Can Anyone Identify the Value of This Component ?
  • mmartell
    • Oct 2013
    • 3189
    Filter at L1 appears marked with the letter H anyone know what that means ? From an Amazon Fire stick remote control. The remote was burning through batteries at an alarming rate I may have popped the filter on disassembly don't know. Also missing a small resistor above it with unknown value but first things first ...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Can Anyone Identify the Value of This Component ?
    Lx is normally the suffix for an inductor.
    • mmartell
      • Oct 2013
      • 3189
      Okay what is the value of an inductor marked with the letter H ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        No idea. I suspect a search of the internet may come up wiith an answer. Have you a suitable meter to measure it's inductance?
        Can you post a clearer close shot of the smd device. I see several smd fuses online with H on the package
        • jkb242
          • Mar 2012
          • 175
          Agreed the picture is way too small.
          • mon2
            • Dec 2019
            • 14677
            Share the markings of the smd ic next to this inductor.
            It appears to be a local buck switching regulator. The ic could help to identify the value for this part.
            • mmartell
              • Oct 2013
              • 3189
              As stated in the first post I do not have the inductor it is missing on my board. The pic is a frame from a youtube video.
              • mmartell
                • Oct 2013
                • 3189
                Yes this is a good idea though I will say I've looked it up and found nothing but if you can please let me know.
                Marking is 4FN5R
                • R_J
                  • 9607
                  Is it the sot23-5 next to the inductor? My first guess is a Torex XC9140A
                  • jkb242
                    • Mar 2012
                    • 175
                    It’s quit likely not that critical but given the relative indicated size, (determined by wire size used to make the inductor and the designed current anticipated) replacement could be
                    2-3 μh SMT like a TDK SPM3010-LR or a TMS252012ALM depending on the actual dimension of the pads which were not provided.
                    • mmartell
                      • Oct 2013
                      • 3189
                      I've replaced the inductor with one of appropriate size and hopefully value (no marking) harvested from an old iphone board. Now, I am missing a resistor going to the chip enable pin which must be high to be active. The 3v supply is there. I think the resistor is for current limiting ? What value is suggested for the resistor ?
                      • mmartell
                        • Oct 2013
                        • 3189
                        33 ohms ? 100 ohms ? Is the value critical for this circuit ?
                        • madan1
                          Modding HPF filter
                          by madan1
                          Hi everyone.
                          Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
                          Most likely I will use a 15" JBL woofer, which I already have and a diy box.
                          After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....
                          09-24-2025, 02:06 PM
                        • Agent24
                          Dick Smith Q-1760 linear power supply filter capacitor question
                          by Agent24
                          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                          It has at least one problem.
                          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                          I have already ordered a replacement potentiometer, so that's not an issue.
                          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                          All are CapXon...
                          10-21-2025, 05:39 PM
                        • thesame
                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                          by thesame
                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                          02-27-2024, 04:31 AM
                        • silver60618
                          Lenovo Legion 7 - Help Identify IC
                          by silver60618
                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                          Any help would be appreciated...
                          07-02-2025, 12:16 PM
                        • chth96
                          How can I identify varistor which have been blew up?
                          by chth96
                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                          So It seems that glass fuse and varistor have been blew up.
                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                          Is there any way to identify varistor type in my sega saturn PSU?
                          Any reply would be appreciated.
                          EDIT:
                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                          11-26-2023, 08:52 AM
