SONY KDL 43w805c does not accept commands
  • Diah
    • Feb 2013
    • 6439
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk
    And now:
    It is trying to survive somehow )
    did it survive or it take ticket to Mars Journey ?
    • Dobsuk
      • May 2020
      • 127
      • England
      #102
      No, I forgot it switched on during the night and now i think it is completly dead Looks there is nothing more i can do but to buy new main board
      • Dobsuk
        • May 2020
        • 127
        • England
        #103
        Ok, my main board model is 1-893-880-21.
        I the same boards on Internet but for different tv models. Do you think they will be suitable:
        Board 1 - 65W855C
        Board 2 - 65W857C
        Board 3 - 55W800C
          • 12276
          • U.S.
          #104
          Does this tv use an external power supply?
          • Diah
            • Feb 2013
            • 6439
            different size could be different Screen driver.. this will put you again in headache get one as yours model and size for example
            • Dobsuk
              • May 2020
              • 127
              • England
              #106
              Yes, it does.
              • Dobsuk
                • May 2020
                • 127
                • England
                #107
                Mm yeah. Just was looking for cheaper option
                  • 12276
                  • U.S.
                  #108
                  Check if the power supply has the required voltage and is steady if you haven't already.
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    #109
                    Checked with the other TV set. All good.
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      #110
                      OK guys, i have some progression. I bought another main borad from 43w809c. When i switched the set on for the first time with all connected i saw again that self diagnostic screen with colours changing. Reset the TV - was the same. Then i switched off the TV, dosconnected the LVDS cable, switched it back on and connected that cable after few seconds when i could hear the sound from welcome screen and the picture came on. Now it is working but has some strange behaviour at moments - like does not hold the settings after retsrat and others. I can see the TV in my network as 43w809c, do you think it is good idea to change the model number from the service menu?
                      • Diah
                        • Feb 2013
                        • 6439
                        no need at all, as both are same Specifications. just check firmware if its the last one.. if need update it. if this solved the issue good if not send the boards back to seller.
                        • crackedprint
                          Sony HCD-HX80R Amplifier Volume Control Problem
                          by crackedprint
                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                          I have tried a Cold Reset as per the service manual.
                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                          I have looked all the way through the service manual and tried many online...
                          01-21-2025, 12:18 PM
                        • karthur
                          Vizio D65x-G4 Volume changes on its own
                          by karthur
                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                          06-05-2025, 08:13 AM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                        • ahmedtou
                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                          by ahmedtou
                          help me please
                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                          I will share all the details with you, including the disc information.
                          Code:
                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                          Current Profile: BD-R
                          Disc Information:
                          Status: Empty
                          State of Last Session: Empty
                          Erasable: No
                          Free Sectors: 12,219,392
                          Free Space: 25,025,314,816 bytes
                          Free Time: 2715:27:17 (MM:SS:FF)
                          Next
                          08-27-2025, 08:49 AM
                        • Ruptor
                          Sony MHC 6600 volume clicking
                          by Ruptor
                          Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                          05-21-2023, 05:32 AM
