Sony KD65X85005C, no boot, hdmi IC suspected
  • Formaster
    • Jul 2021
    • 68
    • Switzerland
    Hi guys,
    This android TV show up the Sony the logo, than black picture, not turn off, but also no reaction for remote or buttons. First suspected a corrupted FW, but found some short around the hdmi IC.
    With upgrade drive show the update pictogram for few min's, after Sony logo again and black pic. The picture below show the short's and found a datasheet from the IC.
    I would be grateful for any help
  • William1967
    • Nov 2017
    • 203
    • Netherlands
    Re: Sony KD65X85005C, no boot, hdmi IC suspected
    What do you measure exact? I suspect you are measuring a very low resistance but that doesn't mean it's not good because you're measuring in the circuit.
    I think you better take a look at the EMMC, these models are known for EMMC problems.
    • Formaster
      • Jul 2021
      • 68
      • Switzerland
      Didn't found any schematic to check, measured around 30, the neighbours 3-400. I know the EMMC by these models, but how can i check if corrupted?
      • CapLeaker
        Leaking Member
        • 8096
        copy the content off the EMMC and save it. FF the EMMC and do a blank check. If the blank check is o.k. it should be all right. Copy the content back to the EMMC and off you go.
        • mmartell
          • Oct 2013
          • 3189
          If that ic is shorted it would likely be getting HOT. Check the area for heat.
          • William1967
            • Nov 2017
            • 203
            • Netherlands
            You can't check that, the EMMC in this model is a Hynix and I've seen a lot of those which I wanted to reprogramme , after the EMMC was programmed I got a message that the EMMC has reached it's "End of Life"
            • Formaster
              • Jul 2021
              • 68
              • Switzerland
              Thx, i checked, can't say it is hot but definitely warm.
              I ordered a new Hynix nand. Need to dump the old, or just replace the nand with empty new and insert a Sony FW loader from usb?
              • William1967
                • Nov 2017
                • 203
                • Netherlands
                [QUOTE=Formaster;1060936
                I ordered a new Hynix nand. Need to dump the old, or just replace the nand with empty new and insert a Sony FW loader from usb?[/QUOTE]
                The old software is useless, you need to get working software , an empty EMMC will never work. The firmware you can find at the Sony website is not the same and will not work either.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4291
                  • Italy - Milan
                  measured around 30
                  30 what? Gallons? Always put measure units..
                  i guess software problem , repairable until the operator can break protection mechanisms, a good hacker is suitable.., i don't know the final bill how much, mabye better find repl. board...
                  • Formaster
                    • Jul 2021
                    • 68
                    • Switzerland
                    Today arrived my hot air gun, removed the chipset and the short is gone around. Ordered a new one just in case, hope only that caused the problem.
                    I know these modells know as ROM problem, but nearly always with boot loop. My shows only the Sony logo, after no picture and hope it was this caused.
                    Here is the pins of the processor on Page 40. Can be tested pins for short?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4291
                      • Italy - Milan
                      In other brands there are tv that shows logo then after some time shuts down in standby. The shut down is due to the watchdog that senses the main software running problem...
                      • Formaster
                        • Jul 2021
                        • 68
                        • Switzerland
                        In this case the tv gone not to standby. Looks like its freezed before system boot. Its not a bootloop or shutdown. But i need long wait for arrive a chipset proc, thats while wanted to test the pins on this suspected one.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4291
                          • Italy - Milan
                          Tell us what you mean for the short gone.. for that symptom it is suspectable also bad soldering on cpu, not short. Furtherly, maybe not always watchdog is enabled, when this, main program can go back to system with an error in shell and stay there, the correct and only way to diagnose is the boot log view trough a PC, and is also easy most of the times..
                          • Formaster
                            • Jul 2021
                            • 68
                            • Switzerland
                            There was a lot capacitors around the chipset processor shorted to ground. After takoff the hdmi chipset did'nt found a shorted cap.
                            The bootlog is on the emmc? I have no bga flasher and don't know what is the jtag points on the motherboard.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4291
                              • Italy - Milan
                              When William asked you the measures you don't replied clearly, if you was meaning 30->400 ohm then those are not shorts. Believe me, you have faulty software , the bootlog is a text sent by the tv over the serial port , that is hidden inside main board on a not populated connector or the vga/hdmi connector.. if you are not familiar with theese, then leave alone this board and buy a cheaper one..
                              • Formaster
                                • Jul 2021
                                • 68
                                • Switzerland
                                (meaned in ohm, not kOhm or mOhm, just 30Ohm)
                                • Formaster
                                  • Jul 2021
                                  • 68
                                  • Switzerland
                                  just try to learn something in freetime as hobby. I did it before xbox jtags and a lot other thing, but hard to find any infos, if don't know where.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4291
                                    • Italy - Milan
                                    But.. if you trust me, this is a software issue and with these Sony i don't know the exact procedure to fix it, maybe you can start a search in the forum for a succesful reload by a simple usb key, not the hard way with expensive eprom programmers.. The way i prefer is by linux shell but if them are commonly shell protected i'm not a linux guru...
                                    For instance here is Android but shell is unix similar, if you want at least see the log you must own a low volt serial port adqpter, like the ones in RT809 / CH341A programmers
                                    • William1967
                                      • Nov 2017
                                      • 203
                                      • Netherlands
                                      30 Ohms is normal and does not mean there is a S.C., the problem when measuring a part is the circuit it's in, if that is a low ohmic circuit you always measure a very low resistance.
                                      • Formaster
                                        • Jul 2021
                                        • 68
                                        • Switzerland
                                        Thanks! First the USB recovery method found it, show the picture in attachment, run it few minutes, than 2 times show the Sony logo and nothing, but won't turn off itself .
                                        For lucky i have one of this serial port adapter. Any suggest how to connect? I would like to thank you.
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • Ihandyrepair
                                          4 red flash led 65X950G boot Sony and android logo but then black
                                          by Ihandyrepair
                                          HI guys
                                          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                          here is the issue
                                          I have Sony and android logo. but then 4 led red flash lights front of the tv
                                          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                          but then I get black screen and 4 red flash light at the front LED
                                          but I get 3 led flash on the LED driver board.
                                          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                          so I tried...
                                          07-11-2024, 01:45 AM
                                        • BubbaW
                                          Sony KDL 55HX800 Lightning-HDMI's bad
                                          by BubbaW
                                          Last week our home was hit hard by lightning, so much so that 4 transformers on our street were blown out.
                                          Items lost....DirecTV box, Cable TV box and initially Sony 55"....all inputs hooked up via HDMI. We have since purchased new set but wanted to at least try and see if this TV can be fixed.
                                          Initially while T/S, found all inputs fine except T-Con_ON = 0VDC
                                          but front panel had 3 red blinks. Yesterday took Pwr Supply and Main Board out to check for any noticeable failures. Coincident or not, after replacing both boards the TV started working fine...
                                          08-21-2022, 08:14 AM
