Sharp Aquos Quattron LC-52LE810UN odd issue
  • 280zx
    • May 2020
    • 43
    • US
    If TV is upright TV runs for 14 minutes then turns off. At this point it tries to come back on every 5 seconds. At the 1 minute mark it came on for 14 minutes again and keeps repeating this process. When I place the TV face down with the back removed it runs fine. I've had the TV on this way for over 2 hours with no power cycling. Both the power supply and main board have been replaced. Any help please.
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp Aquos Quattron LC-52LE810UN odd issue
    disconnect some of the leds string at the connector and see what happens.
      Same TV in this thread?
      https://www.badcaps.net/forum/showthread.php?t=62351
      • 280zx
        • May 2020
        • 43
        • US
        Tightened all screws and checked all connections. As soon as I lift it upright it turned off within a minute. Unplug unit set TV face down and re plugged and it's working again.
          Try tapping on the boards with wooden stick or plastic stick while TV is facing down, also try moving the cables around to see what happen. Also did you try post #2?
          • 280zx
            • May 2020
            • 43
            • US
            Tapped away while TV facing down no change. TV still going strong. Might have to install over bed to watch on ceiling.
              How about post #2 while TV is upright?
                • 12274
                • U.S.
                Had a sony did the same thing, a replacement mainboard fixed it.
                • 280zx
                  • May 2020
                  • 43
                  • US
                  I have 2 main boards and it's doing it with both. I tried to putting the main board upright while the TV was face down TV stayed on. I had a similar problem with a Samsung and it was the main board.
                    • 12274
                    • U.S.
                    Check all solder joints on powerboard, look closely at the joints of components on heatsinks and transformers as they take the most abuse, sometimes a joint looks good but can be bad or loose, some will actually wiggle when loose/bad.
                    • 280zx
                      • May 2020
                      • 43
                      • US
                      I've fixed a main board with similar issue by baking in the oven for 10 min. Not sure if it would damage the power supply board if I baked it?
                        • 12274
                        • U.S.
                        LOL, baking the powerboard would be a first that I've heard of, they bake mainboards to reconnect solder of bga chips but don't always work or last very long, that's IF the board keeps overheating, some have used a fan solution after baking with a lot of success.
                        • 280zx
                          • May 2020
                          • 43
                          • US
                          Not sure it's the power supply board as I had it standing upright while the TV laid face down. TV working fine for over 10 minutes now. Going to try the main board next.
                          • 280zx
                            • May 2020
                            • 43
                            • US
                            Now have the main board in upright position for over 10 minutes with no glitch. Could it be the T-con board?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4456
                              • Italy - Milan
                              With the screen face down turn it on with mainboard unscrewed in upright pos. then bent it gently, if it stop working a reballing is needed, if its not the mainboard try the PSU. using gloves or better a wood spoon.
                              • 280zx
                                • May 2020
                                • 43
                                • US
                                Turn out that the power supply that I had gotten was bad. Replaced the power supply board and that fixed the problem.
                                • claytongarcia
                                  Issue with Sharp LC-42SB45U
                                  by claytongarcia
                                  I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
                                  Has anyone dealt with this issue before?​
                                  03-10-2025, 07:27 PM
                                • sefoster
                                  Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                  by sefoster
                                  I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                  11-20-2022, 09:29 AM
                                • scubacamper
                                  Sharp Aquos LC-70C6400U Half Screen Dark
                                  by scubacamper
                                  I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                  Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                  when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                  05-03-2025, 12:19 PM
                                • leorivers
                                  Issue with Sharp LC-47SB57UT
                                  by leorivers
                                  I bought Sharp LC-47SB57UT 6 years ago. I had to have a vhf antenna to pick up one local station(koco channel 5 OKC). It has worked great up until a week ago. Sometimes I couldn't get channel 5, now I can't receive it at all. I can hook up a digital convertor box I have from another tv and can receive channel 5.
                                  I think the antenna and cable is ok. I doubt that this would be the tuner board or possibly something else.
                                  Any ideas where I should start?​
                                  10-24-2024, 03:11 AM
                                • klassic
                                  Sharp Aquos LC-60LE635E three blinks
                                  by klassic
                                  Hi community,
                                  I will describe my problem with a TV in those short following terms to be the most precise :
                                  What i have :
                                  power board DPS-162KP-1
                                  main logic board QPWBXF733WJN2
                                  symptoms :
                                  white led light logo at startup,
                                  after 2 minutes, blinking 3 times a row, repeating
                                  no backlight (and apparently no picture, checked panel with flashlight)
                                  no startup sound
                                  powerboard investigations :
                                  1-2 PNL : 0v
                                  3-4 GND
                                  5-6-7-8 UR : 13.15v
                                  9-10-11-12...
                                  10-24-2023, 01:39 PM
