LG 65UH5500-UA common problem?
  • notallbad
    • Oct 2012
    • 1190
    Re: LG 65UH5500-UA common problem?
    Originally posted by hatinglgrightnow
    have to take off the plastic frame and "metal bar" on the bottom of the tv by driver board and then the panel just lifts up, if that makes sense.
    After writing that realised the OP has already disassembled his to replace leds. So already knows how to do it.
    • notallbad
      • Oct 2012
      • 1190
      No bought it retail end of 2017.
      Swap the ribbon and let us know the results, of course only one half of the panel with work but at least it will put your mind at rest knowing its as simple as replacing the ribbon.
      We're all waiting in suspense!
      • hatinglgrightnow
        • May 2020
        • 24
        ahhh have to work up the courage to swap from the working side to test. the guy from ebay shipped today hopefully those come in soon!
        • Diah
          • Feb 2013
          • 6614
          i don't think this pin the problem, see the tab of the effected side.. you may have U ribbon cable on it.. if yes then its just fitting it again,
          • hatinglgrightnow
            • May 2020
            • 24
            by tab do you mean the tab connecting it to the glass panel?
            • Diah
              • Feb 2013
              • 6614
              NOT this, on the board... take out the speaker and the metal cover of the effected side.. see are there U ribbon cable as its 65 it may have 2 or 3.. many UHD used U ribbon.. hope yours too
              • hatinglgrightnow
                • May 2020
                • 24
                There are no U ribbons that I can see. Only those 2 ribbons I showed and another ribbon that is not attached to the glass panel.
                Even after removing everything when changing the LED strips, there were no other ribbons besides the ones seen here. Moved the speakers in this pic.
                • Diah
                  • Feb 2013
                  • 6614
                  of course you have U ribbon..i can see one on both side its the brown color you may have another one hidden on the photo... this U ribbon.. seat them correctly on the effected side
                  edit i marked them on yours photo
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    U ribbons see photo
                    • hatinglgrightnow
                      • May 2020
                      • 24
                      Thank you for marking them! Yes there are two of them none hidden, I will try to mess around with them.
                      • hatinglgrightnow
                        • May 2020
                        • 24
                        Originally posted by dick_barton
                        U ribbons see photo
                        Thanks!
                        • hatinglgrightnow
                          • May 2020
                          • 24
                          Just tried switching the ribbon from the side that was working to the defective side and same result
                          I will try messing with the U-ribbon on the side that is defective.
                          Hope it works.
                          I should probably return the ribbons I ordered from ebay then right?
                          • hatinglgrightnow
                            • May 2020
                            • 24
                            Here is the U ribbon of the defective side, how can I seat it correctly? It looks to be in properly, I never took them out when replacing the LEDs.
                            • budwich
                              • Jul 2015
                              • 3097
                              you need to provide a better picture of the bottom edge board on the side showing the gray vertical bar so the forum can see how that side is interconnected. As pointed out, the "U" ribbon cables interconnect the bottom edge boards to complete the drive paths. However, on sets of this size, there may also be side tabs and / or side edge boards (similar to the bottom one) that also might have some interconnect cabling.
                              further as a test, you can disconnect the "u" cable on the "bad" side, you should then see about 1/4 quarter of the picture go white (or black) depending on design... including the grey area should be "gone".
                              • hatinglgrightnow
                                • May 2020
                                • 24
                                Oh man, think I just found the culprit
                                Removed the tape to see the driver board on the defective side and about 3/4 of that tab is lift off the board.
                                Is there anyway to fix this or am I a goner?
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  yep that's the problem... others may have some ideas.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    what ever you do, don't take it any further off as right now it is basically holding "alignment"... you might get lucky by very carefully cleaning what you can and possibly holding it back down with something.
                                    • hatinglgrightnow
                                      • May 2020
                                      • 24
                                      Yeah that is what I am thinking. But holding it down with what? Tape would work? People seem to be using ACF bonding tape. And what to clean it with?
                                        • 12332
                                        • U.S.
                                        #39
                                        Very tedious work, there's plenty more on youtube: https://www.youtube.com/watch?v=o_iBM5JgE28
                                        • hatinglgrightnow
                                          • May 2020
                                          • 24
                                          wow his comment is "Manually Cof bonding process is totally impossible.
                                          I have shared my practical experience on it.
                                          Don't waste your time."
                                          • sofles
                                            Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
                                            by sofles
                                            Hi there,
                                            Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
                                            With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
                                            05-30-2025, 01:11 PM
                                          • kdaniel
                                            Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                                            by kdaniel
                                            As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                                            There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                                            After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                                            Left...
                                            11-16-2022, 09:23 AM
                                          • zesko
                                            xps 9520 ribbon cable
                                            by zesko
                                            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                                            There is 2 models, idk which one is needed on my laptop.
                                            0xkvng
                                            00vpr2
                                            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                                            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                                            thanks...
                                            10-23-2025, 05:03 PM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
