Samsung UA55f6400 led flashing
  • provider10
    • Mar 2016
    • 52
    • South Africa
    Hi
    Have this Samsung TV (maybe elsewhere it will be Un55F, I think the UA prefix is for africa)
    on connection the red led flashes in sequences of 5.
    On disconnection of the lead between the main board and the power supply' the back lights flash and the relay on the power supply is clicking. Any Ideas please
    Jim
  • thommyX
    • Apr 2016
    • 94
    Re: Samsung UA55f6400 led flashing
    Power supply then click please check RS802 10 Ohm.
    Backlight flashing, then please replace IC9101 SLC2013M.
    LG Thomas
      Originally posted by provider10
      Hi
      Jim
      If you disconnect the cable between the power supply board and the main board, also disconnect the LED cable. Is the power relay still clicking when power up the board?
      What Voltage testing have you done on the power supply connector that goes to the main board?
      Power supply/LED driver board P/N BN44-00625B
      • provider10
        • Mar 2016
        • 52
        • South Africa
        Hi
        The power supply only trips when the LED connector is plugged in.
        What voltages do I have to check
        James
        • Nicktronic
          Samsung Power Supply Board BN44-00874F
          by Nicktronic
          Hey everyone,
          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
          Anybody...
          03-17-2025, 06:20 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • repair-it
          Need advice testing a samsung power supply board with scope
          by repair-it
          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
          07-12-2025, 11:00 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
