Vizio M502i B1 - Missing all power except 5v
  • budhanes
    • Feb 2021
    • 9
    Been working on a few televisions for awhile now, and thanks to everyone who posts. Learning so much! Anyways, working on Vizio M502i B1 power supply board with no voltages on CN9101 except for the 5v at pin 15 and 16. Traced it all down and I have an IC9301 that is a A6069H chip. As per the data sheet, this chip needs 13.8 - 15.3 volts to "start up". I only have 12.8 volts? I have attached a pic that was posted here 9/27/206 by Bud M. It shows the same board I am working on. Any ideas why the required 13.8 - 15.3 volts on my board is only 12.8 volts? This is tested with power supply forced on with a 1k resistor. Thanks!
  • handsworth
    • Oct 2015
    • 174
    Re: Vizio M502i B1 - Missing all power except 5v
    First of all, I'm not a technician so that diagram is foreign to me. I've done that Vizio series many times and found that the main board was always at fault. Is your mb good? Bad eprom causes tv not to come on, but ps and backlights are good. Just an idea since I'm 1st to reply
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      What's your power supply board number?
      • budhanes
        • Feb 2021
        • 9
        (X)ADTVD3613XA7 1502
        ESP35000X 2943193 A 0353
        From the white sticker.
        Seems if I let is sit for a day or two and apply power, I will get the 12 volts for a short moment, but goes away. I have tried freezing components with canned air, heating with a blow dryer, etc. Seems not temperature related, but time related??? I discharged all caps and applied power several times to see if it was just the caps draining overnight. Driving me crazy, but gives me a chance to put my new isolation transformer to good use! I know for a fact that in 24 hours when I apply power it will work momentarily yet again.
        • R_J
          • 9548
          IC9301 IS the standby ic, so that is not where the problem is. Check the voltage on one of the main filter caps, C9811 or C9812. The voltage in STANDBY, should be around 160vdc, When you force the power supply ON it should go to 385vdc, This tests the pfc circuit. The main ic that develops the +12v & +24v is ic9101
          If the voltage on the collector of Q9101 is low, Replace C9305 and maybe C9805 & C9122 as well
          • budhanes
            • Feb 2021
            • 9
            Thanks. When I force the supply on, I do get the 385 vdc. I did replace C9305 when testing the caps previously. I'll text the IC9101 tomorrow and post my results. I did order this ic from "SJ" (not sure if allowed to promote) and should be here Friday. Thanks for the reply.
            • R_J
              • 9548
              If the problem is intermittent, I doubt it will be an ic. (we use SJ pictures all the time so it's not a problem that I am aware of) Like I said, if you don't have the pfc boosted voltage, you likely will not have the main ic voltage.
              IC9101 should be a LCS703LG-TL
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Can you post a photo of your power supply board?
                RJ do you know the model number of the psu?
                • budhanes
                  • Feb 2021
                  • 9
                  I do have boosted voltage. I was thinking the same thing about it working intermittent, why I suspected the caps, and even tried cooling and heating the board.
                  This is the board I have. (From internet)
                  • budhanes
                    • Feb 2021
                    • 9
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      The board number is 715G6100-P04-003
                        • 12208
                        • U.S.
                        What exactly are all the voltages on CN9102 when you force on the powerboard with the resistor and are they steady? Remember that's with the cable unplugged.
                        • R_J
                          • 9548
                          The pfc circuit is working so I suspect the VCC is ok, but check the voltage on Q9101 emitter, it should be about 16vdc.
                          The power supply does have OVP (Over Voltage Protection) on the +12 & +24 volt supplies, I am starting to think it might be a backlight issue on this tv?
                          • budhanes
                            • Feb 2021
                            • 9
                            Well, update, I replaced IC9101 and IC9301 and "popped" R9311 and 9312. The same as this guy did... I double and triple checked chips installed correctly with no solder bridges. Chips from reputable supplier. (SJ)
                            https://www.badcaps.net/forum/showth...t=r9311&page=4
                            They appear to be 1R2, or 1.2 ohms.
                            So now, the backstory on this set, which I am thinking about. A neighbour gave me the set, said one day, a breaker popped in circuit panel, and he reset the breaker, but the tv didn't work anytime after. So, he bought a new tv, and put this in storage. One day, he said, he plugged it on to see if it would work, he got the Vizio logo and it went back off and wouldn't come back on. (I seen the same when testing the supply, The first time after 24 hours of being unplugged, would supply all voltage). So, I am wondering if whatever blew in the tv took out itself and one of the ic's, thus, when I replaced the ic's, I still had a short somewhere and blew R9311 and R9312???
                            Wonder why the guy in the above mentioned post experiences the same thing???
                            Just thinking out loud.
                            • R_J
                              • 9548
                              Why would you replace ic9301 ? This is the standby ic which WAS working. If you blew R9311 & R9312 you either did something wrong or the ic was bad. (the resistors are 1.2Ω) The resistors are in the source of the internal mosfet, so IT will have shorted (pin 1 to pin 7,8)
                              • csmith
                                Vizio D50u-D1 Powers up no picture
                                by csmith
                                I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                issue. Set will power up with remote but not power off....
                                07-11-2025, 11:52 AM
                              • ein_individuum
                                Missing Capacitator Intel I9-12900KF CPU
                                by ein_individuum
                                I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                08-06-2025, 01:36 AM
                              • ugamazing
                                820-02020 PPBUS_AON missing
                                by ugamazing
                                Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                02-05-2025, 04:21 PM
                              • jpreza
                                Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                by jpreza
                                I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                Looking at the card, it appears to be missing the following:
                                1x 1.0uH inductor - orange square
                                2x...
                                11-01-2024, 10:54 PM
                              • gurj1979
                                Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                by gurj1979
                                Hey guys.
                                Need help with this one.
                                Fan not spinning due to missing PWN Fan signal.
                                Also 5 seconds from powering up it freezes, unless in BIOS.
                                But as soon as Windows starts to load, it will freeze.
                                CPU is COLD / Room temp when it freezes.
                                I've replaced the CPU, same problem.
                                Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                Replaced fan - same problem.
                                Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                08-19-2024, 05:22 PM
