Hi all i am battling with this issue and was doing voltage tests and came across a zener diode which has no voltage across it,it is 5v6B on the power supply,am wondering is somebody could help me in the right direction,i am still new at lcd tv repairs,i used to repair crt tv's,i will greatly appreciate any advice given
Sony KLV32U300A power on/off with 2 times blinking led
Tags: None
Re: Sony KLV32U300A power on/off with 2 times blinking led
I just lift a leg and check out of circuit, you can just clip a leg if accessible and if it's ok just solder the leg back together. -
We need good clear pictures of the backside of the TV showing all the boards, and pictures of each board so we can see what we are dealing with.Never stop learning
]214576
]214577Attached Filesif you find these attachements useful please consider making a small donation to the site
Ok will place them when i get home,and thanks guys for your input so far.Comment
hey op, is it just a at the end of the model number or ac or act? three different models and trying to get the right info for you.Comment
Hi jostewcrew the service manual is posted above,3 different modelsComment
So what Voltage are you getting at the three connectors on the cold side of the power supply when TV is plugged in but not turned on and when power switch is activated?Hi all i am battling with this issue and was doing voltage tests and came across a zener diode which has no voltage across it,it is 5v6B on the power supply,am wondering is somebody could help me in the right direction,i am still new at lcd tv repairs,i used to repair crt tv's,i will greatly appreciate any advice given
As you can see the pins are labeled with name for each pin so you must put down the connector pin name and follow by the Voltage reading for each pin so we can easily see whit it has and does not have.
What is the designator of the Zener diode in question?
I attached the schematic of ADP-154AF power supply for the 32"Attached Filesif you find these attachements useful please consider making a small donation to the site
Sorry budm,i could not get round to testing when i was home but will definitely do it later when at home,and the zener is on the cold sideComment
That diode ZD131 is part of protection circuit that will shut down the power supply if it detects fault on +15, +24, and PWR_30 supply lines.
That Zener will not conduct until output of IC5 pin 7 goes high above 5.6V for the Zener to conduct which then will cause SCR151 to turn on and shutdown the power supply, you can look at the schematic to see how it works.
I did not error blinking codes in t he service manual.
Right now you need to make Voltage testing on the connectors I requested.Last edited by budm; 06-24-2020, 02:43 AM.Never stop learning
Ok thanks budm i will do it when i get home laterComment
On standby: C201 Pin 1+2=GND 3=0.12V 4=0.12V 5+6=GND 7+8=PWR PANEL 9+10=GND 11+12=0.8V 13=GND 14=0V
C202 Pin1=4.17V 2=0V 3=4,18V 4,5+6=GND 7+8=4.18V
C203=No Voltage
TV on: 201 Pin 1+2=GND 3=5.63 4=5.83 5+6=GND 7+8=5V 9+10=GND 11+12=14.60 13=GND 14=32V
CN202 Pin1=0.2V 2=0V 3=4.1V 4,5+6=GND 7+8=4.1V
CN203 Pin1to6=0V 7to10=24.4VComment
So you are not providing all the pin names and Voltage readings to go with it. For example:On standby: C201 Pin 1+2=GND 3=0.12V 4=0.12V 5+6=GND 7+8=PWR PANEL 9+10=GND 11+12=0.8V 13=GND 14=0V
C203=No Voltage
C201 @standby
Pin 1+2=GND
3=0.12V What is the pin name?
4=0.12V What is the pin name?
5+6=GND
7+8=PWR What is the Voltage reading?
9+10=GND
11+12=0.8V What are the pin names?
13=GND
14=0V What is the pin name?
So do it all over aging to show us what they all are.Never stop learning
C201@standby Pin 1+2=GND
3+4=pwr 6v=0.12v
5+6-GND
7+8-Pwr panel=0v
9+10-GND
11+12-Pwr 15v/1.6A=0.8v
13-GND
14-Pwr 30v/2mA=0v
C202@standby-Pin1-Ps on=4.17v
2-pwr err det=0v
3-4vsb/1.2A=4.18v
4,5+6-GND
7+8-4vsb/1.2A=4.18v
C203@standby Pin1to 6=0v rail-7to10=24v rail=0v
Then Tv on voltages according to previous postComment
Sorry pin 1 to 5 is 0v rail and 6 to 10 is 24v rail on C203Comment
Hi i just would like to find out if the regulator voltages are correct so if anybody could please give me info i will be grateful
INH=5.78v
I=5.78v
O=5.06v
A=1.22vAttached Filesif you find these attachements useful please consider making a small donation to the site
by YasaChHello...
my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
i opened the back cover no sign of damage on the powery suply or motherboard
when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites2 Photos -
by NolesFanI know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
by androriparaHello everyone,
i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led... -
by ahmarzoI have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery... -
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... - Loading...
