Soniq E40S12A-AU Stuck In Standby
  • Eggbert43
    • Jul 2014
    • 47
    Re: Soniq E40S12A-AU Stuck In Standby
    Ok, will test tomorrow, thanks Diah.....
    The other possibility is that more than one LED is bad, which I guess I would need 2 bulbs to test all the different pin combinations etc
      VCC 1 (Pin 1) Connected to 75VDC LED driver PS, it is also connected the Anode of the LED strings.
      LED 1 (Pin 2) This is the Cathode of the LED string #1 which is returned to circuit ground via PWM Controlled MOSFET Q101.
      LED 2 (Pin 3) This is the Cathode of the LED string #2 which is returned to circuit ground via PWM Controlled MOSFET Q102.
      VCC 2 (Pin 5) Connected to 75VDC LED driver PS.it is also connected the Anode of the LED strings.
      LED 3 (Pin 6) This is the Cathode of the LED string #3 which is returned to circuit ground via PWM Controlled MOSFET Q103.
      LED 4 (Pin 7) This is the Cathode of the LED string #4 which is returned to circuit ground via PWM Controlled MOSFET Q104.
      So if you can have pin 2, 3, 6, and pin 7 connected one at a time then turn on the TV and observe if each one of the LED string will come on or not before the circuit goes into protection shutdown. You have to do the test 4 times since you have 4 LED strings., you may have to do it in darkened room.
      • Eggbert43
        • Jul 2014
        • 47
        Thanks budm, will do as suggested as soon as I get a free moment.
        Will also do as Diah suggested & get back to you both once done, thank you...!
        • Loagz
          Soniq S55V14B-AU Stuck in Standby
          by Loagz
          Hi, I'm hoping someone can point me in the right direction....
          I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
          After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
          11-15-2021, 02:13 AM
        • nubie
          Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
          by nubie
          Please help me ID the blown chip and point me where the short might be.
          I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
          The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
          Anything I should check first for a short?
          Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think...
          01-05-2023, 06:06 PM
        • samsonn
          Soniq S55V16A-AU stuck in standby
          by samsonn
          I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
          I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
          06-28-2020, 02:33 AM
        • lego1234567
          LG 32LB1R - stuck in standby mode
          by lego1234567
          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
          What could be the problem ? Thanks...
          01-21-2024, 03:39 AM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
