Hisense 58R6E3 (Backlights, sounds, no picture)
  • TVAddict
    • Jan 2022
    • 76
    • Caribbean
    Re: Hisense 58R6E3 (Backlights, sounds, no picture)
    have not heard of this before, where did you get this info from?
    I think he means the left side of the panel is shorted to ground...so the tape method may not be as effective.
    • Jayxlouis
      • Dec 2022
      yeah the tape method does not work for me either any solutionists
        • 12323
        • U.S.
        I see, test the components on that board for shorts, if you can post a good picture of that driver board.
        • edgar656
          • Apr 2023
          • Estados Unidos
          Has anyone already solved the problem?
            • 12323
            • U.S.
            How do you guys expect help, when NONE of you bother to post pictures, I asked for good pictures of panel driver boards. You want help then do that slightest bit of work, or don't, doesn't really matter, maybe take up another hobby or another career.
            • cozwurth
              • Apr 2023
              • 11
              I have the same model TV with a very similar sounding problem. After reading though the thread and seeing a request for pics I took a couple of mine.
              First pic is an overall of the back with the cover removed. Next are the main board and the T-con board. The pic with the half-lit screen has the T-con cable on the dark side disconnected. The pic with the half lit screen on one side and multi-color streaks on the other side has the first T-con cable reconnected and the other cable disconnected. Screen is black with both connected. A little history on this one... It had some mysterious sticky goo in the back panel, and in the lower trim where all of the ribbon cables connect to the driver boards. I think the lady's kids spilled something in it. I carefully cleaned things with a lint-free cloth and rubbing alcohol. I'm guessing that the screen is shot based on what I'm seeing, but that's just a guess on my part. Thoughts?
              Dave
                • 12323
                • U.S.
                #27
                Can check the little mlc capacitors on the thin panel driver boards for shorts or very low ohms, see if you can detect any damage on the tab bonds, sometimes liquid cleaners which should not be used, will drip down and mess things up, also can try tape cut-off method, which will work on many tvs including this model.
                • cozwurth
                  • Apr 2023
                  • 11
                  I wish it was a cleaner that leaked in there... It looked more like some sort of dried soft drink. Dark and sticky. Blech... At any rate, I'll do a bit of research on the tape cut-off method and take a closer look at the panel driver boards. The dark side of the screen had the worst of it.
                  Dave
                  • cozwurth
                    • Apr 2023
                    • 11
                    OK, I was finally able to do a bit more checking on this thing. First, I plugged it in and turned it on to check for the 12 VDC signal at what I think is the main fuse. Maybe it's not a fuse... That's the part I'm pointing to with my test lead in the first pic. I saw 12 volts at the - side as labeled on the board, but not across it. The + side has continuity to the ground plane, which I thought was strange. There are several other similar components that behave the same way. I also checked for voltage at the test points at the lower ribbon cables. Nothing. I did not see any damage to the ribbon cables between the panel and the driver boards. I have not checked for shorts or continuity there yet.
                    I know this is the same make/model TV as the OP, and it has the same symptoms, but should I start a new thread?
                    Dave
                    • lotas
                      • Jan 2016
                      • 4908
                      • Russia
                      #30
                      The fuse here is listed as F1, but what you specify is a protective diode.
                        • 12323
                        • U.S.
                        #31
                        Now you see the fuse in Lotas picture, just test fuse for continuity which is done with tv unplugged from power. Then see if you have about 12 volts on each end of fuse, neg. probe on chassis ground, pos. probe on each end when plugged back in and turned on or if you have the 12 volts on each side then you know the fuse is good and no need for continuity check.
                        • cozwurth
                          • Apr 2023
                          • 11
                          Lotas, thank you. That fuse is tiny... And I see now that the thing I was pointing to is labeled as "D6".
                          nomoresonys, the fuse has good continuity, I checked it before I left for work this morning since it was out. Is there anything else to look at before I put it back in the TV to check for voltage? I should be able to get it back in the TV this evening to do the voltage checks.
                          Dave
                            • 12323
                            • U.S.
                            #33
                            You mean you took the fuse out? no need for that just to test it.
                            • Diah
                              • Feb 2013
                              • 6614
                              from yours photos post #26 of screen and the black spot .. you have burned panel .. i have doubt if you can fix it neither masking will not help.
                                • 12323
                                • U.S.
                                #35
                                I didn't even notice that black spot, I see there's a thin black line running right up the middle of it the length of the screen vertically.
                                • cozwurth
                                  • Apr 2023
                                  • 11
                                  LOL, no, not the fuse itself. I meant the T-con board was out, but I can see where you were on that one.
                                  While I had the board out I used the ohm/diode setting on my multimeter and checked out the three diodes in the area of the fuse.
                                  D6 - 509 ohms with the leads touching correctly, infinite in the other direction.
                                  D10 - 128 ohms & infinite
                                  D3 - 235 ohms & infinite
                                  I put the board back in, plugged the TV back in, turned it on and checked for voltage at the fuse. 12.06V on both sides.
                                  While I was there I checked voltage at the diodes in the vicinity of the fuse. (-) lead on chassis ground.
                                  D6 - 0V on + side, 12V on - side
                                  D10 - 12.7V on +, 15.3 on -
                                  D3 - 15.14V on +, 0V on -
                                  I'm no electronics wizard by any stretch of the imagination, but the voltage reading on D6 looks off to me.
                                  I'll have to pull the panels off the sides to get to the thin driver boards. I did check continuity to ground (unplugged & T-con disconnected) on the few that I could get to and only got a reading on one side. Those few don't seem to be shorted.
                                  I'm thinking that the panel is dead, too, but I'm just guessing. The large dark spot in the screen definitely looks like an issue with the panel, and there are a lot of vertical lines in the screen when I have one of the cables disconnected, so I'm not overly optimistic here. I had never seen the screen lit up until I disconnected one of the cables.
                                  Dave
                                    • 12323
                                    • U.S.
                                    #37
                                    Lol, that cracked me up, I kinda thought you meant you took out the tcon after I thought about it. Don't diodes just let voltage flow in one direction, so maybe D10 has a problem? Zener diodes allow flow in both directions but are usually labeled starting with a Z, pretty sure D10 is not a zener.
                                    • cozwurth
                                      • Apr 2023
                                      • 11
                                      Yeah, I'm def not an expert on this stuff... Yes, diodes are supposed to let voltage flow in one direction only. The confusing thing is that I have 0V on the + side, but 12V on the - side. I'm pretty sure I'm just wizzing in the wind with this thing, but I would like to learn something. I can get a T-con board on the big auction site pretty cheap, but if that's not the problem, or if the screen is also completely blitzed then there is not much sense in replacing it.
                                      Dave
                                        • 12323
                                        • U.S.
                                        #39
                                        I guess there's not much that can be done, I saw some videos on youtube in the recent past where they would rub the screen on the edges of black circles and they would go away, these guys say it's hopeless tho: https://www.youtube.com/watch?v=8YDwiQevzDU
                                          • 12323
                                          • U.S.
                                          #40
                                          Like this: https://www.youtube.com/watch?v=F59mxBCW9Gw
                                          • DXseekerMO
                                            TCL 55US57 backlights, no picture.
                                            by DXseekerMO
                                            So here we go with another screen short TCL. For this exercise left and right will be reference looking at the screen.
                                            The person I got this TV from said the color was bad in a vertical fashion about 1/4 of the way over the left side of the screen. Shortly after the symptoms below started.
                                            Power Supply, main and T-CON board are working.
                                            Symptoms: The TV has backlights but no picture with both FFC's attached to the T-CON and does not respond to the remote or buttons, and the TV appears to continuously re-boot.
                                            Unhook FFC from left side...
                                            09-18-2021, 03:56 PM
                                          • adamp91gvm
                                            hisense 55e76gqtuk seems to be downloading picture from top to bottom with lines
                                            by adamp91gvm
                                            as above shows coloured lines then slowly goes down and repairs the picture on start up if been on for a while then turned off its fine anyone had this...
                                            09-10-2025, 12:13 PM
                                          • sordids999
                                            SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                                            by sordids999
                                            Hi
                                            Really stuck on this TV
                                            I'm thinking it's a bad screen ?
                                            Voltages all seems good
                                            Tcon 12v ok
                                            Remove one tcon cable at a time no half image on the screen just backlight and no picture
                                            even tried the tape trick still no luck
                                            Thanks...
                                            05-12-2025, 10:36 AM
                                          • stinger
                                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                            by stinger
                                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                            04-17-2024, 03:06 PM
                                          • petersor
                                            Hisense 58R6E3 Backlight/No Picture Repaired
                                            by petersor
                                            Quick repair summary for those interested. I had a Hisense 58R6E3 TV that had backlights working but no picture. T-Con had 12V supply but some of the supplies on the board were 0V. Unplugging one of flat cables to the LCD display driver boards brought the supplies back up, so I figured it was a short on the LCD panel driver board. Narrowed the short down to the 15V power supply by checking the coils on the T-Con board to ground with a diode test and confirmed that all the MLCC caps on that rail all showed a short to ground. I injected 5V/1A into the 15V rail on the driver board (T-Con disconnected)...
                                            06-07-2024, 04:16 PM
