SONY 65" 4K - Horizontal Line on top
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4363
    • Italy - Milan
    Re: SONY 65" 4K - Horizontal Line on top
    Search for a cracked screen tv..
    If my diagnisis is correct the liquid is drying and making serious damage..i suggest you to open it.
    I have a giant 55 opened on the bench since much time with liquid damage, i assure you it is very a pain ..
    • Diah
      • Feb 2013
      • 6396
      hmmmm so late to discover it. show me the damage of the ribbon cable with close focused photo to see if you can repair it.. i did repair many time ribbon and lvds cable,, its always one time attempt repair
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4363
        • Italy - Milan
        Also i add... I don't think your picture showed signs of bad cables, since defect was moving and other questions, maybe you ruined it. Now how it appears the image? No image?
        • 280zx
          • May 2020
          • 43
          • US
          This is what I believe happened. The first picture was what the original post for sale was. Then I believe the owner played around with the t-con ribbon cables which he must of damaged. The second picture is now.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4363
            • Italy - Milan
            My bet is a full shampoo :-)
            • pazoline
              • Dec 2020
              • 26
              • Brasil
              #26
              hello guys , i have the exact same problem,exact same model i ordered new flat cables , horizontal lines are tied to gate drivers short in lcd panel, or bad tab conection in vcom board, first you need to press the gate flat cables on vcom board and see if the lines are gone, if is that the case, you should press it with non conductive materials such as rubber, if is not the case, is a short , and you can isolate the short
              https://www.youtube.com/watch?v=SbGAkRgaZhs
              • 280zx
                • May 2020
                • 43
                • US
                #27
                I ordered the 4 t-con ribbon cables and waiting on them. Once I get them I will update, but I was planning on doing what is in that youtube video.
                • pazoline
                  • Dec 2020
                  • 26
                  • Brasil
                  #28
                  lets help each other!
                  • pazoline
                    • Dec 2020
                    • 26
                    • Brasil
                    #29
                    this may help
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      #30
                      send a close up pic of the original ribbon cable. taping off the cable as in the video is going to "fix" you r tv
                      • pazoline
                        • Dec 2020
                        • 26
                        • Brasil
                        #31
                        https://www.shopjimmy.com/auo-55-65t...1-t-con-board/
                        can some good tec help us to identify what signals to block on t-con cables? where the clock signals come from? thats the real strugle, because that cables are really fragile, try and error will cost another set of cables, ( already happen to me )
                        something important to know, that tv is a 3d tv, so there are two flat cables for each side, if we grind success isolating the short , the 3d will be gone 4 ever right?
                        • 280zx
                          • May 2020
                          • 43
                          • US
                          #32
                          Here are pictures of the 4 ribbon cable tips. As you can see they are shot. It's a beautiful TV and I would hate to see it go to the landfill...
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4363
                            • Italy - Milan
                            #33
                            No, Horizontal lines are only sign of bad gate drivers
                            Wasted time. No contact problem, bad gate circuits. Or if water present and lines moving maybe momentary malfunction, i don't know..
                            You can't fix single isolated horizontal lines i think.
                            If a defect is moving, nothing is really burnt on the panel
                            • pazoline
                              • Dec 2020
                              • 26
                              • Brasil
                              #34
                              ok is water problem, you win , now would you let us solve our problem?
                              • Diah
                                • Feb 2013
                                • 6396
                                if you read my post #7 then now you had enjoying the beauty of it.....
                                • 280zx
                                  • May 2020
                                  • 43
                                  • US
                                  #36
                                  I know I know.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4363
                                    • Italy - Milan
                                    #37
                                    Pazoline i have win nothing, it's not a race, what do you think i am here for? I have made my advice weeks ago, nobody folowed, and you ask me to solve your problem? Have i to take an airplane? Mine was an idea, i don't know if you wash or not your screen, it's based on my knowledge and observation,, i can be wrong, i don't like to repeat. I have seen a bit of the video, and curiously see that someone otther have got the idea of where to take technical documents, i had the idea long time ago, unfortunately i can translate well that documents, so i almost watch diagrams..
                                    • pazoline
                                      • Dec 2020
                                      • 26
                                      • Brasil
                                      #38
                                      I know I know.
                                      any news on the cable? my package will come on monday
                                      • 280zx
                                        • May 2020
                                        • 43
                                        • US
                                        #39
                                        Pazoline I'm still waiting on the new ribbon cable. I can't wait to get them.
                                        • Diah
                                          • Feb 2013
                                          • 6396
                                          I encourage you to clean the ribbon sockets with toothbrush on the panel & T-CON, to be sure there are no rest of cable broken pins left at the sockets.
                                          ((let the the sockets clip open to the top and with the brush from boards side forward outside massage them. after that under loop check if all pins are aligned in place))
                                          i faced such issue before
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • Ihandyrepair
                                            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                            by Ihandyrepair
                                            Hi guys
                                            I just started fixing 4k TV few months ago. so I am still learning a lot
                                            I got this tv from friend complaint is ghosting or horizontal lines on image.
                                            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                            then it started to show the ghosting white image.
                                            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                            it has 3 thin small boards at the bottom of the...
                                            12-05-2022, 04:18 PM
                                          • cubytus
                                            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                                            by cubytus
                                            Hi to all,
                                            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                                            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                                            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                                            01-10-2024, 01:26 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • bbrain
                                            Sony KD-55AG9 TCON?
                                            by bbrain
                                            I have this problem with my Sony 55' AG9.
                                            It flashes 4x.
                                            I have found the service manual, and seems it is the TCON.
                                            Before I buy a TCON can someone check the vid?
                                            Thanks in advance!...
                                            09-19-2024, 10:50 AM
