SONY KDL 43w805c does not accept commands
  • Diah
    • Feb 2013
    • 6343
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk
    Nope...neither with the back panel buttons. Only can switch it on with the RC
    now Firmware issue.. try hard reset again... try mouse.. look after the update if you can force it to accepted again
    • Dobsuk
      • May 2020
      • 127
      • England
      #82
      But i can hear the sound now from the welcome screen. It means the tv is reset....
      • Diah
        • Feb 2013
        • 6343
        try from standby mode log in service menu and from there initial the eeprom
        • Diah
          • Feb 2013
          • 6343
          you can also try to cause error to let the firmware jump from this test... for example plug it out from wall then plug out the LVDS cable. let it register error.. plug it out and put back the LVDS in place
          • Dobsuk
            • May 2020
            • 127
            • England
            #85
            How to login in service mode?
            • Diah
              • Feb 2013
              • 6343
              watch
              • Dobsuk
                • May 2020
                • 127
                • England
                #87
                Nothing happen with this. It does not register any error....still looping in that self test menu. I tried to reset it few times with and without the LVDS cable.
                • Diah
                  • Feb 2013
                  • 6343
                  how it come you reset it with out LVDS LOL... we said just plug it in wall to register error..
                  any way after it reset you hear the start sound.. can you increase it and decrease the sound with RC ?
                  if you press OK on RC to pass language then press OK again to pass the land the start music should stopped !!! try
                  • Diah
                    • Feb 2013
                    • 6343
                    well to let the subject here complete to any one read this threat... attached how we can control Sony with serial command via service / serial port per (RS232C or as build in Model )
                    for more command and how to google.
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      #90
                      Yeah mate i tried that first - to unplug it and thw plug it in the wall without LVDS cable - nothing happened. Then i tried to reset it without this cable. No i am trying to put in standby mode but without success till now. It is just turning on every timw by itself. And yes, i can control the volume when i can hear the sound but that sound it is not comming up every time.
                        • 12079
                        • U.S.
                        #91
                        So what is it doing now, looping test patterns?
                        • Dobsuk
                          • May 2020
                          • 127
                          • England
                          #92
                          Yes.... I tried everything and still trying to do.something - restart, reset etc....
                            • 12079
                            • U.S.
                            #93
                            I think you need to do a firmware update/pair, use the usb drive method, hopefully this kdl is one that will update by itself without needing you to do any remote clicks, some do some don't.
                            • Diah
                              • Feb 2013
                              • 6343
                              keep pressing power on RC for more than 10 seconds.. the set should reboot
                              EDID:
                              you need to buy or ask any friend have I8 Mini 2.4Ghz Wireless Touchpad Keyboard, its work with android and it will work same way about control the Sony with serial command.
                              • Dobsuk
                                • May 2020
                                • 127
                                • England
                                #95
                                Do you think if i can find wireless keyboard will be able to connect it to the set?
                                • Diah
                                  • Feb 2013
                                  • 6343
                                  i use always i8 Mini when RC had issue or no RC in hand with any TV brand. or android TV BOX. because its driver type plug & Play
                                  • Dobsuk
                                    • May 2020
                                    • 127
                                    • England
                                    #97
                                    OK, guys. I was away for a month and now i am back to this project.
                                    Diah, i found air mouse from a frined like this one:
                                    Could you give me some advise how to proceed, please?
                                    • Diah
                                      • Feb 2013
                                      • 6343
                                      [ATTACH]232211[/ATTACH]
                                      yes this is i8 air mouse keyboards.. nothings special need as try F keys and other.. plug the related usb receiver in Tv first then turn on
                                      • Dobsuk
                                        • May 2020
                                        • 127
                                        • England
                                        #99
                                        Ok i did check with the ait mouse but could not see any changes pressing all F keys or the others. Restart TV few times but nothing. Then disconnected the TCON cable so to force some errors or something and now the TV stuck on this screen:
                                        And now i do not dare to touch anything.....
                                        • Dobsuk
                                          • May 2020
                                          • 127
                                          • England
                                          #100
                                          And now:
                                          It is trying to survive somehow )
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • karthur
                                            Vizio D65x-G4 Volume changes on its own
                                            by karthur
                                            On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                            It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                            06-05-2025, 08:13 AM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • Ruptor
                                            Sony MHC 6600 volume clicking
                                            by Ruptor
                                            Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
                                            05-21-2023, 05:32 AM
                                          • jason123
                                            Sony STR-DN1030 Distorted audio when Volume adjusted
                                            by jason123
                                            New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
                                            All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
                                            First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
                                            Second thought was the ribbon cable from front display to control board (V-Flex,...
                                            06-05-2022, 12:54 PM
