid array Flash chip that is why I want to know if point '1' above would work or brick the board.
    Without any advice I shall go route '2' above and have a Toshiba in an Hitachi box without cutting up the back panel and use a universal remote control.
  • Davi.p
    replied
  • Ruptor
    replied
    I found a main board identical to the Hitachi 17MB100 very cheap for £5. On EBay here they advertise my remote RC5118 as Digi home & Hitachi.
    https://www.ebay.co.uk/itm/163395716...Cclp%3A2334524
    The board was advertised as Digi home, comes up as Toshiba, but Hitachi remote doesn't work it why?
    The TV works with the Digi home board and I found my 20 year old Toshiba remote works on it so I could change the language from Polish to English.
    What is the safest & best solution?
    1) Put Hitachi USB in and update the Toshiba to Hitachi so it is all back to normal.
    2) Get a different remote control & leave it as Toshiba.
    3) Cut the TV Box to fit the Hitachi 17MB120 board that uses the original. remote
  • Ruptor
    replied
    Can't you solder copper filaments onto miniscart internally?
    I could and short all the other pins together. TP167 & TP169 are on the UART lines but the board isn't labelled. However there are two test points that connect to the correct pins on the cable SCART socket so it is a reasonable assumption that the UART lines come out as described in the manual. The boards over MB100 seem to only have two methods of software update FTP & USB but both methods require a working TV screen where I only have a flashing LED. Maybe the code doesn't get far enough to log anything although I would guess if it is flashing the LED it is in the search for code mode or in to the software update mode.
    Given that I have put an Hitachi 17MB120 from a 48" TV in place of 17MB100 for a 55" TV and it works isn't it more likely any 17MB100 board would take the Hitachi USB code and work or does it have to be Hitachi because the boot loader software from a different manufacturer might be different?
  • Ruptor
    replied
    Originally posted by yokoono
    Unzipp.Create a folder called PQ on the stick (fat32). Put the file in it.
    I tried putting the screen flip file on root but it wasn't used by the TV so I put it in a directory called PQ like you said and it worked. Thanks a lot for the help and information from everybody I now have a working TV with the screen up the right way but the case needs hacking to clear the onboard SCART, the shifted aerial, Ethernet and SPDIF.
    Now I query the USB stick I was sent by Hitachi for the original board and whether it was created correctly for the job? All the files are in root as per the picture of previous post #6 but does the stick need to be bootable which it isn't?
  • Davi.p
    replied
    Can't you solder copper filaments onto miniscart internally? you have to connect ground , tx, rx, obviously tx,rx must be crossed respect to rx,tx of adapter..
  • Ruptor
    replied
    usually serial line is not in scart port but in VGA or hdmi or internal port..
    Quote from Hitachi 55HK6T64U
    55293DLB MB100 SERVICE MANUAL
    "Try to update TV with latest SW. Additionally it is good to check SW printouts via Teraterm. These printouts may give a clue about the problem. You can use mini scart for terraterm connection. "
    Mini SCART Pins 9 & 12 on the schematic are labelled UART_RX_SC & UART_TX_SC but there is no description of what happens in the adapter cable to convert the mini to standard SCART socket
  • Davi.p
    replied
  • ducky29
    replied
    Originally posted by Ruptor
    Is there a way to back up the existing code just in case of a problem.
    That file only changes the screen. Your screen is already faulty so no need to backup that.
  • Ruptor
    replied
    Unzipp.Create a folder called PQ on the stick (fat32). Put the file in it. Stick to tv. Type MENU 4725. Go to USB Operations and press OK. Exit the menu and turn off the TV. Unplug the TV and wait 1 minute. Take out the stick and turn on the TV.
  • yokoono
    replied
  • Ruptor
    replied
    Originally posted by arizanotlari
    17MB120 VES480QNDS-2D-N11 Flipped Panel File :
    Thanks for the file but what do I do with it? Put it on a USB stick & hold button at power on? Will a future update flip screen back?
  • arizanotlari
    replied
    Hi.
  • Ruptor
    replied
    Originally posted by diif
    Under the Consumer Rights Act 2018 it is the vendor not the manufacturer that is responsible and as it's a TV the expectation is still covered after 18 months.
    I didn't know that & when the supplied USB didn't work, after my prompting, Argos did give me the option of writing to customer services that would have been a long process but I was dealing with the incompetent doctors trying to get mum out of hospital where they were doing nothing for her so didn't follow it up.
    this is the best approach because morally right. The other is to study how the tv is bricked and this only by the serial log and trying to enter in the console..
    Making money and morality are at odds these days.
    This board works the TV full screen but the picture is upside down.
    Easily fixed by turning the TV 180 degrees and it proves beyond doubt that my main board is faulty.
    After hours of messing around trying to get Putty working on Linux I ended up just setting up two terminal windows for receive and send that ended up stuck in a loop when I tested the comms by linking the RX & TX wires on the USB to serial adapter but it proved it could receive.
    I have the PSU & main board on the table but there is no comms out of the SCART. I put the receive in both Data1 & Data2 but nothing. Does the board require other things plugged in to get to the point of talking to the serial output?
  • diif
    replied
    In this optic you can follow two main paths, one to complaint agaist Hitachi that you are sure the fault is by guilt of the upgrade software, until you are to the point of scream in their face, this is the best approach because morally right. The other is to study how the tv is bricked and this only by the serial log and trying to enter in the console..
    The OP needs to remind the vendor about the UK laws under which they operate. They do at times seem to "forget". Loudly and on a Saturday when the shop is busiest is the best time to get the fastest resolution.
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
  • Bazilwrc164
    Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
    by Bazilwrc164
    I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
    The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
    I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
    If anyone can provide:
    • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
    • Or a compatible EEPROM dump
    07-23-2025, 12:15 PM
  • EnricoS92
    Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
    by EnricoS92
    I have a problem with this tv Hitachi with vestel 17MB171 board.
    I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
    The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
    I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
    I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
    12-08-2021, 05:59 AM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
