BN44-00517C dead - blown cap, resistor and fuse
  • dazzystar
    • Dec 2023
    • 25
    Because I don't have one available and to buy just would be expensive, plus I don't have an SMD soldering station. So, if replacing the fuse, cap and resistor doesn't fit it and I can't get a replacement PSU board for little money in the UK then it's the bin for the TV which would be a shame.
    • diif
      • Feb 2014
      • 6978
      • England
      Available from ebay for cheap. Use the same soldering iron you'll use for replacing the other components. Use some low melt solder.
      • dazzystar
        • Dec 2023
        • 25
        Thanks but I can't find them on ebay.co.uk
        • diif
          • Feb 2014
          • 6978
          • England
          https://www.ebay.co.uk/sch/i.html?_f...2S110&_sacat=0
            • 12085
            • U.S.
            You can probably do it if you take your time, maybe watch a couple youtube videos, there's plenty available.
            • dazzystar
              • Dec 2023
              • 25
              Well I've ordered the part but I hope I can figure out how to fit it and it'll work!
              • lotas
                • Jan 2016
                • 4471
                • Russia
                #27
                You also need to check the components next to this smd chip (low-resistance resistors, diodes....).
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4276
                  • Italy - Milan
                  #28
                  Must to use the lamp in series to input.. to keep safe the new conponents.. you have to check if mosfet is shorted D-G, if yes the oscillating IC is 100% dead..
                  • dazzystar
                    • Dec 2023
                    • 25
                    Well we replaced the PWM chip as well but still no joy. No standby light. So out of options now.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #30
                      Did the check the components next to it ?
                      • dazzystar
                        • Dec 2023
                        • 25
                        Thanks but not sure which one(s) you mean. Here's a pic of the new PWM chip.
                        • dazzystar
                          • Dec 2023
                          • 25
                          I should also add that when I plug the TV to mains power I hear the satisfactory 'click' from the PSU so something is better than what it was!
                          • lotas
                            • Jan 2016
                            • 4471
                            • Russia
                            #33
                            Have you checked these zener diodes?
                            • dazzystar
                              • Dec 2023
                              • 25
                              No. I haven't. They seem to have 3 legs on them. How do I test with my multimeter?
                              • lotas
                                • Jan 2016
                                • 4471
                                • Russia
                                #35
                                They have two legs (1, 3) connected together, so that they have two, like a regular diode (zener diode).
                                • dazzystar
                                  • Dec 2023
                                  • 25
                                  From 1 I get a beep in both directions with my DMM and a reading of around 70 ohms. From 2, 3 and 4 I get nothing in either direction from the DMM
                                  • lotas
                                    • Jan 2016
                                    • 4471
                                    • Russia
                                    #37
                                    At 1 you get a sound signal because there is a 68 Ohm resistor (680) in parallel with it.
                                    • dazzystar
                                      • Dec 2023
                                      • 25
                                      Thanks again. Does that mean the other 3 diodes are faulty?
                                      • lotas
                                        • Jan 2016
                                        • 4471
                                        • Russia
                                        #39
                                        When checking in the "Diode" mode, they should show only in one direction, this is when the red probe is on the anode, and the black one is on the cathode, scrape off the varnish on the terminals and check again, maybe there is a bad contact with the probe, if nothing happens, then you need their replacement.
                                        • dazzystar
                                          • Dec 2023
                                          • 25
                                          OK. I will check again soon and report back. Does it sound like number 1 is faulty as I get a sound and a meter reading in both directions?
                                          • dellxps15
                                            macbook a1707 15 inch trackpad dead. blown fuse identification
                                            by dellxps15
                                            hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                            another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                            04-30-2024, 10:48 AM
                                          • magneh
                                            Is this some kind of fuse resistor ?
                                            by magneh
                                            Hello guys
                                            Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                            Seem to me like some kind of fuse resistor?
                                            After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                            They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                            The red band is larger than the 4 others, but I dont have much experience with these components.
                                            Also one of the orange...
                                            02-10-2025, 07:54 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
