Soniq E40S12A-AU Stuck In Standby
  • Eggbert43
    • Jul 2014
    • 47
    Re: Soniq E40S12A-AU Stuck In Standby
    How about a resistor or something?
    • Diah
      • Feb 2013
      • 6614
      Originally posted by Eggbert43
      I'm struggling to grasp where the wires come from?
      which wire ? the photo i added to you.. its any table lamp with filament bulb will have only 2 wire only which take AC from wall socket... this 2 wire one you connected with the wirw which you need to slide it out from the BL socket and the next of the bulb go to the socket at pin3
      sockets on power boards PIn3 -------- table lamp ------- the wire go to backlight
      • Diah
        • Feb 2013
        • 6614
        resistor need high watt ,1K 10 watt and up, bulb are better. as it can handle all kind of currents / watt with out any effect on the other parts in circuit
        • Eggbert43
          • Jul 2014
          • 47
          I have just found a table lamp; see photo.
          However, I am still unsure where the wires you speak of are going to come from?
          • Eggbert43
            • Jul 2014
            • 47
            Do you mean for me to cut the end of the power cable that plugs into the wall off & use those wires?
            • Diah
              • Feb 2013
              • 6614
              yes
              after u cut test it in wall to be sure it work and its switch are on on.. then put it in tv as told.
              you can open the switch and take out the wire from there.... no need to cut
              • Eggbert43
                • Jul 2014
                • 47
                Yey I got there in the end...!
                So, I will do as suggested, making sure that the lamp is switched on before switching on the TV....
                Are we hoping for the screen to stay on & the bulb to light up?
                • Diah
                  • Feb 2013
                  • 6614
                  its your hope too,
                  the bulb will never light on... it will be as resistor only
                  • Eggbert43
                    • Jul 2014
                    • 47
                    No joy, it didn't help....
                    So, in terms of taking the TV apart more, do you have any tricks to bypass the bad LED once it has been identified & we are looking at it?
                    Are we sure that this problem can't be caused by a bad capacitor on the Power Board or something?
                    • Diah
                      • Feb 2013
                      • 6614
                      explain any different you noticed when you did the bulb try?
                      • Diah
                        • Feb 2013
                        • 6614
                        i am afraid you have error at volts reading.. to confirm i want you do the bulb test to the other lines one by one and notice any change.. pin 2 / 6 / 7
                        • Eggbert43
                          • Jul 2014
                          • 47
                          What should I notice?
                          All I noticed is that the splash screen wasn't even coming on, instead the screen just flashed light....
                          It was possible that the wire I was putting down the Pin 3 socket wasn't touching the Pin on the Board properly, so I even tried holding it onto the pin externally to the socket also.... I took my time with those measurements this time, triple checked the readings very carefully etc
                          • Eggbert43
                            • Jul 2014
                            • 47
                            Does bulb size matter at all?
                            It is a slightly smaller than standard household bulb....
                            • Diah
                              • Feb 2013
                              • 6614
                              if you did all correct and splash screen wasn't coming on, mean this line healthy.. so do the test to others 2 6 7
                              • Eggbert43
                                • Jul 2014
                                • 47
                                Ok, will do, thanks Diah
                                  What is the resistance of that incandescent lamp? Cold resistance of incandescent lamp will be really low Ohm (resistance will go up when lamp filament is heated up) which will overload the LED power supply.
                                  • Eggbert43
                                    • Jul 2014
                                    • 47
                                    The bulb is 40 Watt (240/250V); hope that helps?
                                      Check the resistance of the lamp with your Ohm meter.
                                      40W 240VAC = hot resistance of about 1430 Ohms, so cold resistance will be about 143 Ohms or less.
                                      • Eggbert43
                                        • Jul 2014
                                        • 47
                                        I measured 181.8 Ohms
                                        So are you suggesting this is too low to achieve the objective?
                                        I could leave the bulb switched on somewhere for a while, then quickly transfer it to the lamp & test while still warm heheh.... I guess you don't mean that kind of hot; as in hot = plugged into AC Mains, & cold = not?
                                        • Diah
                                          • Feb 2013
                                          • 6614
                                          bulb test method applied to LED back light which controlled with external inverter which it had 24V feed from power boards and it had nothings to do with heat. and will never overload or damage any parts at inverter neither power boards.
                                          the questions if you test this on all lines 2/3/6/7 and didn't help the LED remain on. then you have shorted / exploded / cutoff LED Line. no way unless take the screen apart. end of subject from my side.
                                          • Loagz
                                            Soniq S55V14B-AU Stuck in Standby
                                            by Loagz
                                            Hi, I'm hoping someone can point me in the right direction....
                                            I have a S55V14B TV and it suffered a board failure. Main board part number: 222-655036003-30. I couldn't find a board with the exact part number so I've used what looks to be the same board however the part number is slightly different. 222-655036002-30.
                                            After installing the main board the stanby light came back on, however it wont turn on. I spoke to Soniq Australia and managed to get a copy of the firmware but no service manual. They don't have one. I asked about the different part numbers but they...
                                            11-15-2021, 02:13 AM
                                          • nubie
                                            Gigabyte B460M DS3H blown standby regulator, hot 5v(?) Regulator
                                            by nubie
                                            Please help me ID the blown chip and point me where the short might be.
                                            I have a L1085DG that is getting really hot and a blown up standby regulator (I assume, one leg is ground, one leg is 5v standby, the other has 180 Ohms to ground.
                                            The L1085DG is in the front corner of the board. With no standby power I am using a jumper to get the PSU powered on.
                                            Anything I should check first for a short?
                                            Edit: I can look again but I don't think the USB are shorted, on back or the headers. The USB2.0 are powering up my portable monitor, so I don't think...
                                            01-05-2023, 06:06 PM
                                          • samsonn
                                            Soniq S55V16A-AU stuck in standby
                                            by samsonn
                                            I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
                                            I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting...
                                            06-28-2020, 02:33 AM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
