Sharp LC40LE531E Red/Green flashing LED
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Re: Sharp LC40LE531E Red/Green flashing LED
    With regard to the U3 Mosfet the readings with reference to ground on the 220uF/35V cap:
    (this in powered on mode with the front LED pulsing Red/Green)
    Drain 0.035V
    Gate 24.15v
    Source 24.19
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      I remeasured everything on CN3 with the LED strings connected in standby and ON modes.
      Standby
      Pin-1 VCC
      Pin-2 V between P1 & P2 1.672v
      Pin-3 V between P1 & P3 1.187v
      Pin-4 No Connection
      Pin-5 VCC
      Pin-6 V between P5 & P6 1.745v
      Pin-7 V between P5 & P7 1.685v
      ON
      Pin-1 VCC
      Pin-2 V between P1 & P2 10.52v
      Pin-3 V between P1 & P3 10.36v
      Pin-4 No Connection
      Pin-5 VCC
      Pin-6 V between P5 & P6 10.32v
      Pin-7 V between P5 & P7 10.48v
      • Diah
        • Feb 2013
        • 6362
        look good.
        try to disconnect the screen totally from the T-CON ( disconnect the ribbon cable from t_CON side ) and see did the set come on or the BL turn on ?
        show me please photo on yours Main boards and T-CON
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          I disconnected the T-Con board and power on but there was no change. The LED arrays did not light (they remained at approx 10.5V)
          • Diah
            • Feb 2013
            • 6362
            Man--- i wrote at my post #23 to disconnect the screen ( panel ) from T-CON ( ribbon cable are the 2 flat one connected between T-CON and panel )... also the T-CON should be stay in place and it connected to the LED inverter and to the main boards via 2 LVDS cable
            BTW. the LVDS cable are not plugged good at the main boards... you should let them in place.
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              #26
              Please forgive my ignorance.
              When you said to disconnect the T-Con board, I assumed that was disconnecting it from the digital and inverter boards.
              Do you want me to reconnect these connectors and disconnect the lower ribbon cables?
              EDIT: I have reseated the T-Con connectors on the logic board.
              I disconnected the ribbon cables from the bottom of the TCon board.
              No change going from standby to On
              • Diah
                • Feb 2013
                • 6362
                did you saw the photo of the main boards i made remark on it ?????
                • Diah
                  • Feb 2013
                  • 6362
                  i think your issue fault at firmware bootloader section.. as your main boards Vestel 17Mb70.
                  you need to know which type of panel you have ... in case its LG panel.. then use this file.. extract the zip and put all 3 file
                  1- mb60_en.bin
                  2- mboot.bin
                  3- usb_auto_update_T4.txt
                  on USB stick formatted fat32 better stick not bigger than 2Gb , insert the stick at tv and try first press P+ on the remote ...keep pressing then turn on the set.. if P+ didn't work then try press OK on RC
                  • Nevillet
                    • Sep 2019
                    • 272
                    • United Kingdom
                    #29
                    Thank you.
                    It's an Samsung screen I think:
                    https://www.badcaps.net/forum/attach...1&d=1610654324
                    • Diah
                      • Feb 2013
                      • 6362
                      Thank you.
                      on the mainboard under the cover CI decoder socket ( where there yellow label TEST OKAY ) if you remove the cover you will have the boards label printed .. upload photo of it. )
                      • Nevillet
                        • Sep 2019
                        • 272
                        • United Kingdom
                        #31
                        This the right ID label?
                        • Diah
                          • Feb 2013
                          • 6362
                          okay thanks... forget my bootloader file... yours set bootloader 100% okay...
                          you have BGA issue
                          take the mainboards out side and heat it very well with hot air gun specially under side where the black heatsink covered cpu and other 2 chips. leave it cool down and then put it in place
                          EDIT:
                          it could be main firmware too... i have many with LG panel driver ( medion sets) either modified firmware too and autorun.sh
                          at end here are documentation service manual and schematic to this boards.
                          • Diah
                            • Feb 2013
                            • 6362
                            for record.. there are procedure using UART to know where are the BGA exactly as this set Linux and we can communicated with it via UART. USB TTL 5.V and the UART pins are at the scart sockets
                            Scart Pin 10 - RX
                            Scart Pin 12 - TX
                            Scart Pin 14 - GND
                            terminal setting
                            Baud-Rate:115200
                            Bits: 8
                            Stop-Bits : 1
                            Parity : None
                            Handshake: No
                              So at this point the ENA (BL-ON) is still staying at <1V, correct?
                              • Nevillet
                                • Sep 2019
                                • 272
                                • United Kingdom
                                #35
                                I removed the main digital board and heated the large BGA chips for a few minutes - then let them cool and reassembled.
                                I now only have the red standby and it will not turn on as it did before...
                                Have I fully broken it now?
                                • Diah
                                  • Feb 2013
                                  • 6362
                                  no you didnt... the BGA still there.. do it again and search for firmware for yours mainboards 17MB70-5P with samsung panel driver..
                                  by the way yesterday i did extract the bootloader i posted before its dosnt contained any driver... the driver of panel and audio and video are located at main firmware which you need to search for... so its safe if you flash the bootloader i attached before.
                                  • Nevillet
                                    • Sep 2019
                                    • 272
                                    • United Kingdom
                                    #37
                                    • Diah
                                      • Feb 2013
                                      • 6362
                                      what are you doing LOL ... bad idea.. because if there SMT parts at bottom side of the boards all will fill down... !!!!!!
                                      • Nevillet
                                        • Sep 2019
                                        • 272
                                        • United Kingdom
                                        #39
                                        ...this TV has driven me crazy!!!
                                        Anyhow after my (bad) light bulb trick it it now as it was before.
                                        So solid red with power, then red/green flash on front panel button press...
                                        Re re-flashing firmware how about this?
                                        http://gofirmware.com/content/17mb70-5p-firmware
                                        • Diah
                                          • Feb 2013
                                          • 6362
                                          download this firmware its for samsung panel
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • Tomylee
                                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                                            by Tomylee
                                            Sorry for the person who’s going to read all this !
                                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                                            07-11-2025, 11:52 AM
                                          • dmcabs
                                            SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
                                            by dmcabs
                                            Hey guys,
                                            I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
                                            This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
                                            FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
                                            I'm a bit rusty but still have ability to dig right down.
                                            I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
                                            09-21-2024, 11:09 AM
                                          • JunkmanJimbo
                                            sharp lc-65ub30u plays but screen is flashing on and off
                                            by JunkmanJimbo
                                            Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
                                            09-07-2024, 09:45 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
