Samsung UE37D5520R stuck in boot loop
  • notallbad
    • Oct 2012
    • 1190
    From initial power (plug in socket) the tv immediately turns on and goes in a boot loop.
    Power on,red stby light, Samsung Smart logo, 4 red blinks as logo goes and Hdmi1/DVI 'Source' appears on screen but no picture (now tv box connected to hdmi1 port), tv shuts down and cycle starts again!
    First thing to try I guess is fw update, but is it safe to do so? taking into account its power cycling.
    On initial inspection the boards and connectors look good.
    Disconnect the main and the backlights come on and remain on, no power cycle/shutdown.
    Photos to follow
    Psu - bn44-00422B rev1.3
    main- bn41-01660A
    panel - LD370BGB-C1 (Samsung)
    tcon - T315HW04
  • yokoono
    • Apr 2010
    • 515
    Re: Samsung UE37D5520R stuck in boot loop
    The D5XXX series is famous for this defect. Try cooling spray on the nand memory. Before starting or immediately after starting.
    • diif
      • Feb 2014
      • 6978
      • England
      It's usually bad blocks on the Nand causing a boot loop after showing the logo, you can try an FW update but it usually needs replacing.
      • notallbad
        • Oct 2012
        • 1190
        yh, I was hoping I'd get away without having to change the nand. Main board swap is def a no-go as they are stupidly priced!
        • yokoono
          • Apr 2010
          • 515
          For nand. With this I repaired, on the same day, 3 of the D5500 series. If it starts enter the service menu and give factory reset and then update to the latest software of the manufacturer.
          • notallbad
            • Oct 2012
            • 1190
            ok so freezing the bugger worked.
            Tv on and working at the mo.
            Wot next? Do a factory reset, update???
            • yokoono
              • Apr 2010
              • 515
              Factory reset and update. The nand must be cooled either before the TV is plugged in or immediately after it has been plugged in. Try both methods. If you are lucky you can repair it without replacing the nand memory.
              • notallbad
                • Oct 2012
                • 1190
                factory reset done via service menu
                • yokoono
                  • Apr 2010
                  • 515
                  Yes.
                  • notallbad
                    • Oct 2012
                    • 1190
                    update done via online, all good so far.
                    Lucky the tv stayed on long enough for it to download and install it, phew!
                    • notallbad
                      • Oct 2012
                      • 1190
                      Still going. touch wood.
                      • notallbad
                        • Oct 2012
                        • 1190
                        Thankyou for the help.
                        Looks like its sorted it, haven't swithed it off yet though.
                        • notallbad
                          • Oct 2012
                          • 1190
                          So, on Smarthub (connected to wifi via dongle) and it started to do an auto update for smarthub, thats when the problems came back! dammit. oh well.
                          So back to reboot loop.
                          • yokoono
                            • Apr 2010
                            • 515
                            Update the stick not online.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4540
                              • Italy - Milan
                              if you freeze it again it starts well or not?
                              • notallbad
                                • Oct 2012
                                • 1190
                                yh freezing it got me back and re-installed online, not convinced it completed properly the first time, so got it back again!
                                • notallbad
                                  • Oct 2012
                                  • 1190
                                  Then in Smarthub it did the auto update again but actually worked this time
                                  • William1967
                                    • Nov 2017
                                    • 217
                                    • Netherlands
                                    Freeze Spray sometimes helps, but the bad blocks do not disappear. Personally, I have never succeeded with freeze spray. The best thing to do is to reprogram the NAND and turn off the auto update option in the menu. For reprogramming you do need good working software.
                                    • notallbad
                                      • Oct 2012
                                      • 1190
                                      what hardware and software do you use for these nands?
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        I use a GQ-5X NAND programmer. https://www.mcumall.com/comersus/sto...idProduct=4583 It comes with the necessary software.
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
