Sony Oled 4 or 6 blinking red lights
  • ransome
    • Nov 2013
    • 20
    • usa
    I started a thread about a year ago , just wondering if anyone has figured out how to fix one of these issues. Xbr65a9f , xbr65a8f or xbr65a1e
    some of these will work for a minute then just turn off , the one thing they have in common mostly is a thin line on the screen
    thanks Gregg
  • brucetv
    • May 2015
    • 281
    • united states
    Re: Sony Oled 4 or 6 blinking red lights
    Unfortunately the problem seems to be panel problems and Sony will only cover it during the one year warranty. Not good for business as most of my customers swore they will never buy a Sony again. It's a great picture in most cases but that vertical line is so annoying it just makes you want to kill the CEO of Sony for spewing out this overpriced crap.
      It looks like these OLED panels are LG panels.
      • ransome
        • Nov 2013
        • 20
        • usa
        Yes these are Lg panels , but Sony uses their own boards and firmware. I was just hoping that someone somewhere had figured a fix for the 4 or 6 blinking light issue
        thanks Gregg
        • jostewcrew
          • Mar 2020
          • 79
          When the Main board or T-Con board is replaced, or if you disconnect an LVDS cable and power up the TV, you will get no video on the screen.
          The only indicator you have to go by is the front panel LED.
          The TV may require a software download to re-establish communications between the two boards and also to the LCD panel.
          according to the flashes: 4 flashes indicate the LD/BCM board..... 6 flashes indicate the panel backlights.... both are linked to the LD board so id say that is the best place to hone in on first. Second would be the power supply board, third would be the main board and then finally the lcd panel itself.
          • Diah
            • Feb 2013
            • 6376
            the talking over here on OLED Module not LCD
            • jostewcrew
              • Mar 2020
              • 79
              my information comes directly from the ops' model listed in the discription. not quite sure what you mean?
              • jostewcrew
                • Mar 2020
                • 79
                my apolgies...went back and looked at the source material and it indictaes that this troubleshooting is for led lcd.
                on another note....the service manual for the model listed indicates the most likely board for the 4 flash is the tcon (panel module) and the most likely for the 6 flash is the g* board. with the stationary line there, it indicates the most likely board being the b* board which happens to be the 2nd most likely board for the 6 flash led. the second most likely issue for a 4 flash is the oled panel itself.
                • jostewcrew
                  • Mar 2020
                  • 79
                  hope this helps you guys:
                  • ransome
                    • Nov 2013
                    • 20
                    • usa
                    which boards are the b and g and d
                    thanks Gregg
                    • jostewcrew
                      • Mar 2020
                      • 79
                      thanks Gregg
                      sry...should have included this.
                      • ransome
                        • Nov 2013
                        • 20
                        • usa
                        thanks , that helps
                        where are you getting the service manuals . is it still emcompass or through Sony?
                        thanks Gregg
                        • jostewcrew
                          • Mar 2020
                          • 79
                          thanks , that helps
                          thanks Gregg
                          i source through various sources...manualslib, eservicemanuals,pt-electronica.... these happened to come from a friend of mine via son asp
                          • j3scott
                            • Jul 2021
                            • 3
                            This table looks more applicable to LCD panels, not OLED?
                            • mdonn27
                              • Oct 2023
                              thanks , that helps
                              thanks Gregg
                              did you end up getting your TV working and running without shutdown? Would appreciate if you shared how you did it if so!
                              • Audeze
                                Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                by Audeze
                                I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                Does...
                                10-06-2024, 08:54 PM
                              • bialag
                                Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                                by bialag
                                I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                                Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                                03-25-2025, 05:56 PM
                              • Watson306
                                6 Red Blinking lights (left side darker) on Sony KD-49XE8396
                                by Watson306
                                I've got a Sony KD-49XE8396 TV that will switch on show the Sony logo then the Android logo and then switches off, and then blinks red 6 times.
                                I've read that this is the backlight, and during it showing the initial logos I can see that the left side is definitely darker.
                                I've also read that you can bypass the error to get it working but I'd prefer to fix it if at all possible. Any help would be appreciated.
                                Many Thanks in advance.
                                11-01-2022, 05:33 AM
                              • YasaCh
                                Sony kdl 40p5500 red light keeps blinking 3 times
                                by YasaCh
                                Hello...
                                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                i opened the back cover no sign of damage on the powery suply or motherboard
                                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                07-07-2025, 11:53 AM
                              • shahnld
                                Sony kdl 65xg9505 green amber blinking
                                by shahnld
                                Good Day.
                                I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                01-03-2024, 03:05 PM
