LG 43uh620v 4 red lights, no Led backlight
  • sweeney1987
    • Nov 2015
    • 4
    • Ireland
    Hi guys,
    But if a strange one.
    Have one of these that will not turn on. 4 blinking red led lights.
    However when the right half of the panel is disconnected the leds come on and white and black vertical lines are displayed on the left half of the screen.
    When the right half is connected its back to flashing red lights.
    Am I right in suspecting the worst and its a new panel?
    Thought I'd ask before I bin it
    • 12206
    • U.S.
    Re: LG 43uh620v 4 red lights, no Led backlight
    Could be, maybe try checking the little ceramic capacitors on the driver board between the tcon if equipped and the panel, check in ohm mode, a probe on each end, see if any are shorted and be suspicious of any reading less than 100 ohms. Note that most of the time it's only one bad capacitor that is making others read bad too.
    • sordids999
      • May 2013
      • 2155
      Hi
      Need help with this model originally the screen had a blue tinge stripped the leds down and found most of the leds was blue but all was working,so ordered a set from aliexpress but never worked upon testing one of the diodes on one of the strips was faulty(refunded)so ordered another set from another supplier and the same issue
      Any ideas because the original set worked but was all just a blue colour
      • sordids999
        • May 2013
        • 2155
        Led voltages measuring 125v and slighlty fluctuating
          • 12206
          • U.S.
          Your original strips are bad, turned blue from being over-driven, more than likely, with the new ones, probably got a bad strip if you tested and one was bad, I've already heard of folks receiving a bad strip after 3 or 4 returns.
          • sordids999
            • May 2013
            • 2155
            Does anyone know what diodes these are ?
              Is the Cathode of that Zener diode connected directly to the + pin of the grey connector?
              • sordids999
                • May 2013
                • 2155
                I'll have to look and report back I've also looked and the writing on the diode is 6F J5
                • sordids999
                  • May 2013
                  • 2155
                  Hi budm
                  The cathode is connected to the - pin of the connector
                    Originally posted by sordids999
                    Hi budm
                    That cannot be, you can see the trace from the - pin of the connector that goes to the Anode of that Zener (top end of he Zener), but I cannot see the trace connected to the Cathode of the Zener.
                    The Cathode looks to be connected to the large copper plane which is also connected to the + pin of the connector.
