Soniq S55V16A-AU stuck in standby
  • samsonn
    • Jun 2020
    • 14
    I've got a 55" Soniq LED TV which is stuck in standby mode (initiator LED on, but no picture/sound/backlight). It will intermittently start working again for a few days or weeks, but it has been months since the last time it turned on. I've seen a lot of similar issues with Soniq TVs that were fixed by updating the firmware, but I need to turn it on to update the firmware so no luck there.
    I've taken the back off and visually inspected it but everything looks fine. No exploded capacitors or signs of overheating etc. All of the 1117 regulators on the main board were outputting 3.3v so don't think they're the issue.
    The voltages a the main board power connector were:
    PSON 3.3V
    5VS 5.2V
    5V 5.2V
    12V 0V
    BLON 0V
    ADJ 1.55V
    OPC 0V
    Most of them look normal I guess? Feel like the 12V rail should be 12V but the PSU might just be waiting for a signal from the main board to turn in on. Don't really know the best way to verify one way or another.
    Not sure what my next steps should be, any advice is greatly appreciated.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Soniq S55V16A-AU stuck in standby
    There are 13 wires in connector CON 2.
    Could you list them for example as below :-
    Code:
    No.  Label  Reading
    Pin 1 +5V   4.8V
    Pin 2 GND   0V
    Pin 3 GND   0V
    Pin 4 BL   2.5V
    What dc voltage do you have between the two legs of the large capacitor
      1) Please provide the result in the format as requested by dick_barton.
      2) PS-ON (3.3V as reported) for turning on the rest of the power supply is present so the switched 12V should be present but it is not.
      3) BL-ON is reported as 0V so that is missing also.
      4) I need good clear straight shots of the whole bottom side of the power supply board.
      5) I need the closed up of the power supply connector so I can see pins' label.
      6) I need the pictures of the whole backside of the TV showing all the boards so I can see how all the boards are connected together.
      • samsonn
        • Jun 2020
        • 14
        The voltage across the large capacitor was 382V.
        Here is the pinout and voltages of the mainboard connector.
        Code:
        Pin 1   PSON  3.3V
        Pin 2   5VS   5.2V
        Pin 3   5V   5.2V
        Pin 4   5V   5.2V
        Pin 5   5V   5.2V
        Pin 6   GND   0V
        Pin 7   12V   0V
        Pin 8   12V   0V
        Pin 9   BL_ON  0V
        Pin 10  GND   0V
        Pin 11  ADJ   1.55V
        Pin 12  OPC   0V  (Not connected to anything?)
        Pin 13  GND   0V
        Pin 14  GND   0V
        Pin 15  GND   0V
        Pin 16  GND   0V
        And the pinout at the other end on the PSU (CON2)
        Code:
        Pin 1   12V
        Pin 2   12V
        Pin 3   SGND  (Connected to GND on the main board)
        Pin 4   SGND
        Pin 5   SGND
        Pin 6   5V
        Pin 7   5V
        Pin 8   5VSB   (Connected to 5VS on the main board)
        Pin 9   PS/ON
        Pin 10  BK/ON  (Connected to BL_ON on the main board)
        Pin 11  ADJ
        Pin 12  SGND
        Pin 13  SGND
        I've attached the requested photos, let me know if they're clear enough. I can pull out my good camera and have another go tomorrow if necessary.
        Cheers
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Is the 3.3V at PSON present with the mainboard disconnected from the power supply and nothing connected to it? I believe some power supplies need PSON taken low to bring up the other supplies.
          • samsonn
            • Jun 2020
            • 14
            Nope, without the mainboard connected the only voltages are 5VSB at 5.2V and ADJ at around 0.75V. Everything else is 0V.
              • 12199
              • U.S.
              Try with tv UNPLUGGED from main power, unhook cable from powerboard to mainboard, leave it off, on powerboard, use about a 1k resistor to jump 5v SB pin to PS/ON pin and another resistor from BK/ON pin to 5v SB, plug power into powerboard, see if you have the expected voltages and see if the backlights come on and stay on.
                1) So PD-ON is present, 3.3V as reported and the PFC boosted Voltage is also present, 382V as reported.
                2) But the 12V and LED power supply, generated by transformer T2, is not working so you need to check the resistor and the capacitor (check capacitance) that I marked.
                3) I also need the P/N of the IC that I marked so we can see if the VCC is present to run the IC or not.
                4) I also need better focused pictures of the whole top side of the power supply board because I cannot read the designators of the resistor and the cap.
                Power supply board PCB: MAGMEET MP420D-QG3
                • samsonn
                  • Jun 2020
                  • 14
                  Hey so I've found what the problem was. The transistor below the capacitor budm marked in his images had been knocked and the pcb pad on one of it legs had been ripped up a little bit. See the attached image. I soldered a wire from the leg to a nearby pad and the tv came back to life.
                  Feel kinda silly I didn't notice it earlier, could've saved everyone some time. Thanks everyone for you help.
                  Cheers
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Another one saved from the scapheap.
                      Cheers
                      I cannot tell from picture as to which Transistor that is.
                      So did someone work on this board before you?
                      I am glad you are able to see it and fix the problem.
                      • Eggbert43
                        Soniq E40S12A-AU Stuck In Standby
                        by Eggbert43
                        Hello everybody,
                        My Soniq E40S12A-AU (Australia) won't stay on when coming out of standby.
                        Upon the power button being pushed to come out of standby, the red standby light starts flashing, then the Cinavision splash screen appears for a brief second before screen going black, & within another ten seconds the TV goes back into standby; with a solid red light.
                        I have tried flashing the original & new firmware but upon completion I get the same behaviour as above, with the addition of an audio chime I assume to be notifying me of a successful firmware...
                        04-02-2021, 02:55 AM
                      • PNI E.
                        Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                        by PNI E.
                        Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                        03-17-2025, 04:23 AM
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • AleMonti
                        LG 55EG910V - no power and no standby light
                        by AleMonti
                        I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                        I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                        The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                        After checking the basics I did the following:
                        • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                        11-04-2024, 05:02 PM
                      • lego1234567
                        LG 32LB1R - stuck in standby mode
                        by lego1234567
                        Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                        What could be the problem ? Thanks...
                        01-21-2024, 03:39 AM
