Does this seem like a gamma problem to you? Philips 42PFL3512D/12
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    Hello!
    I have already fixed some TVs in the past years, but now I am planning to buy another faulty unit for cheap. However, checking the pictures that the seller made, I can't decide if it's a Gamma problem or not.
    I'm open to learn new thingies, but I don't wanna waste too much money if it's not repairable.
    The seller sent me the 3 attached pics.
    What do you think?
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Does this seem like a gamma problem to you? Philips 42PFL3512D/12
    Looks like an AS15F IC issue to me ! That is located on the T-con
    • dominik0801
      • Feb 2018
      • 98
      • Hungary
      Yes, I have fixed that kinda problems too recently, but this color distortion seemed a bit different from what I saw before. I wasn't sure.
      But if more people agree on the AS15/AS19 chip, I will buy it and give it a try.
      • petehall347
        • Jan 2015
        • 4450
        • United Kingdom
        freeze the ic and see what happens
        • dominik0801
          • Feb 2018
          • 98
          • Hungary
          Well.. i have to buy the TV first and wait for it to arrive.
          If I buy it in the first place ofc.
          I'm just not sure if that will be the problem, thats the reason I made this thread.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4543
            • Italy - Milan
            Is it worth an expensive transport for a very old tv? Yes it is surely gamma problem, as15 if i remember. I have fixed the as15 on the 37" version. I remeber that was not a good bargain because it had channel memorization problem that needed too much expensive Philips service update, and it had no LCN organization.
            • dominik0801
              • Feb 2018
              • 98
              • Hungary
              Well, I am not buying it to use it, just to fix and then sell it. It's what I am doing nowadays to gain some extra money and practice before I get a job.
              These kinda TVs in my country are listed (and sold) for ~$100 when working.
              The bad unit is sold for ~$30, and I have an AS15 chip at home.
              So if I can make ~$70 profit, I am more than happy.
              This is the same profit I usually make after fixing then selling LED TVs with bad backlight.
              Anyways, I will most likely buy it, if you all say it seems to be a bad gamma chip, I have too much free time, and every penny profit is good.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4543
                • Italy - Milan
                But you told about.a shipping, that will cost too much i think.. and don't forget the extra problems it can have as per my previous post..
                • dominik0801
                  • Feb 2018
                  • 98
                  • Hungary
                  Oh yes, I forgot to mention, that the shipping is free (counted in the price to be more exact).
                  The other problems can ofc be annoying, I will definitely think about it again tomorrow.
                    • 12332
                    • U.S.
                    I would give it a shot, it looks like typical bad gamma chip, try freeze test as suggested. Philips are good tvs, I have one and it's every bit as good picture as a sony or sammy.
                    • janos6662000
                      Philips 47PFS7509/12 LCD TV problem
                      by janos6662000
                      Hi
                      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                      When i applied cable signal to check image, i had normal picture, but TV was restarting.
                      I downloaded original firmware and applied the update, but the problem remained.
                      From a colleague i received a "factory package software" which is a lot bigger.
                      I made another firmware update, but still did not solve the problem.
                      Somewhere on the way the error got worse, because at the moment the...
                      08-12-2025, 12:54 PM
                    • courtcircuit
                      Philips HTS8000 home cinema noise problem
                      by courtcircuit
                      Hello
                      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                      Removed each of tyhe boards
                      02-08-2025, 08:22 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • bohaboha
                      PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                      by bohaboha
                      Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                      how to fix it thanks
                      02-05-2025, 09:23 PM
                    • atkallu
                      Philips 58PUS8545 t-con problem or something else ?
                      by atkallu
                      Hello
                      I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                      See the attached image.
                      I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                      But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                      T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                      01-13-2025, 11:23 AM
