Samsung UN46D6500VF - no display, odd lines and double image on half of display
  • nomoresonys
    • 12274
    • U.S.
    Re: Samsung UN46D6500VF - no display, odd lines and double image on half of display
    Yep didn't register that you wrote B1, lol, C is the designator for capacitor.
    • viewfindr
      • Feb 2019
      • 37
      Just tested some with a 5 dollar Harbor Freight meter, they read over 120, sometimes you need to re-apply probes to get a reading to make sure you have good contact, you need to look quick because it will give the reading then go back to 1 in about a second til you re-apply the probe.
      Thanks for all of the helpful suggestions in this thread so far! I have that same $5 cheapo meter from HF, so I went back to try again.
      I still wasn't able to get a reading on every one of the caps, but did pick up a reading of 170-180ohms on a few in each of the 3 tab bonding sections on the bad side, which seems to align with the readings on the 2-3 caps I checked on the good side as well. Is it necessary to check over every single one of the caps on the bad side?
        "Is it necessary to check over every single one of the caps on the bad side?" Yes.
        • viewfindr
          • Feb 2019
          • 37
          Okay, I'll go do that. If they all come back in the same range of >100 ohms, is it safe to say the issue is in the tcon?
          • viewfindr
            • Feb 2019
            • 37
            Sorry for the delay, but I finally picked this project up again and took some new measurements on the tab bonding board with a new multimeter.
            All caps measure between 3-6 kOhms on both sides. Is this variance expected? Does this mean that the panel is actually okay?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4458
              • Italy - Milan
              #26
              Hi, starting from the pictures in your first post you surely have a bad side driver, a gate driver, so i suggest don't mess around with capacitors, you are not so lucky, the only way to save it is to isolate that whole side of drivers, get an adhesive tape , what happens if you block the signal VSS against one side of screen or another doing one at a time placing the tiny strip on the tcon connector? PS: Vss is marked on one side only in tcon but that is connected also to the other.
              • viewfindr
                • Feb 2019
                • 37
                Do you have any suggestions on which part of the connector to block with tape? I see a VSS test point on the board, but am not sure if the area to try would be the connectors right underneath it?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4458
                  • Italy - Milan
                  #28
                  Obviosly you take the meter in continiuity and check to which pins of both connectors is connected the vss TP, start to block the side opposite to the side that is working better. Ensure you have no traces of past adhesives on connectors.
                  • viewfindr
                    • Feb 2019
                    • 37
                    I covered the 5-6 pins around the VSS point on the tcon with clear tape and can only get white bars to show up on the screen. Since this is the case, I assume that this is a lost cause and it's not worth trying a new tcon?
                    • budwich
                      • Jul 2015
                      • 3097
                      have you tried looking around the front of the panel to see if there is some visible damage where the tabs are connected to the panel? You need to remove the front bezel to see the area. Maybe someone "window washed" the screen.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4458
                        • Italy - Milan
                        #31
                        My english is bad, maybe i don't explain well, must be blocked only Vss and only on one connector, the one of the worst side. It is not a lost cause, there is more to study on, and stop.
                        • howardc64
                          TCL 49S405 double image
                          by howardc64
                          LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                          This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                          06-23-2025, 03:20 PM
                        • Formaster
                          Sony KD75XE9005 Bottom half double image
                          by Formaster
                          Hi guys,
                          I'm tyred from these sympthom, if anyone helps me really big thx.
                          When i open the connection and play with these ribbon cables, i can get back the image problem free. BUT after turn off and ON, the bottom half is ghosted/doubled again. Did'nt from touch, only reboot the TV. I have changed the ribbons from the other side, but the same. Anyone any idea please?...
                          08-10-2021, 06:57 AM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                        • jason123
                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                          by jason123
                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                          07-19-2025, 08:07 AM
