Bad T-con or bad panel??
  • Alternet
    • Oct 2017
    • 41
    • canada
    I have a 50UH5500 lg tv with no picture. Previously I thought it was due to the backlights. But that was resolved ( https://www.badcaps.net/forum/showthread.php?t=85170 )
    Now I have this tv with fully functioning backlights and when I turn it on I get some start up sound as well. I figured the logic board is working. I see the optical port lit up and as well I'm getting voltage to the t-con board. I also now hear a buzzing that sounds like its coming from the T-con board.
    I moved down to the t-con board and verified that there was signal going in.
    Next I disconnected the left ribbon cable going to the screen and applied power. No buzzing and I get picture on the right half of the screen. (right and left looking at the back of the tv).
    Then I reconnected the left ribbon cable and disconnected the right ribbon cable. Turned the tv on again and I get garbage on the left half of the screen and nothing on the right half. (again no buzzing)
    *Edit* the side that does not have a connection is white
    Reconnect the right ribbon (both panel ribbons connected again). I turned on the tv and get no picture again and the buzzing is back.
    At first I thought this was a display problem and a bad t-con board as both seem sides seem to be producing something. But why it not display anything when both sides of the panel are connected. Is there a short in the screen some how?
    Anyone have any insight?
  • Diah
    • Feb 2013
    • 6357
    Re: Bad T-con or bad panel??
    at this point of disconnecting the ribbon cable this should show white screen on the second half beside half picture..
    so its panel issue...
    • Alternet
      • Oct 2017
      • 41
      • canada
      On the side that doesn't not have a connection the panel is white
        • 12104
        • U.S.
        Check the little mlcc ceramic caps on the panel driver board/the board between the tcon and panel for low ohms, usually expect over 100 ohms if they are ok.
        • Alternet
          • Oct 2017
          • 41
          • canada
          I checked them for shorts (none found) but I did not ohm them. I'll check that tonight.
          • Diah
            • Feb 2013
            • 6357
            this is good sign.. then you have the ribbon cable some pins broken r shorted together on the ribbon... take them out and inspect them carefully with good loop
              • 12104
              • U.S.
              Did you get pictures of both sides of screen when you did the one ribbon test?
              • Alternet
                • Oct 2017
                • 41
                • canada
                When the left side was disconnected I got a correct picture on the right side and white screen on the left side. (the image was the lg no HDMI input screen but only half of it of course)
                When the right side was disconnected I got garbage of the left half (kind of like the attached picture but only on the left side while the right side was white)
                *Please note this picture is not my tv and just a rough example of what i saw but it was only on the half of the screen that was connected*
                • Alternet
                  • Oct 2017
                  • 41
                  • canada
                  I swapped ribbon cables and still got the same results. If there was a bad ribbon cable i would assume things would have swapped sides.
                  • Diah
                    • Feb 2013
                    • 6357
                    i just saw the photo...
                    do you removed the panel before?? so you may damaged it ??
                    ribbon need under good loop to inspect the pins of it from both sides.. good loop and light. don't trust only your eyes or glasses
                    • Diah
                      • Feb 2013
                      • 6357
                      could you show us photo on one ribbon disconnected at once
                      • Diah
                        • Feb 2013
                        • 6357
                        in this case panel okay... you have the issue at ribbon cable or T-CON.. also if you have 2 LVDS connected from MB to T-CON need to inspect them
                          • 12104
                          • U.S.
                          "Tape method" might work, example there, not in English but self explanatory, there's a ton on youtube, quite a few that involve cutting but I think this is easier and it's reversible, sometimes have to play with size and location of tape, needs to be done carefully ribbons can be delicate, it's done on the bad side with the faulty display of course: https://www.youtube.com/watch?v=Ug7FsUSQpfY
                            • 12104
                            • U.S.
                            Another ASSUMPION is what that is.
                            • Diah
                              • Feb 2013
                              • 6357
                              its not assumption.. its judgment regards to the drops info OP give over here..
                              • Alternet
                                • Oct 2017
                                • 41
                                • canada
                                I did remove the panel to fix the backlight issue. But I never saw an image even with the flashlight test before I took it apart.
                                I don't see any damage when inspecting the screen but i can't rule out that the screen may have bent to much or something along those lines.
                                I can take a picture tonight if you would like
                                  • 12104
                                  • U.S.
                                  That does NOT prove there isn't a panel fault.
                                  • Alternet
                                    • Oct 2017
                                    • 41
                                    • canada
                                    the tape method mentioned here is for a double image is it not? Would this work for no image at all? (as i'm getting no image at all when both ribbons are connected. and also getting a buzzing that sounds like its coming from the t-con board)
                                    • neilc6
                                      • Nov 2015
                                      • 1550
                                      Your other post indicated you saw the LG logo flash. You likely damaged the panel removing it.
                                        • 12104
                                        • U.S.
                                        It can work for other than double, the way I read one of your posts above is there was a distorted image on one side while doing the one ribbon test.
                                        • NWArkGuy
                                          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                          by NWArkGuy
                                          Well, I will be the first to admit that I screwed up...
                                          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                          I have 2 that I have found and have in my possession. ...
                                          10-12-2023, 10:13 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • mmartell
                                          General Questions on the Relationship Between Mainboard, TCON and Panel
                                          by mmartell
                                          My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                          I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                          And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                          01-06-2024, 01:32 PM
