Fixed a ViewSonic N3260w
  • Timbot
    • Apr 2013
    Fixing a ViewSonic N3260w w/ later power supply
    I also have a Viewsonic N3260W with a bad power supply that does not have 5v standby. I have read Bud Martin's troubleshooting guide, have the service manual and PS schematic, and have replaced all the caps, one of which apparently exploded. I am beginner/intermediate and have a good DMM.
    My power supply is the FSP228-3F01, not the FSP212-3F01 everyone else seems to have trouble with at Q7 and the zener diode (ZD4), in addition to the same bulging caps everywhere that I have replaced. My Q7 and zener seem fine, as well as the other transistors, although I did not unsolder them from the board. Nothing was shorted there.
    Attached is a schematic showing voltages I was able to measure at various locations off the top of the board while running on 120v AC household supply.
    What are my next troubleshooting steps?
      Re: Fixed a ViewSonic N3260w
      @timbot, are those voltage readings in red are the readings you are getting? Pictures of the your board top and bottom?
      • Timbot
        • Apr 2013
        Budm, yes, those are the voltage readings in red, here are the pics of the board with the new caps. Thanks much!
          OK, we need to fix the 5VSTBY first. Check or replace start-up/running cap C22, C33 (33UF/35V), make sure R65 (5.1 Ohms is OK). Zener Diode ZD4 (15V) is really 15V (I just fixed one last week, the Diode mode test OK but it becomes 10V Zener instead of 15V). You will need variable power supply and a 1K resistor to test the voltage of ZD4.
          • byacey
            • Oct 2013
            • 13
            Sorry to resurrect an old thread, but I have a FSP212-3F01 that turns on, and I get a picture, but I can see the power supply is pulsing dropping out and re-starting over and over causing the picture to flicker. I've replaced all the secondary caps. I tried replacing the primary side caps, although I just had ordinary electrolytics, not the low esr. When I replaced these the back light was flickering, but no video, so I put the old caps back one at a time, and testing the supply after replacing each cap..
            After replacing the 2.2uf, the video came back, but the supply is still pulsing. Any thoughts on this?
            • Toasty
              • Jul 2007
              • 4171
              #26
              Welcome!
              What caps did you use? Brand, series?
              Standby and On voltage readings from PSU? Analog meter is better here than a DMM.
              Voltage across mains cap at standby and on also, please.
              Sounds like a PFC issue.
              1) Use the correct caps on the primary and secondary sides. Low ESR.
              2) Check the values of the large (pink) resistors in the pic in post 23.
              3) On the back side, inspect all SMDs for burn marks or bubbles. A bright light and a jeweler's loupe are recommended. Clean up any flux residue on the SMDs so you can see the markings clearly. Surfaces should be shiny all the way across devices. If you see a clouded line transecting the device, that's a problem.
              4) Check the value and/or replace the large light blue poly cap in the middle of the pic in post 23. It provides the drive to the secondary transformer (to its left).
              5) Check the value of the mains cap. Sub another of matching or higher voltage and value. You can usually just tack-solder another across it. Mind the polarity.
              T
              veritas odium parit
              • byacey
                • Oct 2013
                • 13
                I don't have an analog meter at home, I can pick one up later at the shop and re-measure the fluctuating voltages. All measurements taken with a Fluke 87.
                Standby +5V is good, measures 5.07V and rock steady. R36 measures 74K in circuit, and R67 measures 0.5 ohm in circuit.
                The rectified mains voltage across C1 is 165V @ standby. When switched on, it bounces around between 202V and 293V due to the supply pulsing.
                Similar situation with the 12V supply, bounces between 8.9V and 11.1V.
                The 5V supply is solid when switched on.
                24V supply is pulsing as well, 21V to 23.2V.
                I replaced the secondary filter caps with whatever low ESR caps I could get from Newark:
                1000UF, 35V NICHICON - PW Series - I'm not sure about the ESR on these; I have some suspicions regarding them.
                1500UF, 16V,RUBYCON - ZLH Series
                820UF, 20%, 25V PANASONIC - FM Series
                270UF, 35V Panasonic FR Series
                220UF, 25V, Panasonic FC Series
                What is the recommended series regarding longevity / high temp and low esr?
                I'll find a large electrolytic that I can parallel across C1. I'll also bring home my cap meter and test C16.
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  Yeah, that really sounds like a PFC issue or a weak/failed component in that circuit. It tries to come up and gets shutdown, rinse-repeat.
                  Cart before horse: The bouncing from 202v to 293v is not because of the supply pulsing, its the problem with the start-up/PFC.
                  >>R36 measures 74K in circuit, and R67 measures 0.5 ohm in circuit.<<
                  Are those correct values according to markings?
                  PW's are fine. It's not -always- advisable to get super-low ESR caps for PSU use as they can cause issues also. Middle-low is perfect. I've had FM/FR cause problems where FC & PW have no problem. PW & FC are very close in most specs.
                  Can we get some clear pics of your board? There are likely subtle differences.
                  T
                  veritas odium parit
                  • byacey
                    • Oct 2013
                    • 13
                    R67 is a 0.51 ohm , and R36 is a 75K; well within tolerance.
                    I found a 200uF/450V cap in my bins; I'll try and parallel this across the input filter C1 and see if this makes a difference.
                    • byacey
                      • Oct 2013
                      • 13
                      No go on the mains filter cap; didn't make any difference. I also tested C16, the blue cap that drives the xfrmr, and it measures .0226uf, as it should be.
                      Additionally, I swapped out the 1000uF/35V filter caps that I mentioned before with some low ESR ones I picked up today, but no difference.
                      Looks like I'm going to have to get out the scope and see what IC3 is doing.
                      • byacey
                        • Oct 2013
                        • 13
                        Here's some pics of the board:
                        http://smg.photobucket.com/user/byac...4e62a.jpg.html
                        http://smg.photobucket.com/user/byac...3f239.jpg.html
                        http://smg.photobucket.com/user/byac...2f60f.jpg.html
                        http://smg.photobucket.com/user/byac...6b449.jpg.html
                          Per SCH as post in post21, check the VCC voltage for IC3, check the PFC Diode D7, D8, C34.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            Yeah, those little CapXon's are known problem children. An ESR meter will weed them out. Simpler to just replace them with FC, FM, FR, HE or PW series.
                            I am concerned about C16 as there appears to be a circular fracture on the one end. Understand that those caps are dipped when manufactured. There are no mold or parting lines and that crack indicates an issue.
                            Great top pics, a few of the bottom in that quality would be super!
                            T
                            Note: I adjusted the pics so they are 2000 px wide and attached them here. Photobucket has a nasty habit of deleting pics after a time and it would be a shame to lose them. The next person to come along would have no references to look at. I also have the originals saved personally.
                            veritas odium parit
                            • byacey
                              • Oct 2013
                              • 13
                              Vcc on the PFC chip (IC3) is 11.2V, fluctuating slightly with the pulses.
                              I measure 36mV across R17 for about 3 seconds, and then it drops to about 24mV for a split second, and then climbs back up to 36mV repeatedly.
                              J13 which supplies Vs on pin 12, IC1, has 11.0V, pretty steady.
                              Gate of Q3 is pulsing from .1V to 2.3V
                              J14 (pin 1, IC3) has 1.3 to 1.7V, pulsing.
                              In reading about the PFC, IC1, It requires about 12.3V for the VCC voltage to operate normally. Because this is sitting at 11.2V, just below the threshold, I believe this is the cause of the pulsing. The source for the VCC is via Q7 and ZD4, which should yield about 14.4V on the emitter of Q7 if the zener is 15V. I measure 14.2V across the zener; emitter of Q7 measures at 11.35v, collector has 20.5v, base 14.2.
                              Looks like another case of the 15V supply failure, both the zener and transistor. I'll replace them tomorrow and report back. If I have a 78L15 regulator, I'll put that in, instead of the transistor and zener.
                                if the Zener is 15V, then the output at the Emitter should be about 0.6v less due Vbe drops than the Base voltage (15V). So did you check Q7 and ZD4 which are commonly failed parts. So 14.2 - 0.6 = 13.6V but you are only getting 11.35V, that is not right at all.
                                • byacey
                                  • Oct 2013
                                  • 13
                                  C16 is OK, it must be a reflection you are seeing.
                                  I'll take some bottom pics after I get it running and clean up the flux.
                                  I'll replace the remaining primary side caps, but for now they appear and test OK.
                                  Any recommendations on an ESR meter? I should probably get one if I'm going to be working on these finicky supplies.
                                  • byacey
                                    • Oct 2013
                                    • 13
                                    I did check ZD4, as I mentioned I measured 14.2V across it. As well the transistor is shot, because the base-emitter voltage is way beyond 0.6V.
                                    I didn't bother removing it to test outside of the circuit. I'm confident with the voltage readings that the transistor is finished.
                                      The 78xx needs about 5V min diff (in-out) for good regulation, we only have just about 5V so it will be on the border line, unless you can get LDO version instead.
                                      • byacey
                                        • Oct 2013
                                        • 13
                                        I may have some of the low drop out regs in the bin; I'll have to check. If not, I've got 2N4401 transistors and 1W zeners.
                                        I just the thought the reg would be a more elegant solution.
                                          I would have thought so, but it comes down to which one is cheaper.
