LG 65UH615A - Backlight on with No Picture Black Screen
  • jimmyboy111
    • Feb 2013
    • 32
    • US
    you press the power button and get the backlights so the mainboard must be functioning at some level .. standby 5v is normal and power supply rails are clean and normal
    .. I am trying to see if I get sound by pressing changing inputs but not luck .. 12v is on the t-con and I have swapped the power and t-con board already which leaves me at the mainboard again .. the main was swapped as well and I got the same black screen no image so either it is the main or I got a board with the same problem as the original
    .. guessing maybe bad flash or cpu problems on main .. if anyone has any clues send me a message
  • Diah
    • Feb 2013
    • 6357
    Re: LG 65UH615A - Backlight on with No Picture Black Screen
    check yours lcd panel.. if you disconnect one side ribbon cable between t-CON and panel you will see half picture on one side of the panel.. also on the panel boards you have U ribbon cable can remove one on each side to have 3/4 of screen side image... all will goes to one result panel broken some where
    • jimmyboy111
      • Feb 2013
      • 32
      • US
      Did that .. disconnecting left and then right of t-con .. no real difference
      .. panel boards? do you mean the panel driver chips on the edge of the glass? .. I havent looked at those yet .. good idea .. I had someone spill soda on a screen and screw those up before since it would run to the bottom of the screen
      • jimmyboy111
        • Feb 2013
        • 32
        • US
        checked the driver boards on the edge of the glass panel .. all look normal no corrosion or dirty connectors .. checked again with scope .. notice that the T-CON main processor is not running normal temp .. dead although there is clearly 12v on the main fuse and the diode input on the board
        .. unplugged all the edge panel drivers and now it runs but now the mainboard does not turn on the backlight
        .. connected to left alone and the t-con runs but no backlight .. connecting to right driver board and all the voltages get dragged down
        .. there is only a few caps and a single ST Micro controller chip on the driver board but I cannot find any info on the SMD code .. any help would be appreciated
        PHOTOS
        https://imgur.com/a/1C6vFlc
          No cables between T-CON and the Tab bonding board, then check the resistance of all the MLCC (Multi Layer Ceramic Cap) on the tab bonding boards to see if any of them show low resistance (<100 Ohms).
          • diif
            • Feb 2014
            • 6978
            • England
            It's an I2c eeprom probably holding EDID information. You can check the voltage at the VCC pad or check the resistance between that and ground. It's more likely to be a shorted capacitor.
            • jimmyboy111
              • Feb 2013
              • 32
              • US
              Thanks Bud .. yes did that all showed normal no shorted ceramics .. just checked there is a short to the ground test pad on the board to pins 1 2 3 and 4 on the chip so it is toast .. turned on the board one more time and the 3.3v test pad on the driver board shows 1v but the chip doesnt seem that hot
              Diif .. is EDID is unique to this specific TV or could I rip one off another broken panel?
                But pin 1,2, 3, and 4 are connected to Ground plane as you can see the traces. What is the resistance between GND and VCC test pads?
                • jimmyboy111
                  • Feb 2013
                  • 32
                  • US
                  When your right your right .. kind of strange having a micro with 4 pins all connected I didn't look close enough .. pulled out a better ohmmeter with sharper probes and I found 3 shorted caps .. any suggestions on swapping caps so close to tab bonds? I guess maybe some low temp solder and a tiny iron
                    • 12129
                    • U.S.
                    Could be only one is shorted, remove one on an end, see if it's shorted out of circuit and see if other 2 are still shorted.
                      Show us the pictures fo the suspected bad caps.
                      I use 40W wide tip soldering iron and add Lead solder to each end of the cap to remove it.
                      • jimmyboy111
                        • Feb 2013
                        • 32
                        • US
                        You guys are on a roll today Attaboy .. I put a meter on low ohms and found the ceramic on the driver board with the lowest value removed it and the others opened up guess they were in parallel .. swapped in a ceramic cap from junk board and now it's firing up .. I was about to give up this one
                        .. the LG 4K tv's have bad ceramics in them I wonder how long before the next one shorts out
                          MLCC failure mode is shorts circuit or low Ohm mode, this happens to just about all brands of TV not just LG, you will see lots of threads about bad MLCC, we all have lots of experience about these failed MLCC.
                          BTW, if you did not use good meter and good probes then we would not have found out the cause of the problem, remote troubleshooting requires valid data, I am glad you did find good meter and probes.
                            • 12129
                            • U.S.
                            Nice save, nice big ole 65 incher too.
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
                            • DaniK
                              Acer Aspire E5-574-52RH - black screen
                              by DaniK
                              I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                              Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                              Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                              Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                              The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                              Symptoms are:
                              - random black screen after displaying Acer logo...
                              02-21-2024, 06:27 AM
                            • turmix
                              AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                              by turmix
                              Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                              The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                              At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                              During another reassembly, I made a mistake, and...
                              01-29-2024, 03:48 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • EazyBone
                              Element E4AA70R black screen shows picture
                              by EazyBone
                              On this TV I got black screen with with picture.
                              Tested the LEDs and they work.
                              Had a hunch that this was similar to a ONN tv thread I found and wanted to post about this to possibly help someone else.
                              The capacitor by the LEDs is bulging, 450v 10 uf. I suspect this is the cause. Will post results after replacing the capacitor. You could just replace power board as well I assume.
                              https://www.badcaps.net/forum/showthread.php?t=110615
                              Will post results when capacitor arrives...
                              10-13-2023, 05:07 PM
