How to program a specific flash region of a Nations N32G455RE MCU?
  • Nikan.e
    • Nov 2023
    • 20
    Greetings and salutations!
    I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
    How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
    I do not have a J-Link debugger and won't buy one, as I am not rich.
    I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
    What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?
    I have multiple boards and programmers on hand:
    picKit 4
    NUCLEO-C031C6
    RTK9FPG021S00001BJ
    nRF52840-DK
    FRDM-MCXN947
    Any advice is welcome!
    Thanks in advance and Best Regards!
  • piernov
    • Jan 2016
    • 4438
    • France
    This looks extremely similar to an STM32 MCU, maybe even just a clone, there are multiple options to interact with it: USB (in bootloader mode with dfu-util), UART (in bootloader mode with stm32flash), SWD (maybe with STM32CubeProg or OpenOCD using an ST-Link), JTAG (possibly with OpenOCD using some sort of JTAG probe, FT2232 could be enough).
    Of course always take a full backup before doing anything.
    • Nikan.e
      • Nov 2023
      • 20
      You are right, It seems to be a clone. By choosing the STM32G431RB MCU in J-Flash, I was able to dump the entire 512KB of flash from the working and not-working Nations chip. Unfortunately, it is not possible to flash the chip that way; an error always occurs, but it does not specifically indicate the type of error. It is unclear if this is due to the difference in internal flash sizes of the chips or if there is an ID mismatch, etc.
      I will try the STM32CubeProg. Is there a settings file of supported chips if something has to be changed for the Nations chip to work?
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • JayZee
        Samsung Odyssey G9 C49G95TSSR / BN94-17725A – full SPI flash dump needed (M-T9549GGAA / T9549)
        by JayZee
        I am trying to repair a Samsung Odyssey G9 49" monitor and I suspect corrupted firmware / NVM data or a bad SPI flash.
        Monitor details:
        Model: Samsung Odyssey G9
        Model: C49G95TSSR
        Model code: LC49G95TSSRXEN
        Type No.: C49G95TSS
        Version No.: CA02
        Mainboard: BN94-17725A
        PCB: BN41-02843B
        Firmware/platform marking: M-T9549GGAA-1017.0
        Official Samsung USB update available: M-T9549GGAA-1020.0
        Scaler/platform: Novatek NT68500 / T9549
        SPI flash: Winbond 25Q40CLSIP (if it is the right chip)...
        05-15-2026, 04:16 AM
      • Martisolutions
        BIOS/ME Region Help - ASUS F556UJ (Motherboard X556UJ_MB REV 2.0) - Hangs at 0.33A - RAM Communication Error
        by Martisolutions
        I am requesting help with a BIOS/ME Region issue on an ASUS laptop. I have followed the "BIOS guides, methods, resources and tools" provided in the forum, specifically trying to clean the ME Region and updating the BIOS region to version 413, but I haven't been able to succeed, i've tried to download a the same ME Region v11.0.0.1180_COR_LP_C_NPDM_PRD_RGN.bin but not able to fit it since it is bigger than the actual size from the ME region of my chip.
        System Details:
        • Make: ASUS
        • Full Model: F556UJ-XO015T (Mainboard X556UJ_MB REV 2.0)
        • Serial
        04-28-2026, 10:13 AM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
