46pfl9707 : TCON replacement Region specific or anything?
  • spartantravis
    • Nov 2019
    • 17
    • Italy
    Hi guys
    I ran into some trouble with my Phillips 46PFL9707 TV and isolated the problem down to the TCON board. I eventually saved up enough money to buy a replacement one from ICCFL.com but when it arrived and I inserted it, all I got was a black screen when I switched on the TV. Even the old broken one produced some type of screen distortions when it was there.
    Both of the TCON boards are CPWBK 4920TP RUNTK and look identical but they have a slightly different code written on them (ZE 118A127 is written on the old one) while the new one has ZH -something written in the same spot.
    I wanted to ask, if this is some type of region code that means the board does not work in European TVs or something?
  • lotas
    • Jan 2016
    • 4580
    • Russia
    Re: 46pfl9707 : TCON replacement Region specific or anything?
    Hello, maybe the new T-CON has been registered under a different display, try to put your display code.
    • William1967
      • Nov 2017
      • 203
      • Netherlands
      Why change a t-con when in 99% only the resonator has to be changed...
      • spartantravis
        • Nov 2019
        • 17
        • Italy
        Yeah I am not 100% sure anymore if the issue is with the TCON board. Now the old board does not work anymore.
        The problem with the resonator is that I cannot remove it or dont know where to buy them online. Shame really? I am just down the road from you in Maastricht
        • spartantravis
          • Nov 2019
          • 17
          • Italy
          Yes I tried this as you suggested. The tv shows no response. I think the issue may not be with the TCON board.
          When I disconnected the LVDS cables from the new board and reconnected them to the old one, the issue I could no longer reproduce the old artifact/garbled screen. The screen appeared black with only the ambient backlight appearing at the points of the screen where the logo and menu options would appear. The TCON board appears to not be connected at all now.
          How fragile are the LVDS cables? And how are they removed on the TV? I had to use considerable force to get them out of the TCON board
          • diif
            • Feb 2014
            • 6978
            • England
            There should be no force involved, lift the flap and they should come out easily, inspect the ends for damage.
            • spartantravis
              • Nov 2019
              • 17
              • Italy
              Ah, these are not the flap variety where you lift it up to pull out the tab (first photo). I have never seen these ones before (photo 2 + 3). There is no obvious way to remove the cable besides force. I think it is likely I damaged them when remove them. I tried to unhook the black thing but I dont see how.
              • lotas
                • Jan 2016
                • 4580
                • Russia
                Usually you need to press the latches on both sides and pull
                • spartantravis
                  • Nov 2019
                  • 17
                  • Italy
                  There are no latches on this one. It almost looks like it is clipped in like Ipods are
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    the black part pulls part way out by the looks of it.
                    • lotas
                      • Jan 2016
                      • 4580
                      • Russia
                      And it is not necessary to change the resonator, it is enough to solder it carefully, the adjacent choke gets very hot and the soldering of this resonator degrades
                      • William1967
                        • Nov 2017
                        • 203
                        • Netherlands
                        It looks like a faulty LVDS cable, there must be nodges like in the attached picture. In the second picture you can see two small buttons you must press in to release the cable, without those buttons you can only pull out the cable which will be damaged like the third picture, changing the cable will solve the problem.
                        • spartantravis
                          • Nov 2019
                          • 17
                          • Italy
                          After 2 hours of poking around, I finally figured it out. The holes on each side of where the cable fits in have springs in them. I had to insert a small metal rod to get them to loosen the black part....
                          Now I need to find new lvds cables as I likely torn the other ones
                          • spartantravis
                            • Nov 2019
                            • 17
                            • Italy
                            Ahhh they were missing from my old TCON board, likely because I broke them off when I had to repair the board a few years ago. I figure now that is why the new TCON board does not work.. thanks
                            • spartantravis
                              • Nov 2019
                              • 17
                              • Italy
                              okay. Turns out one of the pins on the cable was bent enough to stop it from working. I tried to trim the cable and check the voltages across one of the boards outputs to see if the cable was working. I shorted something, heard a noise and now the TV has power but will not switch on.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4318
                                • Italy - Milan
                                It's very sad to see a wonderful tv handled so bad by a not technician, i don't know the original fault, you don't explained, if it was like mine, good image until start logo then artifacts and shutdown, then the solution is a faulty 1,8v regulator on the FRC board...
                                • Nikan.e
                                  How to program a specific flash region of a Nations N32G455RE MCU?
                                  by Nikan.e
                                  Greetings and salutations!
                                  I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
                                  How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
                                  I do not have a J-Link debugger and won't buy one, as I am not rich.
                                  I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
                                  What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
                                  05-23-2024, 11:51 PM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
                                • Hakuu
                                  by Hakuu
                                  Hi There,
                                  More Details
                                  TV Model - LG OLED77G1PUA
                                  07-12-2023, 02:37 PM
                                • tom3k
                                  Dell Precision 5540. Need clean ME Region
                                  by tom3k
                                  Laptop: Dell Precision 5540
                                  MB: LA-H331P Rev: 1.0(A00)
                                  Hi.
                                  I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                                  After extracting my BIOS in FIT the ME Region size is 7565 KB.
                                  However the ME Region files I fouud online are 11688 KB in size.
                                  Can someone help me find he correct clean ME Region?
                                  Thanks!
                                  Code:
                                  ║ Family │ CSE ME ║
                                  06-28-2025, 12:34 PM
