SONY 65" 4K - Horizontal Line on top
  • pazoline
    • Dec 2020
    • 26
    • Brasil
    #61
    Re: SONY 65" 4K - Horizontal Line on top
    Originally posted by Davi.p
    I have found a video where horiz. sparse lines, but intermittent, can be solved via signals masking..
    This is what we are trying tô do my friend!
    • 280zx
      • May 2020
      • 43
      • US
      #62
      pazoline did you post that video on youtube yet?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4460
        • Italy - Milan
        #63
        i know.. was a plus info
        • pazoline
          • Dec 2020
          • 26
          • Brasil
          #64
          https://youtu.be/ohYETE9CAYs
          • pazoline
            • Dec 2020
            • 26
            • Brasil
            #65
            Originally posted by pazoline
            Hi Friend , do you still have your old t con board?
            • 280zx
              • May 2020
              • 43
              • US
              #66
              I watch the video, but not sure which ribbon contact to tape off. As for the t-con board I still have the old one.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4460
                • Italy - Milan
                #67
                Which is the problem? I saw back that you found the correct pins to block..
                • pazoline
                  • Dec 2020
                  • 26
                  • Brasil
                  #68
                  is the 4th pin, on each cable
                  right side, 4th pin right to left, on both conectors
                  Left side 4th pin left to righ on both conectors , but you will need to test wich side to block testing one at the time
                  • pazoline
                    • Dec 2020
                    • 26
                    • Brasil
                    #69
                    how do i call an admin on this forum?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4460
                      • Italy - Milan
                      #70
                      search for Topcat...
                      i have not seen your video.. so you have solved.. but 280zx not... aren't the same situations?
                      • pazoline
                        • Dec 2020
                        • 26
                        • Brasil
                        #71
                        clock signals 1 to 4
                        • 280zx
                          • May 2020
                          • 43
                          • US
                          #72
                          So if I understand correctly each ribbon has its own clock signal?
                          • pazoline
                            • Dec 2020
                            • 26
                            • Brasil
                            #73
                            yes , each side each conector, always in the 4th pin
                            • pazoline
                              • Dec 2020
                              • 26
                              • Brasil
                              #74
                              • 280zx
                                • May 2020
                                • 43
                                • US
                                #75
                                pazoline did you get a chance to change the bad t-con board yet? I have not had a chance to get the ribbon cables installed yet. To many projects going on.
                                • pazoline
                                  • Dec 2020
                                  • 26
                                  • Brasil
                                  #76
                                  Hello My friend! , i am still waiting for the t con board , do you have any news where the board is? maybe a track code?
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • Ihandyrepair
                                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                    by Ihandyrepair
                                    Hi guys
                                    I just started fixing 4k TV few months ago. so I am still learning a lot
                                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                    then it started to show the ghosting white image.
                                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                    it has 3 thin small boards at the bottom of the...
                                    12-05-2022, 04:18 PM
                                  • iglitare
                                    by iglitare
                                    09-04-2025, 07:13 AM
                                  • cubytus
                                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                    by cubytus
                                    Hi to all,
                                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                    01-10-2024, 01:26 AM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
