intergrated tcon board ic rt6939 vestel polaroid p55up0277a
Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
here is pic of screen the only thing you can see is my reflection in my workshop the light from window reflected
the tv is upside down on workbench
screen has very dark blue with no picture imageAttached Filesif you find these attachements useful please consider making a small donation to the site
unplug lvds socket and take a picture please.https://www.badcaps.netComment
Why leds shining blue?
unplug lvds socket. Turn on tv and plug a dvd or receiver via scart. if you hearing sound panel is faulty. if still same...good luck.https://www.badcaps.netComment
i dont know why display is blue
the backlights seem very bright viewed from the back of tv.
i use satellite box i/p via scart . no sound,since f/w update.
so is this important
your f/w is
:QNDS2DN12
MY PANEL is type :VES550 QNDS 2D U12
could it be the f/w is not the same ,would this explain why ,since f/w update i have no sound?Comment
before you write FW the tv was installed so you can switch input to hear sound. complete firmware you did flashed the tv will be back to first installation page so no way to switch input. you can by pass it as blind way by pressing OK several time on RC and EXIT too.Comment
Does anyone have some information about this capacitor, on the same t-con board from the discussion above ? Thanks !Attached Filesif you find these attachements useful please consider making a small donation to the site
sorry to waking this post again... I have the exact same issue and my tcon has the same components -RT6939 GQW. Its an MI tv and even I thought it was a cap that was shorted but now after reading this post I learn that its a fuse. Did you find a solution to this? I need help urgently.Comment
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by snimmitsGood afternoon,
I have a Polaroid P43D300.
It shipped with WiFi and Bluetooth.
Two weeks ago, I ran through the first time installation.
This did a full reset and went through the first time setup.
Once complete, I went to settings > sound.
selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
search completes and doesn't find any devices.
I have tried everything I can think of.
Can someone provide... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
