Westinghouse LD-4285 stuck in stanby, short on mainboard?
  • Ifixstuff9
    • Jul 2017
    • 120
    When the TV is plugged in the red standby LED comes on and nothing else... it won't respond to any of the buttons. I don't get any other signs of life from the TV.
    I know that a few similar Westinghouse models had an issue where the backlight ribbon cables would short out against the LCD frame, but I have tried turning it on with the backlight ribbons disconnected and nothing changes. I also partially disassembled the panel to inspect the ribbons and they look fine, I even added some electrical tape to insulate them from the frame just to be safe.
    This TV has just one board that handles everything, and power comes from an external 19v supply. I don't know much about board level repairs but I started by checking voltage regulators - only 3 of them had power, a MP2403DN and two 1117's. Here are the voltages:
    MP2403DN (circled in red)
    pin 1 = 9.8v
    pin 2 = 19.46v
    pin 3 = 5v
    pin 4 = GND
    pin 5 = 800mv
    pin 6 = 1v
    pin 7 = 7.6v
    pin 8 = 3.6v
    1117 (circled in green)
    pin 1 = 444mv
    pin 2 = 1.83v - fluctuates between 1.45 and 1.53 after about a minute
    pin 3 = 4.9v
    1117 (circled in blue)
    pin 1 = 169mv
    pin 2 = 292mv - shorted to ground
    pin 3 = 4.93v
    Looks like something is shorting out the last 1117. Not sure why the other 1117 starts off at 1.81v and then lowers to around 1.5v. Also, the main processor is hot to the touch and the tuner module is warm as well, I may be wrong but I don't think either of those should be warm when the set is in standby... at this point I'm not really sure what to do next. Are there any components that I should check for shorts?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Westinghouse LD-4285 stuck in stanby, short on mainboard?
    Can you lift the regulator (blue) and check if pad 2 is still shorted to ground?
    • Diah
      • Feb 2013
      • 6554
      you need first to clean the boards complete with air pressure. and tell what are the label of U13. its sound the set at half boot.
        • 12328
        • U.S.
        Maybe try cooling or heating U13, power up see if there's any change, could also try heating the capacitors on the board with a hairdryer, see if there's any change, U13 there if it turns out to be the issue: https://www.ebay.com/itm/36332330489...cAAOSwefBgT0b1
        • Ifixstuff9
          • Jul 2017
          • 120
          Sorry for the delay, I finally got another chance to look at the board. I was able to remove the blue regulator and pad 2 is still shorted to ground. I also tried freezing U13, no change. Will try heating both U13 and the capacitors with a hairdryer later tonight and see if anything changes.
          I also attached a pic of the label on U13 for Diah
            The Blue regulator is the adjustable regulator IC, there should be filter caps connected to pin 2 of the IC, one will be MLCC (Multilayer Ceramic CAP) type connected in parallel with lytics type cap, so the short can be from shorted out MLCC or shorted load.
            BTW, when you say shorts, how many Ohms is it? <1 Ohms?
            • Ifixstuff9
              • Jul 2017
              • 120
              The short I'm measuring is <1 ohms at about 0.56 ohms. Is the MLCC one of the three circled caps connected to the output of the blue regulator? I'm going to try removing all three and seeing if that changes anything
              • RJARRRPCGP
                • Jul 2004
                • 6304
                That's starkly familiar, expect it was a blue standby LED, with a TV that reportedly had a failure during a power problem, probably because of a nor'easter in eastern-Massachusetts.
                It got brought up to Vermont and that's the type of symptoms I saw, (back in 2013, IIRC) then it got abandoned. (I wasn't even close to knowing how to possibly fix it, IMHO)
                Looks like it will be known as "The Westinghouse nothing-except-for-standby-LED-syndrome". (IIRC, the brand was Westinghouse.)
                https://www.badcaps.net/forum/showthread.php?t=42335
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • duwane
                  MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                  by duwane
                  Hi All.
                  I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                  Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                  After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                  Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                  10-17-2023, 07:48 PM
                • DynaxSC
                  Extreme High Current & Low Voltage Short Killer ??
                  by DynaxSC
                  Hi Folks
                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                  After taking off the socket, the shorts dissappear again.
                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                  10-15-2024, 10:13 AM
                • Stunt
                  Hp Laptop Stuck on Hp protected by hp sure start screen
                  by Stunt
                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                  screen that's it and stuck there. I left it until the following day and i still...
                  09-02-2025, 01:51 PM
                • Stephen
                  MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                  by Stephen
                  I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                  02-06-2025, 12:03 PM
                • adelfr2009
                  HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                  by adelfr2009
                  I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                  After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                  09-28-2025, 10:21 PM
