Re: Sharp LC40LE531E Red/Green flashing LED
I agree with Mr. Barton, very well done Diah, you are...The Wizard.
Good fix indeed.
Now you should take the Voltage readings as reference for future repair.Leave a comment:
the Main boards design are early one from vestel where they missed up with so many parts where now at the new design are to much less parts. beside the quality of some brand parts of NAND RAM EEPROM developed in good way... SOME BRAND NOT ALL... as we experience many become more bad than before.Leave a comment:
Last question:
How does the BIOS/SW become corrupted in the first place?Leave a comment:
THANK YOU SO MUCH!!
Persistence works!!!
PM sent.Leave a comment:
OK.
500Mb USB stick
FAT32
All files copied across
F**K!!!!
It's worked!!!!!!!!!!!!!!!!!Leave a comment:
its better to flash the bootloader first then the main firmware
extract the zip and put all file you have on USB stick formatted FAT ot FAT32 the usb stick will be better with max 1GB . insert the stick in tv press P+ or ok on RC and turn on the set.. you can see the USB stick led indicator will blinking... give time for it... after it finish flashing and every things went ok.. the TV will restart and initial it selfLeave a comment:
OK, I have the FW.zip file.
Which file do I need to flash and how do I do it?
Is there a YouTube video you can recommend?Leave a comment:
...this TV has driven me crazy!!!
Anyhow after my (bad) light bulb trick it it now as it was before.
So solid red with power, then red/green flash on front panel button press...
Re re-flashing firmware how about this?
http://gofirmware.com/content/17mb70-5p-firmwareLeave a comment:
what are you doing LOL ... bad idea.. because if there SMT parts at bottom side of the boards all will fill down... !!!!!!Leave a comment:
by the way yesterday i did extract the bootloader i posted before its dosnt contained any driver... the driver of panel and audio and video are located at main firmware which you need to search for... so its safe if you flash the bootloader i attached before.Last edited by Diah; 01-15-2021, 06:10 AM.Leave a comment:
I removed the main digital board and heated the large BGA chips for a few minutes - then let them cool and reassembled.
I now only have the red standby and it will not turn on as it did before...
Have I fully broken it now?Leave a comment:
So at this point the ENA (BL-ON) is still staying at <1V, correct?Leave a comment:
for record.. there are procedure using UART to know where are the BGA exactly as this set Linux and we can communicated with it via UART. USB TTL 5.V and the UART pins are at the scart sockets
Scart Pin 10 - RX
Scart Pin 12 - TX
Scart Pin 14 - GND
terminal setting
Baud-Rate:115200
Bits: 8
Stop-Bits : 1
Parity : None
Handshake: NoLeave a comment:
okay thanks... forget my bootloader file... yours set bootloader 100% okay...
you have BGA issue
take the mainboards out side and heat it very well with hot air gun specially under side where the black heatsink covered cpu and other 2 chips. leave it cool down and then put it in place
EDIT:
it could be main firmware too... i have many with LG panel driver ( medion sets) either modified firmware too and autorun.sh
at end here are documentation service manual and schematic to this boards.Last edited by Diah; 01-14-2021, 04:11 PM.Leave a comment:
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by dmcabsHey guys,
I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
I'm a bit rusty but still have ability to dig right down.
I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about... -
by JunkmanJimboHey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
by STKR123As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
I wonder if re-flashing the BIOS might be of any use here.
As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,... - Loading...
