Re: Removing large LCD panels
2 suction cups and put to the side of chassis - my bench is long enough for that. Before cups I had large piece if cardboard, Id lift a corner and slide the cardboard in.
https://www.youtube.com/watch?v=_-cKfX3WmSM
In this video we can see a chinese assembly factory of LCD TV. At minute 10:00 there's a contradictory view: first, a worker grabs a large LCD cell by hand and places it over a light table for testing, and after that, a machine with about 12 computer controlled small suction cups moves the cell over a pre-mounted backlight. Before that, it rotates 90 degrees to let a worker peel a protective sheet.
In attached picture we can see a cheap chinese tool with simple suction cups. Anyone uses this?Leave a comment:
I use the big double suction cup technique . Sometimes you will get like a circle mark on the screen if it has been on the for a long time, but it goes away in a short time. I always clean the sdie of diffusor that points to the leds , because it is known there for dust to settle. Also when putting back the screen , check for fitment on every corner , make sure the plastic saddle is clipped all the way around , and then you can put the bezzle on the screen. Pretty straight forward , i made a video showing the full process with some advices here and there , but i still havent posted it. Also i would prefer to have an air compressor nearby or some elctrical blower to clean before putting back the screen.Leave a comment:
has anyone tried this method? The guy in the video uses duct tape to lift the panel. I want to change the LED strips on my 48" TV, but I don't have suction cups, and lifting the panel with my hands from below, like pizza, makes me very nervous.
https://youtu.be/pUIKa7QSEO8?t=264Leave a comment:
I work by myself also with no help. And only broken screen with suction cups that failed.
Personally I don’t work on anything smaller than 50” as there’s just no money to be made for me.
Every screen is different. Some have no bezel and are glued. Some lift right out.
You just have to figure out what works best for you and what you’re comfortable with.Leave a comment:
I thought that my method of disassembling the panel with LCD screen looking down laying on the table was safe, until today. It’s very safe for disassembling, but reassembly can be catastrophic, because you don’t see how the LCD glass aligns with the backlight chassis guides. This is what has happened to a Samsung UE48JU6060K with a LSF480FN05-K04 LCD cell (attached image). When reassembling the TV, the glass was trapped by the black guide and cracked when pressed against the front bezel. Now that side of the screen is darker and has motion artifacts.
So now I face either to stop repairing anything that implies opening panels larger than 40" (which basically means leaving the business), or either to find another way to disassemble/reassemble them.
Suction cups seem to be risky and can produce mura effect or even break the glass due to excess of force. What do they use at factories to assemble the TVs? I guess that they use suction cups connected to a vacuum pump with controlled pressure.
What about a set of smaller and simpler suction cups attached to a structure?
I’m only interested in solutions that can be performed by a single person, because I work alone and nobody can help me. I’ve already ruled out TVs larger than 55", because I can understand that a single person cannot safely lift a 65" glass.Last edited by Chungalin; 01-07-2023, 02:46 PM.Leave a comment:
[QUOTE=KYBOSH;1193819]When you say you use your hands do you mean you lift it and grip it vertically (like a suitcase) or horizontally (like you would carry an extra extra large pizza)?
Both. Smaller screens up to 65” I can do like a “pizza” as you say. 75-86” I stand vertically and let them kinda fall out as I hold them.Leave a comment:
I have found that misting the screen with a little spray bottle before applying the suction cups help a lot. I also use the smaller cheaper suction cups. The quality gives the sweet spot for applying to screens. Too cheap to have a strong bond/suction that would damage the screen but just strong enough to stay attached with the aid of water and a clean surface. I got mine from Harbor Freight.Leave a comment:
I always use my hands and never broke a panel. I’ve done everything from 32” up to 86” LGs this way.
I broke 2 panels with suction cups and never again.
Just my 2 cents.Leave a comment:
I have jsed stav242's wooden brace method along with suction cups on several occasions each. Both have had instances where my heart skipped a beat when something was about to go wrong. Suction cups slip and or come off mid-lift. Wooden braces brush against delicate wires or film which protrude from the glass they are trying to support.
I like the looks of the back of the couch method thoughLeave a comment:
I've made a wooden brace which ican adjust to fit the glass panel size , them use some decent blue tape (like decorators use) to stick this to the glass. Then can lift the panel fully supported off and stand on its edge. The wood brace is holding it off the surface slightly. Works well. Can swap the panel out quite easily.Leave a comment:
I haven't had that problem but watched Nick's video where he said suction marks would clear up. The spots are probably on diffusers.Leave a comment:
Despite long inactivity in the thread, and not a answer to any of the previous posts, Im posting a similar problem that I recently experienced.
After replacing all backlights on a Samsung 55" UE55JU6875, I got blue marks and som blue dots in dark pictures, see attached picture. This is only visibel in dark pictures. Used suctioncups to lift of the screen, so the bowmarks is caused by this, but not the dots. Anyone have explanation on what causing this?Leave a comment:
After replacing all backlights on a Samsung 55" UE55JU6875, I got blue marks and som blue dots in dark pictures, see attached picture. This is only visibel in dark pictures. Used suctioncups to lift of the screen, so the bowmarks is caused by this, but not the dots. Anyone have explanation on what causing this?Last edited by dagav; 09-12-2022, 06:36 AM.Leave a comment:
I recently got some suction cups that are meant for lifting TV panels and the first 2 TVs I used them on they worked perfect, although I did feel that the suction appeared to be very strong. Nonetheless, since it worked I used them on the next TV. Worked fine, but when I finished fixing the backlights and picked up the panel, there was a slight crack sound. I inspected the TV and saw nothing, so I continued assembling it. When I turned it on, sure enough one of the suction cups cracked a circle on the panel... maybe the suction is too strong, maybe I lifted it too fast, I don't know.Leave a comment:
One thing to add - resist the temptation of setting a panel directly on any form of carpet. It will attract stray fibers and lint like a magnet. Set the panel on a clean cotton towel and set the diffusers also on the towel in front of the panel (they are "attractive", too). Also, do not touch the panel or the diffusers with an unprotected hand. The oils in you hand will leave a mark that will have to be cleaned off. Wear a pair of cotton gloves, or even put a pair of cotton socks over your hand when you handle the panel.Leave a comment:
by NolesFanI have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you06-23-2025, 09:19 AM
I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....01-13-2024, 01:57 PM -
by HelikvarNo picture ,tv appears to turn on and off using remote as standby led goes from red to nothing when on and red again when off
. Backlights also light up when tv is powered on.
Removing panel ribbon cable from left side screen still dark.
Removing panel ribbon cable from right side the right panel is white and left panel is dark but within a few seconds the left panel has a large green vertical bar and beside it many thin red lines.This whole screen dims down to dark within a few seconds and the right side slowly turns white again.
. Tcon gets 12 volt
. Tried taping...8 Photos -
I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
...11 Photos -
by KYBOSHI came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
Later I checked for shorts on the panel PCB boards but could not find anything.
When I took a look with the FLIR i noticed the 2 resistors...08-10-2024, 08:39 AM - Loading...
