Daewoo DT-42A1 not storing settings
  • Trevtron
    • Apr 2015
    • 124
    • Portugal
    A friend asked me to look at this old-school plasma set.
    It runs fine, still has a good image considering its age but every time it is switched off (at the mains) it "forgets" all its settings.
    I've had a good look around, was hoping to find a lithium or backup battery, or a storage capacitor but there's nothing obvious on the psu or main board.
    Anyone had dealings with these? I know it's not worth a fortune but it would be a shame to bin it.
    TIA.
  • R_J
    • 9623
    Re: Daewoo DT-42A1 not storing settings
    What settings? Clock, channels? If you turn it OFF "at the mains" that is the same as unplugug the tv. What happens if you just turn it off with the remote or front power button?
    • Trevtron
      • Apr 2015
      • 124
      • Portugal
      Hi R_J. There is a mains on/off switch on the set so yes, the same as unplugging it. There is no 'standby' button and also no remote (but I will try and set up a universal and see how that goes). It's the channel settings that is the most noticable/irritating (yes, still using analoge tuner lol!) but it's like it does a factory reset each time it's powered down as it comes on every time with the language selection menu - even after switching off for just a few seconds.
      • Trevtron
        • Apr 2015
        • 124
        • Portugal
        OK, I found a universal remote, unfortunately it's the same if the set is put into standby - as soon as it comes back on again the tuning has been lost and the language selection comes up again
        • RetroComputingGrotto
          New Toy UNI-T UTi260B - What Settings?
          by RetroComputingGrotto
          I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
          After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
          I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
          09-02-2025, 08:36 AM
        • i440bx
          Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
          by i440bx
          Hey there,
          I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
          The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
          It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
          As written above, I plugged in a new CMOS cell and checked...
          08-19-2024, 02:28 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • chopduel
          Bad mains power causing TV malfunctions?
          by chopduel
          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
          • TV would randomly turn off then back on.
          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
          12-29-2024, 03:20 AM
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
