Fixed a ViewSonic N3260w
  • Pableros
    • Mar 2015
    • España
    #121
    Re: Fixed a ViewSonic N3260w
    Hello again
    Need help with a ViewSonic 3260w
    The scheme does not come values zd zd 1 and 3
    Please ZD-1 and 3
    Thank You
    • Keshetisrael
      Tech-N-Training
      • 72
      Originally posted by budm
      OK, we need to fix the 5VSTBY first. Check or replace start-up/running cap C22, C33 (33UF/35V), make sure R65 (5.1 Ohms is OK). Zener Diode ZD4 (15V) is really 15V (I just fixed one last week, the Diode mode test OK but it becomes 10V Zener instead of 15V). You will need variable power supply and a 1K resistor to test the voltage of ZD4.
      Question on this.. wherein you see on the corners of this power supply.. the metal around the two mounting holes that have them, do you just ground these out, and turn the board over onto say.. an anti-static matt; in order to test the Zener w/ the VPS attached to the 1k resistor?
        To use Variable power supply to test the Zener diode, you will have to remove the Zenner off the circuit board.
        Before taking the Zener off the board, you should verify the DCV between the two legs of the Zener when you power up the board, just put the board on insulated sheet first. You will be working in the HOT DEADLY side of the circuit so you should power up the board through GFCI outlets.
        Example of how to test the Zener using power source, in your case it will have to be 18V or more power source.
        http://www.elexp.com/electrical_meas...ts_part_3.aspx
        http://www.tpub.com/celec/47.htm
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
