Westinghouse WD55UDR101 bad picture goes black after a few minutes
  • MikeRWK
    • Jun 2017
    • 121
    Re: Westinghouse WD55UDR101 bad picture goes black after a few minutes
    Ok, now you're getting somewhere, straighten out that blob, then see if the caps still read short, if still short remove one and test it, then test the other one while it's still on the board, one bad cap can make the others read short.
    Solder blob removed! I can't believe I pulled it off. Thats definitely the smallest thing i've worked on. I have good eyes but they have their limits.
      • 12075
      • U.S.
      Nice work, do you still have short on caps?
      • MikeRWK
        • Jun 2017
        • 121
        Now as for the capacitors, here is what I got.
        Caps highlighted in Red tested 146-147ohms one way and 67 ohms the other.
        Yellow tested 2280 ohms both ways.
        Orange tested 418 ohms and 617 ohms.
        Purple which I removed and tested showed open circuit on diode test and resistance climbs until the meter (2000 counts) maxes out.
        The two caps highlighted in blue in the second pic only show .03v when I had the tv running before I removed the capacitor. The others were all showing 0.25v.
          • 12075
          • U.S.
          You forgot the picture.
          • MikeRWK
            • Jun 2017
            • 121
            I forgot to mention when the tv was working voltage on those caps in the first pic was around 1.12v if I remember correctly and it would read 1.06v when the picture would go out.
            • MikeRWK
              • Jun 2017
              • 121
              pics are added, im bad for that.
                • 12075
                • U.S.
                #27
                Test the one you took off in diode mode, does it beep with the probes on both ends? and check the others the same way.
                • MikeRWK
                  • Jun 2017
                  • 121
                  Thats the one that showed open circuit and when i tested resistance it just climbed until the meter maxed out.
                    • 12075
                    • U.S.
                    #29
                    Ok, check the rest on the board for any more shorted if none maybe replace that one and see if tv works, I see some on youtube just get another same type ceramic cap that's the same physical size from a scrap board to use, shouldn't hurt to try the tv with the one cap off just to see if you get a different result than you were getting.
                    • MikeRWK
                      • Jun 2017
                      • 121
                      I was about to say I'm going to scrap the tv and keep the boards. Looks like i need to look at the main board, when I unplugged the lvds cable my short went away.
                      • MikeRWK
                        • Jun 2017
                        • 121
                        I spoke too soon the ic that got the solder glob on it has a few shorts to ground while the other ic doesnt.
                          • 12075
                          • U.S.
                          #32
                          Ok, guess that IC got screwed up with all that solder.
                          • MikeRWK
                            • Jun 2017
                            • 121
                            IT'S ALIVE!!!! I put some flux on the ic and ran my iron across it a few times and I must have still had a short because I it fired up and the tcon ghosted for a second (negatively charged caps from the short?) and it's been working fine for the last 10 minutes or so.
                              • 12075
                              • U.S.
                              #34
                              Nice, glad to hear it, so where that solder blob came from is a complete mystery then?
                              • MikeRWK
                                • Jun 2017
                                • 121
                                No looking back at the first pic I posted of the tcon it wasn't there. That was 100% me,, not sure at what point I did it but I think the tv had two problems, the first which was the shitty power cables and the second which I caused.
                                • MikeRWK
                                  • Jun 2017
                                  • 121
                                  Turned it on and it's back to the same thing. I managed to get into the factory menu, a seiki remote works fine. I reset the eeprom which didnt fix anything.
                                  I'm going to pull it back apart and check everything.
                                  • MikeRWK
                                    • Jun 2017
                                    • 121
                                    Is it safe to assume the 2 ics on the right correspond to the left and right side of the screen?
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • kerberos137
                                      Sony xbr-65x930e faded to black; now has backlight but no picture
                                      by kerberos137
                                      Hopefully someone can help me out. This tv was working perfectly until a few weeks ago. At some point, the TV just faded to black, but sound continued playing. It almost looked like smoke on the screen as it faded from the bottom left corner toward the top right. Took only a second or less, but wasn't instant. After restarting, it turned back on and worked fine for another day or two. Then it happened again more or less the same way, but in a slightly different direction, again with sound continuing. I thought it was working fine after another restart, but looked a bit dimmer than before. Then...
                                      11-29-2022, 05:40 AM
                                    • S14Sr20det
                                      Nec E557Q lines and fade to black picture FIXED
                                      by S14Sr20det
                                      Trash picked this tv from a local business, had a garbage image and would fade to black within second then cut off. It would get shorter and shorter every time.
                                      Narrowed it down to the right side of the panel by unplugging half the t con
                                      One side had a great picture the other was black and distorted still.
                                      Down to the buffer boards… found yet another set of two esd diode arrays. One leg had a 60 ohm short to ground and would get lower the more attempts made to turn the tv on.
                                      Soldering iron and some chip quick knocked both of them off and...
                                      06-17-2023, 02:55 PM
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • EazyBone
                                      Element E4AA70R black screen shows picture
                                      by EazyBone
                                      On this TV I got black screen with with picture.
                                      Tested the LEDs and they work.
                                      Had a hunch that this was similar to a ONN tv thread I found and wanted to post about this to possibly help someone else.
                                      The capacitor by the LEDs is bulging, 450v 10 uf. I suspect this is the cause. Will post results after replacing the capacitor. You could just replace power board as well I assume.
                                      https://www.badcaps.net/forum/showthread.php?t=110615
                                      Will post results when capacitor arrives...
                                      10-13-2023, 05:07 PM
