LG 42LB552v no power red light blink twice then off
  • elpiko
    • May 2020
    • 25
    • Seychelles
    Hi I have an LG led tv when power on the red light come on then blink twice then turn off. The screen is completely blank no backlight or image shows. I've check the power supply everything seems ok.
  • elpiko
    • May 2020
    • 25
    • Seychelles
    Re: LG 42LB552v no power red light blink twice then off
    Ok so I've changed two opto in the power supply.
    When I connect the tv the backlight comes on but no image and the two blinking of red light remains then goes away. If I keep finger on power for few seconds the backlight turn off and red light stay solid but I hear a rapid clicking sound in the power supply.
    If I turn tv on again backlight comes on two flashing red light then goes off and the clicking sound stops.
    • Repair_dane
      • May 2020
      • 42
      • Danmark
      Try to unplug the main board and turn it on again.
      Do the LED's come and stay on?
      • elpiko
        • May 2020
        • 25
        • Seychelles
        since the power switch is on the main board i wont be able to turn on the tv with the main board disconnected. but ive tried to power it on without the tcon board and the backlight does not turn on.
        ive tested all the voltage on power supply going to the main board all are fine.
        the strange thing is that the standby light will flash twice then completely off but the back-light remain on till i turn it off from power button then the standby light will stay solid red
          1) Please attach good clear pictures fo the whole back side of the TV showing all the boards so we can see what we are dealing with?
          2) Your post #1: "I've check the power supply everything seems ok" does it mean all the Voltages and the control Voltages are OK?
          3) Your post #2: "Ok so I've changed two opto in the power supply." Are they bad? What section of the circuit are they used in?
          • elpiko
            • May 2020
            • 25
            • Seychelles
            there are two sets of pin one says power on this all volatage is ok. the one that says drv on i have not test yet.
            as for the opto i was not getting any reading from one of them, also i was reading some forum and a guy got the solution by changing the opto so i tried changing both and now i have backlight but no images
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              What voltage do you have on either side of the fuse on the Tcon board
              • elpiko
                • May 2020
                • 25
                • Seychelles
                im gettting almost no voltage on these around 0.8v but the one next to it has 8v the fuse is ok ive tested it. check image
                • Repair_dane
                  • May 2020
                  • 42
                  • Danmark
                  Main board is the green one that controlls inputs, sound and video. The other one is your PSU. power supply board.
                  • elpiko
                    • May 2020
                    • 25
                    • Seychelles
                    yes i know the main board is the green one and the other one is psu and the small one that panel connect to is the tcon.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      With the set powered off check the resistance of the fuse. It should read close to 0 ohms.
                      Did you take the voltage measurent across the fuse and not from chassis to one side of the fuse and then chassis to the other side?
                      • elpiko
                        • May 2020
                        • 25
                        • Seychelles
                        i tested the fuse and get continuity so its good also i check the voltage from both side of the fuse and not from chassis.
                        i dont think its the power supply im suspecting the main board to be faulty. problem is i live very far and shipping is costly and dont have the luxury to order a main board to test i have to make sure before i do as i cannot return it after.
                          • 12273
                          • U.S.
                          It's still not clear, we are looking for about 12 volts on each side of the fuse when acting correctly, for this you put red + probe on each side of fuse and the black - probe goes to chassis ground.
                          • elpiko
                            • May 2020
                            • 25
                            • Seychelles
                            ok ill check that tomorrow and revert back on the findings
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • ipatch
                              troubleshooting microsoft surface pro 4 no power no led charge light
                              by ipatch
                              hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                              10-05-2023, 11:59 AM
                            • russpall
                              LG 39ln540v - red light flashes twice, no power to LED driver?
                              by russpall
                              Hi there,
                              I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                              The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                              08-27-2024, 01:07 PM
                            • Acnologia
                              Lenovo Ideapad B50-80 (80EW) - LA-B091P - Power Blink Orange light ?
                              by Acnologia
                              Hello to all,
                              New laptop to troubleshoot.
                              It power on , fan spin , no image, no light on caps lock.
                              Power light is blinking orange .(not an error blink) just orange blinking.
                              You press power button again , again it powers up fan spin ,and then cuts off.
                              What i tried?
                              Removed everything only board, and external monitor left on , and powered with bridge to the power button (in case it was the problem)
                              Tried reset RAM ,new RAM , re-flashed bios dump ,from thread that i found here again all the time the same behaviour. With any kind...
                              10-12-2022, 02:56 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
