intergrated tcon board ic rt6939 vestel polaroid p55up0277a
Re: intergrated tcon board ic rt6939 vestel polaroid p55up0277a
Try it.https://www.badcaps.netComment
1 3.38v, 2 3.38v, 3 3.4v ,4 0v,
5 ov, 6 3.38v 7 3.26v, 8 3.26v
no change with heat or freeze before turning on,tried a few times ,no changeLast edited by jimbofz; 11-17-2020, 05:49 AM.Comment
try the firmware from Arıza Notları
while the tv ON, plug it from wall socket.. put all files on usb drive and insert it at any usb ports, press OK on the RC and keep pressing while you plug the tv in wall socket again... hope your screen will show progressComment
do the 3 files have to be in a folder,
or do i load them on to usb
as 3 separate items?
ive double checked the voltages on U11 and U13
and as you say i would expect them to be the same?Comment
about SPI.. my bad english.. i am asking if the both SPI lable are the same as you wrote 25L1606E on the paperComment
thanks your english is very good much better than my german
both SPI are the same 25L1606E.
i have downloaded and extracted the files ,
do they have to be in a folder or do i create a folder ? put the files in then send to usb?Comment
i did answer before... no folder just all files copy them on the usb root LOLComment
Plug USB Drive to USB 1 port of tv.
Press and hold OK button from rc and plug in ac cable.
Hold OK button until led blinking fast.https://www.badcaps.netComment
the other 2 are not marked
looked on back cover and on pcb
i tried the usb next to the scart skt and followed your instructions
holding down OK button waited 5 minutes no fast blinking
so powered off and tried the side usb ,no change
only now when i removed the usb and powered on i cant get sound from scart i/p which i had before so now im confused
just looked on cct there labelled side usb, back usb, and usb3 which is the correct one?Last edited by jimbofz; 11-17-2020, 01:35 PM.Comment
Usb 1 is cn16.
Unplug lvds cable and try again.https://www.badcaps.netComment
ok tried with lvds cable disconected
using the usb next to the scart skt which is cn16
when fast blinking pauses
i remove power
reinstall the lvds and unplug usb
tv will come in and out of sby as before,
but cant get any sound via scart i/p
and pic just the same as before no osg or pic infoComment
ok back to basics when the main board is working normally
it provides a enable voltage to turn on the dc/dc converter ics
on the intergrated tcon board .
now after trying to install the f/w
we still have no enable voltage on pin 22 or 30 of the lvds
neither of these pins are s/c or low resistance to deck .
if i could find out which is the enable pin in the two ics RT6939 AND RT6935 these ics are made by RICHTEC and their website has info on hundreds of ics that they make except the ones used in this vestel panel.
i may have to wait until i can compare with a working vestelComment
After upgrade led must go off.
If tv going to standby mode chassis is not working.
You write u13 voltages before, this voltage values showing tv is standby mode.
first make sure the tv is working.https://www.badcaps.netComment
i dont understand why ,
but tv was definately on when voltages were measured ,
as the backlight was lit and i had sound via scart i/p.
but i now have no sound ?
i will try the upgrade f.w again tomorrowComment
them unplugged mains ,removed usb stick and powered up.
tv comes on as before (dark blue image backlight on)
but now with no sound via scart i/p
so i checked the voltages on u13 again
and pin 3 has no volts ,on cct its shown as write protection .
pin 6 also has no volts shown on cct as sclk clock
any ideas ? should i try to buy a main board ?Comment
tried again f/w update when fast blinking finally stops waited until backlight came on and red led went out.
Can you add photos of screen.https://www.badcaps.netComment
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by snimmitsGood afternoon,
I have a Polaroid P43D300.
It shipped with WiFi and Bluetooth.
Two weeks ago, I ran through the first time installation.
This did a full reset and went through the first time setup.
Once complete, I went to settings > sound.
selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
search completes and doesn't find any devices.
I have tried everything I can think of.
Can someone provide... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
