Bad mains power causing TV malfunctions?
  • chopduel
    • Jan 2024
    • 7
    • Europe
    I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
    Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
    • TV would randomly turn off then back on.
    • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
    • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited success as well. Sometimes it worked, sometimes we still had to wait.
    Eventually after a few years, one day the TV turned off and wouldn't turn on at all. After some unskilled attempts at replacing the power board and such, I gave up and threw it away.
    Now we bought a new LG OLED TV (65" B4), and yesterday we suddenly noticed a similar phenomenon. The TV display froze for a few seconds, then it turned off, the LED blinked a few times and then it turned back on.
    I'm now worried that there is some issue with the mains power in my apartment which is eventually going to destroy my new TV as well.
    The TV is connected to an extension cord which is shared with an anker multi-port charging station (which is mostly used only at night), and that extension cord is in turn connected to a different extension socket which is shared with the robot-vacuum charger and a couple of USB ports of which only one is used for a super low-power IKEA night lamp.
    I've used a device to check this socket for ground and/or reverse polarity issues and it seems that everything is working fine in this regard. In any case the new TV's mains cable does not have a ground leg.
    Any kind of advice would be very welcome,
    Thanks in advance!
  • EazyBone
    • Jun 2023
    • 1352
    • United states
    I mean, try to plug it into a dedicated outlet and then see what happens. Seems like easiest test to do. But also go buy 5 yr warranty
    • petehall347
      • Jan 2015
      • 4433
      get the electrical supply and installation checked by a competent person
      • chopduel
        • Jan 2024
        • 7
        • Europe
        Can you please clarify? Which electrical supply are you referring to? The one inside the TV?
        • petehall347
          • Jan 2015
          • 4433
          apartment
          • chopduel
            • Jan 2024
            • 7
            • Europe
            apartment
            Any suggestions for what to look for? Voltage drops, voltage spikes?
            I'm not an electrician so any guidance would be very helpful
            • bykanovm
              Thinkpad W541 Works from the mains and charges the battery only when it is turned off
              by bykanovm
              Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
              If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
              If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
              even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
              Also, the laptop does not turn on without...
              04-02-2025, 02:45 AM
              Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-06-2024, 08:58 AM
            • peter99
              HP 245 laptop not charging when turned on
              by peter99
              helo everry body!!!
              My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
              - If not power on, battery charge ok.
              - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
              The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
              I replaced the BQ 25A charging IC but the device only charges when not turned on.
              everyone please help me with solution, what should i do ?
              thanks a lot !!!!!...
              04-04-2025, 07:35 AM
            • Dannyx
              Help with LNK304PN power supply (Whirlpool auto washer)
              by Dannyx
              Good day folks. A pretty simple job turned into a great confusion today. My boss sent me over to a friend of his to have a look at his washing machine which stopped working entirely. He opened it up himself and presented me with this lovely board before I got there. I took it back to the shop and instead of immediately hopping online and trying to find info on this board, I opted for a more hands-on approach and troubleshooted on my own.
              The layout seemed pretty simple overall and it wasn't hard for me to spot the issue: the power supply in the lower-right corner had popped. I noticed...
              08-11-2021, 10:16 AM
