BN44-00517C dead - blown cap, resistor and fuse
  • lotas
    • Jan 2016
    • 4754
    • Russia
    #41
    Originally posted by dazzystar
    OK. Does it sound like number 1 is faulty as I get a sound and a meter reading in both directions?
    I answered in post 37 that a 68 Ohm resistor was soldered in parallel to it, so the multimeter shows this resistance! To be sure, unsolder it and check.
    Only they (zener diodes) should not be confused with each other, each zener diode has its own marking and each marking has its own characteristics!
    • dazzystar
      • Dec 2023
      • 25
      so I have scraped around the area and the readings from all 4 diodes are the same as before. Is it worth repairing or should I give up?
      • vinceroger69
        • Mar 2012
        • 6714
        #43
        Depending on what the tv is worth to the customer or if for re sale china do a board but not cheap maybe worth sending the seller a lower offer Substitute bn44-00517c Power supply board for Samsung TV Maintenance Accessories - AliExpress​
        • dazzystar
          • Dec 2023
          • 25
          Thanks but it's my TV not a customers. Also that aliexpress board is NOT compatible with the TV. Shame. We'll take it to the recycling centre.
            • 12276
            • U.S.
            #45
            Just make sure you are testing the diodes correctly, they are pretty cheap to buy, of course shipping is never very cheap, check youtube, there's plenty of component checking videos.
            • cheeky2
              • Dec 2012
              • 337
              #46
              Thanks but not sure which one(s) you mean. Here's a pic of the new PWM chip.
              Click image for larger version  Name:	IMG_6078.jpg Views:	25 Size:	4.42 MB ID:	3173857
              Your pin 5 doesn't appear to be connected up to anything! Did you take a picture of your pcb before you did the soldering? Also your pin 4 looks like the track could be broken as well where the masking is removed and the copper is exposed.
              • dazzystar
                • Dec 2023
                • 25
                Pin 5 doesn't connect to anything. I didn't take a pic beforehand.
                • dazzystar
                  • Dec 2023
                  • 25
                  I've tried testing the diodes with my DMM. The only one I get any reading from is what I described earlier so I have no idea now what to try.
                    • 12276
                    • U.S.
                    #49
                    Probably best way to test, specially if they seem to test not right in circuit is to remove and test out of circuit, Look there, 13 minute mark, checking diodes : https://www.youtube.com/watch?v=l7WdQoPGjrU
                    • lotas
                      • Jan 2016
                      • 4754
                      • Russia
                      #50
                      For this SSC2S110 PWM, pins 3 and 5 are not used.
                      • dazzystar
                        • Dec 2023
                        • 25
                        Yes. I saw that. Thanks.
                        • dazzystar
                          • Dec 2023
                          • 25
                          Can anyone help with what value(s) those zener diodes are please so I can order some replacements. Also, does anyone have a link to a circuit diagram at all?
                          • Jonny B
                            • United Kingdom
                            #53
                            Hi, I have the same issue and rather than throw the TV away I want to try and fix it. I have sourced some of the parts but I'm struggling with the resistor. If anyone could post a link to the correct one I'd really appreciate it.
                              • 12276
                              • U.S.
                              #54
                              Budm explained it in post #2, 0.24ohm resistor, doesn't have to be flame proof, or are you talking about another one, youtube is your friend for how to test components if needed. Resistor checking chart there for thru hole: https://www.digikey.com/en/resources...tor-color-code Surface mount chart: https://www.digikey.com/en/resources...-resistor-code
                              • Jonny B
                                • United Kingdom
                                #55
                                Thanks for your swift reply.
                                The only reason I ask for a link to the correct one is that I have been looking for a while now and still seem to get lots of options even when I find a 0.24ohm resistor.
                                Other factors that I can see when looking include,
                                • Composition - wire wound, metal film, metal oxide film
                                • Power (watts)
                                • Operating temperature
                                • Temperature coefficient
                                Again, any help would be really appreciated.
                                  • 12276
                                  • U.S.
                                  #56
                                  Some there, I'm not sure what watt yours is but I wouldn't put a half watt where a 1 watt was, you can tell by measuring the diode, measure yours not including the leads, then just search for diode size, the one watt are much bigger than the 1/4 watt: https://www.ebay.com/itm/32468305174...r=513856919460
                                    • 12276
                                    • U.S.
                                    #57
                                    By size: https://www.youtube.com/watch?v=LRf33fN68ws
                                    • Diah
                                      • Feb 2013
                                      • 6439
                                      just to add.... if the PWM chip exploded .. must all SMD caps replaced beside the R on the TOP. its Frequency function should be captured by Oscillator, nozt only testing in R or Diode mode.
                                        • 12276
                                        • U.S.
                                        #59
                                        Meant to say resistor in post #56, not diode.
                                        • dinkodinko
                                          • Apr 2022
                                          • 4
                                          • Croatia
                                          #60
                                          I had few blown components on the LED power supply on BN44-00517C board, including 1kv capacitor, MOSFET, power resistor, and some SMD resistors for which I cannot find values, so maybe someone can help me.
                                          I've tried to recreate resistor combination using a datasheet for the SSC2S110 pwm controller, but the LED backlight still won't turn on.
                                          I can confirm that the LED backlight is working, pwm controller is working because I've soldered it instead of the same controller for logic power supply and that is working fine.
                                          I've even changed the optocoupler.
                                          The only thing that could have some influence is 0.22 ohm resistor RM811 i've put in instead of blown 0.24 ohm one, but it should at least start for a second, even if the resistor blows again.
                                          Any suggestion is welcome.
                                          Thank you in advance,
                                          Regards,
                                          Dinko
ID:	3330473 Click image for larger version
                                          • dellxps15
                                            macbook a1707 15 inch trackpad dead. blown fuse identification
                                            by dellxps15
                                            hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                            another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                            04-30-2024, 10:48 AM
                                          • magneh
                                            Is this some kind of fuse resistor ?
                                            by magneh
                                            Hello guys
                                            Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                            Seem to me like some kind of fuse resistor?
                                            After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                            They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                            The red band is larger than the 4 others, but I dont have much experience with these components.
                                            Also one of the orange...
                                            02-10-2025, 07:54 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
