Sony KDL-55HX800 White Screen
  • henryvrensburg
    • Oct 2018
    • 104
    Hi guys
    I got the above set from a friend with exact same symptoms as Tom.molyn described in another thread.
    "The tv would power cycle initially.(no picture or sound)
    I was able to get 3.3v on the standby voltage at all times.
    The on power and high voltage would be on for the first 2 seconds inbetween "clicks"
    I was able to keep the power from cycling when the T-con board was disconnected from the Inverter.
    I replaced the LED Driver board as well as the T-CON. When I replaced the LED Driver board, symptoms were still the same.(4 x flashes, no display, clicking sound) When I replaced the T-CON, the set now comes on with white screen, I can see the set tries to respond to the remote, but no display. If I remove one of the TABS from the T-CON to the Panel, both sides come on as white, although one side is whiter than the other side. I also replaced the BAL board, with no luck.
    I do have sound, backlights and a white screen.
    DO you think I got a bad T-CON board from my supplier?
    Thank you for reading this, and any subsequent help.
  • henryvrensburg
    • Oct 2018
    • 104
    Re: Sony KDL-55HX800 White Screen
    Can someone please help.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      It is possible that you may have an incorrect Tcon.
      Post pictures of the original and the replacement Tcon clearly showing any labelling or part numbers so a comparison can be made.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4309
        • Italy - Milan
        Hey, this is not paid call center, if you want help in a hurry contact someone and pay him for a consult..
        • henryvrensburg
          • Oct 2018
          • 104
          Note taken. Sorry
            Originally posted by henryvrensburg
            Hi guys
            Can we see the screenshots of what the white screen looks like?
            Also pictures of the whole backside of the TV showing all the boards.
            • henryvrensburg
              • Oct 2018
              • 104
              Hi budm and dick_barton
              Please find herewith the photos as requested. When I looked for the T-CON, this set seems to use two different T-CON's a LJ94-0349E and/or a LJ94-03495E. I could get the LJ94-03494E, as depicted in the photos.
              Budm, the pictures of the white-screen with the division in the middle is when I remove one of the T-Con to panel tabs, and the clean white is of the picture I get with all tabs connected. The pictures with the weird circles are probably a fault with my camera. In all the pictures the display is crisp and clean "White". Even with all tabs connected the display is an even crisp white screen.
              I taped down the tabs going to the backlights after reading the thread from Tom.molyn(tape in black right corner of LED Driver)
              Thank you for reading this. I am willing to pay for any help in this.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                The two boards do look identical. Have you checked you have voltage on both sides of the fuses.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4309
                  • Italy - Milan
                  The white screen tells that 12v is present on the load side of tcon fuse, i guess, but something is wrong on the tcon because it has not all the tensions, that huge beasts of tcon appears to be very expensive, i think that your original tcon was not really faulty, but i guess for some strange and unpleasant reason the LD board tells the tcon that he has a fault and tcon sets a fault bit in its memory, so i strongly suggest to find the smaller eprom on the new board and save it because if it goes again into protection the reversing is sometime impossible otherwise, or buying a new tcon. The white screen is maybe due to screen defect (less probably) or error flag stored in BAL board, do you have changed it before or after LD+Tcon boards? One way to commonly reset an error flag in the Sony is to make an update procedure by USB.
                  • henryvrensburg
                    • Oct 2018
                    • 104
                    Hi guys
                    Thank you for your help. Like Davi.P mentioned I do have 12.51V on the load side of the T-CON fuse.
                    Davi.P I replaced the LD board first, then the T-CON and then the BAL board. So I hope I didn't carry the problem onto the new BAL board.
                    I will install the old T-CON again, and see what happens. I will also read up on the update procedure by USB
                    Will report back. Thanks once again
                    • henryvrensburg
                      • Oct 2018
                      • 104
                      Hi guys
                      I don't exactly knows how this works or what happened. I installed the old T-CON again, switched on the TV and it came on with beautiful picture and sound.
                      1. The T-CON I ordered is faulty
                      2. The Problem was the BAL board
                      Thank you everyone for your help. It's much appreciated.
                        I hope you can return that defected expensive T-CON board, you will never know what you get when you buy used board.
                        Glad you got it working.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4309
                          • Italy - Milan
                          It's a little bit mistery mechanism again today form me... my guess is: when you installed the replacement tcon it was ok and with the error flag unset so ready to show a picture but the Bal board was with its error flag already set so it does not sent an image to the tcon, a tcon power lit but with no image shows white screen, but in this moment Bal board read the error flag from the tcon and at the next boot it decided to send a picture... so if you try now the repl. tcon what happens?
                          • henryvrensburg
                            • Oct 2018
                            • 104
                            Hi guys
                            Thank you for your help in this regard. Sadly I already returned the "faulty" T-CON, but I should have tested it afterwards.
                            Thanks once again. The TV is working since Monday without problems. You guys are seriously Masters in this.
                            • Daren87
                              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                              by Daren87
                              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                              08-13-2023, 03:25 PM
                            • harp
                              White screen repairs
                              by harp
                              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                              05-13-2024, 03:43 AM
                            • Ryan.man
                              by Ryan.man
                              02-04-2025, 12:23 PM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • alltvrepairs
                              Lg TCon test pins for screen test
                              by alltvrepairs
                              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                              Appreciate your help....
                              06-13-2025, 06:33 AM
