Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
  • nubie
    • May 2010
    • 64
    Please help me ID the blown chip and point me where the short might be.
    I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
    The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
    Anything I should check first for a short?
    Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think that's the problem. Does this L1085 run off the 12v rail?
  • bbanana
    Father Land
    • Oct 2021
    • 164
    • Vietnam
    Re: Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
    L1085BG maybe is 3,3v
    check :
    pin 1: 2.1V
    pin 2: 5V
    pin 3: 3.3 V
    it getting hot maybe has problem with 3v3 rail. check your led line, LAN and sound line, if all ok i think short on chipset.
    • nubie
      • May 2010
      • 64
      Originally posted by bbanana
      check :
      pin 1: 2.1V
      pin 2: 5V
      pin 3: 3.3 V
      Pin1 is Ground, pin 2 is 12v pin 3 is 0.10V.
      I injected 3.3v from the PSU and smelled some burning. Getting another motherboard, same one, so maybe it can shed some light on the voltages.
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • Hounddoghill
        DPS285BP 5v standby transformer blown
        by Hounddoghill
        Sharp TV LC-80LE633U
        Power supply board DPS 285BP Run TKB096WJQZ
        Standby transformer markings (attached picture)
        MP-130I(01)
        AV-DP11153 Delta
        Dcum 1244(03) H6P
        So an event in the primary exploded the cap (C7901)on pin one of the Standby circuit IC. So after replacing a couple diodes a the 2.2ohm resistor(fuse) I found the transformer inputs are open.
        Anyone know about replacements for this transformer?
        I suspect the original is not available.
        https://www.badcaps.net/forum/images/smilies/silly.gif
        02-04-2022, 03:22 PM
      • fharris1977
        Vizio D50u-D1 Dead Set No Standby
        by fharris1977
        Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
        12-28-2023, 10:25 AM
      • Crystaleyes
        Samsung BN44-00259A standby question
        by Crystaleyes
        Hi all.
        I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
        SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
        Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
        The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
        08-11-2023, 05:15 AM
      • disorder
        HP 2311 display, 3.3v regulator fried, need help to replace
        by disorder
        hello,
        i have a hp display 2311 to repair, totaly dead
        on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
        i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
        thank you
        07-27-2025, 04:34 AM
