Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
    the picture of the TV with both cables inserted shows a brighter spot where the line originates, that gives it away, panel problem, also I think the last picture (full white) is the TV without any ribbons and the line is still there, but we haven't asked OP about that.
      • 12328
      • U.S.
      pm sent.
      • kdaniel
        • Oct 2016
        • 25
        Originally posted by Davi.p
        don't buy tcon, don't waste money..100% only panel damaged.. only signal masking can quiet bad part of screen..
        I will take more time with masking the lines. I am unfortunately not a super expert on repairs but I am willing to dig deep into problems and learn from each repair. I would like to know how to possibly identify which line is which signal... if that makes sense. I've been searching through the forum but can't really find this explained, wherever I look it was only a "guess and tape method".
        have you tried the suggested tape method?
        Yes, but as from above, I tried random connection points without any luck, and the image only got worse... I will go back to it.
        No, that is only a white image "video" (with both ribbons inserted) that I played through YouTube, in the hope to show you the image better on the white screen as the lines are a lot more visible on bright colour backgrounds
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4534
          • Italy - Milan
          The clock lines that come from tcon to panel controls each one a subset of lines, some few lines are broken so you must choose from two, block all lines or the single start pulse that does the same, or finding the subset with the ones broken by blocking corresponding clock. Another way maybe is the drilling method thought by me but never experimented.. i never find such defect on tv on sale..
          • kdaniel
            • Oct 2016
            • 25
            Finally found some time to get back to this TV and after a few hours, I decided to stop and leave it to the point where I could not get the image any better.
            I used the taping method and pins 1,2 and 10 had to be taped to get the best possible picture on the TV.
            While watching the video you could not say there is anything wrong with it but as could be seen in the last (red) image, the left side of the screen lost its rich colours and they are now blurry.
            If you guys have any additional advices of possible solutions to get the image even better, I might get back to it when I get more time.
            I just want to thank you for all your advice and whoever tried to help me.
            • alfatv
              • Sep 2020
              • 353
              Can you find out the signal names that you blocked? In particular, check if it's VGH.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4534
                • Italy - Milan
                #27
                in the last picture what it is supposed that might be showed?
                • ggil44
                  Sony XBR-65X750D Horizontal lines bottom of screen
                  by ggil44
                  Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                  05-30-2023, 07:51 PM
                • howardc64
                  by howardc64
                  07-24-2025, 05:17 PM
                • x_orange90_x
                  Samsung UN46C8000XFXZA Horizontal lines
                  by x_orange90_x
                  I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                  I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                  07-15-2023, 05:06 AM
                • noipi
                  samsung Oled 65 Horizontal Lines and Flicker
                  by noipi
                  I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                  10-14-2025, 02:11 AM
                • Rubenlily
                  Samsung QE50Q67TAU - horizontal lines
                  by Rubenlily
                  First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                  I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                  I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                  I'm no expert but I've done the tape...
                  08-16-2023, 01:12 PM
