TCL 55s405 no backlight
  • speter
    Been around the
    • 77
    I have a TCL 55s405 TV with the back light out, there 4 wires to the backlight(pic to follow) I would like to test the led strips without taking the set apart
    How can I find out the proper voltage to power the strips?
    So far I cannot find service info on the set.
    I have sound, and picture with a flashlight
    Goshen NY, USA
  • Diah
    • Feb 2013
    • 6403
    Re: TCL 55s405 no backlight
    be brave and ask friends to help you take the screen apart. you can spend money and waiting time of led tester.. but of sure you will need the asking of friends help. this advice free of charge
      Show us the pictures of the whole backside of the TV so we can see what we are dealing with.
      Also good clear straight shots of the power supply/LED driver board.
      • speter
        Been around the
        • 77
        I figure it's pretty hard to measure the voltage out to the LED strips, because the PS shuts down very fast, so I can easily power the strips from the connector, and see if it's the leds light, or power supply is bad.
        I hear you about dismantling the panel
        Goshen NY, USA
          OK, you have 4 wires for the LED's.
          1) TV is off, set Volt meter to 200VDC scale, all connectors in place.
          2) Keep black probe of the meter on the chassis.
          3) Keep red probe on one of the 4 pin of the LED connector.
          4) Turn on the TV while watching the meter to see how high the Voltage jumps up to before it goes into shout down, then turn off the TV and wait 10 seconds.
          5) Repeat the same test on the other 3 wires.
          6) Report the result of each test.
          • speter
            Been around the
            • 77
            Top wire (black) goes to 200 -300 volts (my meter is pretty slow) Pin 9
            Second wire(red) always 0 Pin 7
            Third wire (white)always 0 Pin 4
            Bottom wire(red) goes to 40 - 65v Pin 2
            Goshen NY, USA
              You have open circuit (bad LED, bad connection between LED strips, bad wires, etc) for the LED current path to complete that is why the Voltage went up to 300V.
              • speter
                Been around the
                • 77
                Thank you!
                My daughter smashed our Vizio 55 and I am going through some TVs that a friend gave me, looking for an easy fix for a replacement.
                Tomorrow I'll try a 60 Samsung with no power, sooner or later we will be watching again
                Goshen NY, USA
                  • 12206
                  • U.S.
                  Yes, break out the sammy, backlight replacement is pretty much the hardest job on tvs.
                  • speter
                    Been around the
                    • 77
                    The Samsung had shorted LEDs. The set of 2 LED strips came in, but I had to improvise a tester with my bench power supply and a series resistor of 500 ohms to test the strips.
                    I replaced the bad strip, and let the LEDs run a couple of minutes, and put it back together.
                    I put it on the TV stand and it had a small flash of the LEds and it was out again..sigh...
                    I took it apart again, and another string of the same type(4 LED VS 5 LED) so I didn't have the part. I ended up removing 1 good LED from the first bad strip, and installing it on the other bad strip. and the set is working, it has been playing for 6 hours now.
                    Goshen NY, USA
                      • 12206
                      • U.S.
                      Nice work, now turn down the backlights, NOT brightness to as low as you can tolerate, I run my samsung on 8, it goes up to 20 but 20 will wear out your leds much faster.
                      • speter
                        Been around the
                        • 77
                        I can't get into settings yet until the remote arrives tomorrow, watching it through the demo popup for the moment.
                        Goshen NY, USA
                          • 12206
                          • U.S.
                          I operate mine with a 7 dollar philips universal remote, it seems to work every section.
                          • speter
                            Been around the
                            • 77
                            I wasn't sure which universal remote would have all of the functions, so I ordered the one for the TV for about the sane price, If I knew the universal would support every function, I would have gone that way, as this TV could die tomorrow in a worse way
                            Goshen NY, USA
                            • motterpaul
                              • Feb 2020
                              • 21
                              As long as a universal remote has a "menu" button it should work for your purposes. I found that finding the network helped a lot to getting my Vizio remote up & running again, but there was no "menu" button on the TV. Using an alternate remote "menu" button got the TV remote working again.
                              • speter
                                Been around the
                                • 77
                                TV was good till 3 weeks ago, and it burned out another LED strip, I replaced it, and it is running again. I had already bought a LED kit last time, now I finally was able to put it to use.
                                Goshen NY, USA
                                • Cornito
                                  TCL 65C715 backlight issue
                                  by Cornito
                                  Hello team,
                                  I'm back with another topic.
                                  It's a 65C715 TCL tv with backlight issue.
                                  But the problem is a bit strange.
                                  When I took this tv from the marketplace backlight didn't work but picture was ok.
                                  Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                                  Putting all back together the tv worked fine for weeks. => Contact issue??
                                  Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                                  06-09-2024, 02:24 AM
                                • cheebster
                                  iPad Pro 12.9 5th Gen Backlight Issue
                                  by cheebster
                                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                  Anyone...
                                  05-20-2025, 09:17 AM
                                • Kingfreddie
                                  LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                                  by Kingfreddie
                                  Ok.. this is the story:
                                  Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                                  This is kinda how it looked, just that mine were at the bottom of the screen:
                                  09-11-2021, 01:57 AM
                                • canadaboy25
                                  LG Flatron 24EN33TA No Backlight When Cold
                                  by canadaboy25
                                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                  03-07-2023, 12:23 AM
